查看: 1527|回复: 0
[转贴]:圖層合併,摘自明經
发表于 2007-7-31 09:05:28 | 显示全部楼层 |阅读模式
  1.   [FONT=courier new]
  2. (defun mergelays (lay1 lay2 / cnt space blocks attrs)
  3.   (command "-layer" "u" lay1 "")
  4.   (setq blocks (vla-get-blocks (vla-get-activedocument
  5.                                                        (vlax-get-acad-object)
  6.                                )
  7.                )
  8.   )
  9.   (setq cnt 0)
  10.   (while (< cnt (vla-get-count blocks))
  11.     (setq space (vla-item blocks cnt))
  12.     (vlax-for itm space (if (= (strcase (vla-get-layer itm))
  13.                                (strcase lay1)
  14.                             )
  15.                           (vla-put-layer itm lay2)
  16.                         ) (if (and
  17.                                 (= (vla-get-objectname itm)
  18.                                    "AcDbBlockReference"
  19.                                 )
  20.                                 (= (vla-get-hasattributes itm) :vlax-true)
  21.                               )
  22.                             (progn
  23.                               (setq attrs (vlax-safearray->list
  24.        (vlax-variant-value
  25.        (vla-getattributes itm)
  26.        )
  27.                                           )
  28.                               )
  29.                               (foreach attr attrs
  30.                                 (if (= (strcase (vla-get-layer attr))
  31.                                        (strcase lay1)
  32.                                     )
  33.                                   (vla-put-layer attr lay2)
  34.                                 )
  35.                               )
  36.                             )
  37.                           )
  38.     )
  39.     (setq cnt (1+ cnt))
  40.   )
  41.   (if (= (getvar "CLAYER") lay1)
  42.     (setvar "CLAYER" lay2)
  43.   )
  44.   (command "_.purge" "lay" lay1 "_n")
  45.   (princ)
  46. )
  47.   [/FONT]
GMT+8, 2026-11-22 08:33 , Processed in 0.382792 second(s), 10 queries , Gzip On, File On.
