查看: 1560|回复: 3
[ARX程序]:各位高人帮个忙,有用过 AcApLayoutManager 这个类吗
发表于 2007-6-1 16:51:33 | 显示全部楼层 |阅读模式
请各位高人帮个忙,有用过 AcApLayoutManager 这个类吗
就是创建、或复制图纸空间的类
createLayout、copyLayout主要这两个函数怎么用
谢谢!
发表于 2007-6-14 00:55:03 | 显示全部楼层
Re: [ARX程序]:各位高人帮个忙,有用过 AcApLayoutManager 这个类吗
最初由 ksbaidu 发布
[B]请各位高人帮个忙,有用过 AcApLayoutManager 这个类吗
就是创建、或复制图纸空间的类
谢谢! [/B]
有的
  1.   [FONT=courier new]
  2. Acad::ErrorStatus
  3. CreateLayoutFromTemplate(
  4.       AcDbObjectId &layoutId,
  5.       AcDbObjectId &blockTableRecId,
  6.       AcDbViewport*& pVP,
  7.       const char* dwtName,
  8.       const char* entryName
  9.       )
  10. {
  11.   Acad::ErrorStatus es;
  12.   AcDbDatabase *pDWTdb = new AcDbDatabase(false);
  13.
  14.   es = pDWTdb->readDwgFile(dwtName);
  15.   if (es == Acad::eOk )
  16.   {
  17.     //get the layout dictionary
  18.     AcDbDictionary *pDict = NULL;
  19.     es = pDWTdb->getLayoutDictionary(pDict,AcDb::kForRead);
  20.
  21.     AcDbObject *pObj = NULL;
  22.     AcDbLayout *pSrcLayout = NULL;
  23.     AcDbLayout *pNewLayout = NULL;
  24.
  25.     //copy the layout entryName from the drawing template
  26.     //or you can use the AcDbDictionaryIterator to get the required AcDbLayout  from the database
  27.     es = pDict->getAt(entryName, pObj, AcDb::kForWrite);
  28.     //close the dictionary
  29.     pDict->close();
  30.     if(es == Acad::eOk) // es = pDict->getAt(entryName, pObj, AcDb::kForWrite);
  31.     {
  32.       pSrcLayout = AcDbLayout::cast(pObj);
  33.       //add new layout to the current document
  34.       AcApLayoutManager *pLayoutMan = (AcApLayoutManager*)acdbHostApplicationServices()->layoutManager();
  35.
  36.       //get the name to create a new layout
  37.       char* psName;
  38.       psName = pLayoutMan->getNextNewLayoutName();
  39.
  40.       //create a new layout
  41.       pLayoutMan->setCreateViewports(Adesk::kTrue);
  42.       pLayoutMan->createLayout(psName, layoutId, blockTableRecId);
  43.       pNewLayout = pLayoutMan->findLayoutNamed(psName, TRUE);
  44.       //copy from the source layout in to the new layout
  45.       pNewLayout->copyFrom(pSrcLayout);
  46.
  47.       //open the newlayout object to refresh the list
  48.       //this required to refresh the device list
  49.       pNewLayout->upgradeOpen();
  50.       AcDbPlotSettingsValidator *pPltValid = NULL;
  51.       pPltValid = acdbHostApplicationServices()->plotSettingsValidator();
  52.       pPltValid->refreshLists(pNewLayout);
  53.
  54.       //close the layouts
  55.       pNewLayout->close();
  56.       pSrcLayout->close();
  57.
  58.       //update the layout tabs using the layout manager
  59.       pLayoutMan->updateLayoutTabs();
  60.
  61.       // copy entity from template
  62.       // Source BlockTableRecordId
  63.       AcDbObjectId sourceId = pSrcLayout->getBlockTableRecordId();
  64.       // Source BlockTableRecord
  65.       AcDbBlockTableRecord *pSource = 0;
  66.       // Open Source for Read
  67.       es = acdbOpenObject(pSource, sourceId, AcDb::kForRead);
  68.       if(es == Acad::eOk) // es = acdbOpenObject(pSource, sourceId, AcDb::kForRead);
  69.       {
  70.         AcDbBlockTableRecordIterator* pIter = 0;
  71.         pSource->newIterator(pIter);
  72.         AcDbObjectIdArray Idlist;
  73.         while(!pIter->done())
  74.         {
  75.           // Add all the entities to the list
  76.           AcDbEntity *pEnt = 0;
  77.           es = pIter->getEntity(pEnt, AcDb::kForRead);
  78.           if(es == Acad::eOk)
  79.           {
  80.             AcDbObjectId obj;
  81.             AcDbObjectId id = pEnt->objectId();
  82.             Idlist.append( id );
  83.             if((obj = pEnt->extensionDictionary()) != AcDbObjectId::kNull)
  84.             {
  85.               AcDbDictionary *pDict = 0;
  86.               acdbOpenObject(pDict, obj, AcDb::kForWrite);
  87.               pDict->setTreatElementsAsHard(Adesk::kTrue);
  88.               pDict->close();
  89.             }
  90.             pEnt->close();
  91.           }
  92.           pIter->step();
  93.         }
  94.         delete pIter;
  95.
  96.         pSource->close();
  97.
  98.         // New BlockTableRecordId
  99.         //AcDbObjectId newId = pNewLayout->getBlockTableRecordId();
  100.         // Set this Layout Current
  101.         //es = pLayoutMan->setCurrentLayoutId(newId);
  102.         es = pLayoutMan->setCurrentLayoutId(layoutId);
  103.
  104.         AcDbDatabase *pNewDb;
  105.         es = pDWTdb->wblock( pNewDb, Idlist, AcGePoint3d::kOrigin);
  106.
  107.         acdbHostApplicationServices()->workingDatabase()->insert(AcGeMatrix3d::kIdentity, pNewDb);
  108.
  109.         delete pNewDb;
  110.
  111.       }
  112.
  113.
  114.       // delete the damnnnnnnnnn- AcDbViewPort
  115.       AcDbBlockTableRecord *pTarget = 0;
  116.       // Open Source for Read
  117.       es = acdbOpenObject(pTarget, blockTableRecId, AcDb::kForRead);
  118.       if(es == Acad::eOk)
  119.       {
  120.         AcDbBlockTableRecordIterator* pIter = 0;
  121.         pTarget->newIterator(pIter);
  122.         bool bFirst = true;
  123.         while(!pIter->done())
  124.         {
  125.           // Add all the entities to the list
  126.           AcDbEntity *pEnt = 0;
  127.           es = pIter->getEntity(pEnt, AcDb::kForRead);
  128.
  129.           if(es == Acad::eOk)
  130.           {
  131.             if (pEnt->isKindOf(AcDbViewport::desc()))
  132.             {
  133.               AcDbViewport *pVPort = (AcDbViewport *)pEnt;
  134.
  135.               es = pVPort->upgradeOpen();
  136.               if (!pVPort->isOn() )
  137.               {
  138.                 if (bFirst)
  139.                 {
  140.                   pVPort->erase();
  141.                   bFirst = false;
  142.                 }
  143.                 else
  144.                 {
  145.                   pVPort->setOn();
  146.                   pVP = pVPort;
  147.
  148.                 }
  149.               }
  150.             }
  151.             pEnt->close();
  152.           }
  153.
  154.           pIter->step();
  155.         }
  156.         pTarget->close();
  157.       }
  158.     }
  159.   }
  160.   delete pDWTdb;
  161.
  162.   return es;
  163. }
  164.   [/FONT]
发表于 2007-6-20 20:29:54 | 显示全部楼层
谢谢rave
发表于 2026-2-16 11:06:54 | 显示全部楼层
学习了,好代码 赞
GMT+8, 2026-11-22 07:53 , Processed in 0.321663 second(s), 16 queries , Gzip On, File On.
