查看: 1418|回复: 9
[编程申请]:关于“菜单条“在“AutoCAD“的实现,请相助!
发表于 2003-6-16 09:37:46 | 显示全部楼层 |阅读模式
关于“菜单条“在“AutoCAD“的实现,我最近作了一些尝试都不成功,可能是我在“界面“方面的功力不够。我查询了论坛上的有关资料,但好像还是帮助不大,希望各位能相助,不胜感激!
发表于 2003-6-17 23:19:14 | 显示全部楼层
你可以利用CAcUiDockControlBar来实现, 我以前发过的帖子里有示例,你搜搜
 楼主| 发表于 2003-6-18 12:23:30 | 显示全部楼层
怎么付了爱心币确下了些不能用的附件?
版主:
如下链接中的附件已坏(还要耗费爱心币),不知如何得到好的?
http://www.xdcad.net/forum/showt ... d=132726#post132726
http://www.xdcad.net/forum/showt ... d=116534#post116534
发表于 2003-6-22 22:15:07 | 显示全部楼层
It's so easy. The implementation of the menu bar of this type is not very difficult, but it need you to have an acvanced MFC skills and a complete knowleage about the SDI and MDI in VC.
    Here I  give your a tip. The essential step to implementate this is to get the main frame's handle or its pointer. If you can do that, every thing will be seem very easy. Ok, you can try that!
 楼主| 发表于 2003-6-23 11:10:24 | 显示全部楼层
Thanks ,"xu02118019"  !
But It's my problem that "acvanced MFC skills and a complete knowleage about the SDI and MDI in VC"!
Don't laugh at me please. I need a example about it ! Could you give me some help ?
发表于 2003-6-26 13:00:48 | 显示全部楼层
DARCY,
请参阅 http://www.xdcad.net/forum/showt ... d=165095#post165095
里面有解决办法,
发表于 2003-6-26 13:41:17 | 显示全部楼层
rave 在吗?
有个问题想请教你下
 楼主| 发表于 2003-6-28 16:43:00 | 显示全部楼层
谢谢!
最初由 rave 发布
[B]DARCY,
里面有解决办法, [/B]
谢谢版主,示例非常好,但确实存在一个问题,就是“CAcuiDockControlBar"的最小尺寸没法修改。
但我想,“菜单条 “的实现还是对于想我这样“MFC"功底不够的人来说有些难度。
但还是很感谢版主相助!
发表于 2003-7-10 10:14:03 | 显示全部楼层
DARCY,我也碰到和你一样的问题,不知你解决了吗?
 楼主| 发表于 2003-7-11 11:28:32 | 显示全部楼层
"CAcuiDockControlBar"我还是没用,我正在绕开此种方法去解决。
GMT+8, 2026-11-3 20:47 , Processed in 0.601834 second(s), 51 queries , Gzip On.
