查看: 1243|回复: 5
[求助] [求助]:多段线的标注
发表于 2007-8-9 12:28:16 | 显示全部楼层 |阅读模式
一条多义线,要是标注各顶点间的水平距离可以用快速标注命令qdim,可是要是想标注各顶点到某一水平线的垂直距离却不行,只能一个个标注,有没有快速的办法,可以一下子将多义线的各顶点与水平线的垂直距离标注出来?
发表于 2007-8-9 13:36:42 | 显示全部楼层
[php]
(defun c:tt (/ D I LEAME P10 PLEAME PLST)
  (defun get_pt        (ename / elist ptlist)
    (setq elist (entget ename))
    (foreach n elist
      (if (= 10 (car n))
        (setq ptlist (cons (cdr n) ptlist))
    (reverse ptlist)
  (if (and (setq pleame (car (entsel "\n>>>选择多段线<退出>:")))
           (setq leame (car (entsel "\n>>>选择水平线<退出>:")))
           (setq d (getdist "\n>>>输入标注间隔<退出>:"))
           (setq plst (get_pt pleame))
           (setq p10 (cdr (assoc 10 (entget leame))))
           (setq i 0)
    (repeat (length plst)
      (command ".DIMLINEAR"
               (nth i plst)
               p10
               (polar p10 pi (* (+ i 1) d))
      (setq i (1+ i))
    (princ "\n>>>安全退出!<<<")
  (princ "\n>>>程序执行完毕!<<<")
  (princ)
[/php]
发表于 2007-8-9 13:52:22 | 显示全部楼层
[php]
    (foreach n elist
      (if (= 10 (car n))
    (reverse ptlist)
           (setq i 0)
               (nth i plst)
               p10
      (setq i (1+ i))
  (princ)
[/php]
发表于 2007-8-10 01:48:19 | 显示全部楼层
XDCAD真是高手如云啊
 楼主| 发表于 2007-8-10 09:15:00 | 显示全部楼层
这个程序还不是我想要的,这个是距离起点标注水平距离的,我要得是标注各个顶点到水平线的竖直距离。
发表于 2007-8-11 19:48:08 | 显示全部楼层
[php]
    (foreach n elist
      (if (= 10 (car n))
    (reverse ptlist)
           (setq p11 (cdr (assoc 11 (entget leame))))
           (setq i 0)
      (setq p_t1 (nth i plst))
      (setq p_t2 (polar p_t1 (* 0.5 pi) 1))
      (setq p (inters p_t1 p_t2 p10 p11 nil))
               p_t1
               p
               (polar p pi (* (+ i 1) d))
      (setq i (1+ i))
  (princ)
[/php]
GMT+8, 2026-11-7 12:29 , Processed in 0.440745 second(s), 41 queries , Gzip On.
