查看: 2289|回复: 4
[求助]:二进制数据块加入实体xdata时失败。
发表于 2007-10-12 17:46:53 | 显示全部楼层 |阅读模式
int nBufferLength=12001;
        resbuf* pRes= acutBuildList(1001,"AppName",1000,"XXXX",0);
        pRes->rbnext->restype= AcDb::kDxfXdBinaryChunk;
        pRes->rbnext->resval.rbinary.clen= nBufferLength;
        acdbRegApp("AppName");
        ads_name entlast;
        acdbEntLast(entlast);
        acdbGetObjectId(m_idLayer0,entlast);
        AcDbObject* pObj;
        if (Acad::eOk == acdbOpenObject(pObj,m_idLayer0,AcDb::kForWrite))
                Acad::ErrorStatus es=pObj->setXData(pRes);
                pObj->close();
        if (Acad::eOk == acdbOpenObject(pObj,m_idLayer0,AcDb::kForRead))
                resbuf* pGetRes;
                pGetRes=pObj->xData("AppName");
                pObj->close();
这个小小的测试程序都失败了?为什么呢?
发表于 2007-10-13 08:59:47 | 显示全部楼层
有长度限制,不记得了,查查
发表于 2007-11-1 17:55:19 | 显示全部楼层
不错!
发表于 2007-11-4 10:52:39 | 显示全部楼层
pRes->rbnext 的数据没有准备好,resval.rbinary 只给其中一个值初始化了!
发表于 2007-11-5 11:04:48 | 显示全部楼层
struct resbuf* res;
res = acutNewRb(AcDb::kDxfBinaryChunk);
ads_binary bin;
bin.clen = ....
bin.buf = (char*) ....
res->resval.rbinary = bin;
res->rbnext = 0;
For resbufs, binary data can only be up to 127 bytes.  And, the size field of an ads_binary structure is a short not a long since it only has to handle values up to 127.
If your binary data is larger than 127 bytes, then you'll have to break it up across multiple resbufs.
GMT+8, 2026-11-2 23:10 , Processed in 0.590170 second(s), 40 queries , Gzip On.
