查看: 2624|回复: 2
[求助]:Microstation XM V08090282 中文版的MicroStation GeoGraphics相应的模块下载
发表于 2007-5-28 17:23:36 | 显示全部楼层 |阅读模式
Microstation XM V08090282 中文版的MicroStation GeoGraphics相应的模块下载?
帮帮忙啊 给我一个下载地址?谢谢
发表于 2007-6-2 12:51:26 | 显示全部楼层
好像还没有
 楼主| 发表于 2007-6-14 14:43:00 | 显示全部楼层
Bentley Geospatial Extension v08.09.03.19 (地理信息系统):
为绘图人员、土木工程和规划专业技术人员专门设计的, 具有强大的GIS功能、集成在MicroStation环境之中的GIS产品。MicroStation GeoGraphics将MicroStation工业标准资料的获取及编辑工具, 完整的资料库界面及空间分析功能完美地结合在一起,提供制作、管理与发布地理工程咨询完整功能的作业平台 。
   Geospatial Extension is a powerful product that provides a
   user-friendly interface to make complex tasks easier. The examples
   demonstrate the easy use of Geospatial Extension basic functionality
   with simple, step-by-step instructions. The QuickStart Guide focuses
   on Geospatial Extension project-related functions and works with the
   sample Mytown database, or with the Mytown export file, which does not
   require a database connection. This QuickStart Guide is a supplement to
   the full set of Geospatial Extension documentation. is a key engineering
   product and forms the foundation for discipline-specific applications.
   By configuring MicroStation for geoengineering use, it significantly
   increases user productivity and offers a more natural and easy-to-use
   environment for users in geoengineering than plain MicroStation elements
   and operations. With this engineering configuration included with
   MicroStation, independent software developers can take advantage of
   high-level functionality to increase application performance and reduce
   development time. Finally, using this engineering configuration
   facilitates the migration to component-based modeling.
这就是Microstation XM V08090282 中文版的MicroStation GeoGraphics相应的地理模块啊?谁能提供下载地址啊
GMT+8, 2026-11-1 14:17 , Processed in 0.479594 second(s), 36 queries , Gzip On.
