楼主: surenwang
[求助] [求助]:求助把这次移动或拉伸的距离作为下次的隐含值
发表于 2007-12-18 19:29:13 | 显示全部楼层
怎么设置呢?我还是不能用
 楼主| 发表于 2007-12-25 10:27:11 | 显示全部楼层
为什么出现
错误: 除数为零
 楼主| 发表于 2008-1-10 14:14:10 | 显示全部楼层
总算明白了一些
我改了下,现在可以用了
中途退出也能恢复系统变量
绘图比例都是1:1,没有交互输入。
(defun c:move1(/ ss blx0 p1 p2 ang dis p3)
    (setq *OLDERR* *ERROR*
         *ERROR*  *MYERR*)
    (modes '("osmode" "cmdecho" "orthomode" "AUTOSNAP"))
    (setvar "osmode" 0)
    (setvar "cmdecho" 0)
    (setvar "orthomode" 1)
    (setq ss (ssget) p1 (getvar "viewctr") blx0 1)
    (princ (strcat "\n**  当前绘图比例为1:" (itoa (fix blx0)) "  **"))
    (if mvang0
      (foreach n ' ((0 "向右")(1 "向上")(3 "向左")(4 "向下"))
        (if (= (fix mvang0) (car n)) (setq fx0 (cadr n)))
      (setq fx0 "竖直向上")
    (setq p2 (getpoint (strcat "\n搬移方向<" fx0 ">:") p1))
    (if p2 (setq ang (angle p1 p2)) (setq ang (if mvang0 mvang0 (/ pi 2))))
    (if (= distan nil) (setq distan 100))
    (princ  "\n移动距离<") (princ distan)
    (setq dis (getint  ">:" ))
    (if (= dis nil) (setq dis distan))
    (setq p3 (polar p1 ang dis))
    (command "move"   ss "" p1 p3)
    (setq distan dis mvang0 ang)
    (moder)
    (*ERROR* "命令结束")
    (princ)
(defun MODES (a)
  (setq MLST '())
  (repeat (length a)
    (setq MLST (append MLST (list (list (car a) (getvar (car a))))))
    (setq a (cdr a))
(defun MODER ()
  (repeat (length MLST)
    (setvar (caar MLST) (cadar MLST))
    (setq MLST (cdr MLST))
(defun *MYERR* (MSG)
(moder)
(setq *ERROR* *OLDERR*)
(if (= MSG "命令结束")
   (princ (strcat "\n" MSG))
   (princ "*取消*")
(princ)
发表于 2008-1-10 14:36:53 | 显示全部楼层
什么隐含值???
用
vlax-ldata-get
vlax-ldata-put
可以吗?
发表于 2008-1-21 22:31:05 | 显示全部楼层
试试u系列的udist:
  1. [FONT=courier new];;;---------------------- UDIST ---------------------------
  2. ;;;                  距离输入格式化
  3. ;;;方式 : (setq dist1 (udist 1 "" "距离" dist1 (list 0 0)))
  4. (defun udist (bit kwd msg def bpt / inp)
  5.   (if def
  6.     (setq msg (strcat "\n" msg "<" (rtos def) ">: ")
  7.           bit (* 2 (fix (/ bit 2)))
  8.     )
  9.     (setq msg (strcat "\n" msg ": "))
  10.   )
  11.   (initget bit kwd)
  12.   (setq        inp (if bpt (getdist msg bpt) (getdist msg)))
  13.   (if inp inp def)
  14. )
  15. [/FONT]
GMT+8, 2026-11-7 09:54 , Processed in 0.412859 second(s), 33 queries , Gzip On.
