查看: 1258|回复: 2
[求助] [求助]:如何实现文字截取转换并计算?
发表于 2007-7-24 14:40:41 | 显示全部楼层 |阅读模式
如何在全部文字中选定带"S="前缀的字符,如何截取"S=17.78"和"S总=17.78"这两种字符中,数字部分的内容,并转换成实数相加呢?请各位高手出手一下!,
发表于 2007-7-28 19:27:21 | 显示全部楼层
(defun c:zz ()
    (setq ss (ssget "all" '((0 . "*TEXT") (1 . "S=*,S总=*"))))
    (setq n -1)
    (setq sum 0.0)
    (repeat (sslength ss)
        (setq en_data (entget (ssname ss (setq n (1+ n)))))
        (setq txt (cdr (assoc 1 en_data)))
        (setq sum (+ sum (atof (substr txt (+ (vl-string-position (ascii "=") txt) 2)))))
发表于 2007-7-28 20:24:52 | 显示全部楼层
ssget居然还有 all  这个过滤模式??
GMT+8, 2026-11-3 07:09 , Processed in 0.584104 second(s), 34 queries , Gzip On.
