查看: 1680|回复: 2
[编程申请]:申请自动布置自动喷水喷头
发表于 2007-6-14 20:48:20 | 显示全部楼层 |阅读模式
很多专业软件,不能满足不规则房间喷头布置要求,一般设计人员都要先画辅助线,然后在辅助线交点布置圆,能不能编制一个LISP,自动识别直线交点,并在交点处自动绘制可自定半径大小的圆。
发表于 2007-6-15 16:15:41 | 显示全部楼层
[php]
(DEFUN C:TEST ()
(SETVAR "CMDECHO" 0)
(SETQ OLDOS (GETVAR "OSMODE"))
(SETVAR "OSMODE" 0)
(PRINC "\n选择直线 :")
(IF (SETQ SS (SSGET)) (PROGN
  (SETQ D (GETDIST "\n圆半径 :"))
  (SETQ N -1 SL (SSLENGTH SS))
  (WHILE (< N (- SL 1))
   (SETQ ENT (ENTGET (SSNAME SS (SETQ N (1+ N))))
         PT1 (CDR (ASSOC 10 ENT))
         PT2 (CDR (ASSOC 11 ENT))
         I N)
   (WHILE (< I (- SL 1))
    (SETQ ENT1 (ENTGET (SSNAME SS (SETQ I (1+ I))))
          PT3 (CDR (ASSOC 10 ENT1))
          PT4 (CDR (ASSOC 11 ENT1))
          PT5 (INTERS PT1 PT2 PT3 PT4 T))
    (IF PT5 (COMMAND "CIRCLE" PT5 D))
(PRINC)
[/php]
 楼主| 发表于 2007-6-22 14:19:23 | 显示全部楼层
谢谢
GMT+8, 2026-11-22 10:01 , Processed in 0.417425 second(s), 14 queries , Gzip On, File On.
