查看: 1789|回复: 5
[求助]:cad2006安装问题 急!
发表于 2007-9-14 09:04:49 | 显示全部楼层 |阅读模式
安装AutoCAD 2006  进度到3分之二的时候  提示  错误1935安装汇编   电脑是新买的
请教高手怎么介解决?
发表于 2007-9-14 09:32:43 | 显示全部楼层
换板本
 楼主| 发表于 2007-9-14 10:03:50 | 显示全部楼层
2005也是这个问题!
发表于 2007-9-14 21:24:34 | 显示全部楼层
无语了。。。
我给好多机子装过2006,没见过你说的问题
发表于 2007-9-15 01:07:16 | 显示全部楼层
原廠有相關資料,參考看看吧
Error code 1935 during installation process
Published date: 2005-06-13
Applies to:AutoCAD® 2006AutoCAD® 2005AutoCAD LT® 2006AutoCAD LT® 2005
Issue
The product fails with a fatal error during installation. The following error message is displayed in a message box or in the client installer log file:
Error 1935. An error occured during the installation of the assembly component {A22E3DB9-BA62-4477-AF95-3189E7B06132}. HRESULT: -2147024891.
Note: The component name may vary. This is an example only.
Solution
This error occurs due to known issues with the Microsoft .NET Framework installer.
To work around this, try rebooting and attempting the installation again.
If this fails to resolve the problem try downloading and installing the latest released version of the .NET Framework from Microsoft at www.microsoft.com/downloads.
See the following links for more information and workarounds. If the problem persists, or for further technical information. contact Microsoft Product Support directly.
http://support.microsoft.com/default.aspx?scid=kb;en-us;308096
http://support.microsoft.com/default.aspx?scid=kb;en-us;839547
看起來主要是微軟的.net framework的問題,依照解決方案給的連結試試看吧
 楼主| 发表于 2007-9-17 10:55:17 | 显示全部楼层
非常感谢
GMT+8, 2026-11-23 21:40 , Processed in 0.509500 second(s), 20 queries , Gzip On, File On.
