查看: 4448|回复: 15
[编程申请]:求lsp程序,将水平标注的尺寸放到“水平标注”图层里,将垂直标注的尺寸
发表于 2007-12-13 16:32:28 | 显示全部楼层 |阅读模式
求lsp程序,图中有若干尺寸标注,框选这些标注,将水平标注的尺寸放到“水平标注”图层里,将垂直标注的尺寸放到“垂直标注”图层里,斜向标注的尺寸不变,谢谢。
发表于 2007-12-15 18:48:32 | 显示全部楼层
[php]
;将尺寸标注放入相应图层 晓东 zxq0220 2007.12.15
(defun c:tt ()
(setvar "CMDECHO" 0)
(setq cl (getvar "CLAYER"))
(if (setq ss (ssget "X" '((0 . "DIMENSION") (50 . 0.0)))) (progn
  (command "LAYER" "M" "水平标注" "")
  (command "CHPROP" ss "" "LA" "水平标注" "")
(if (setq ss (ssget "X" (list '(0 . "DIMENSION") (cons 50 (/ pi 2))))) (progn
  (command "LAYER" "M" "垂直标注" "")
  (command "CHPROP" ss "" "LA" "垂直标注" "")
(setvar "CLAYER" cl)
(setvar "CMDECHO" 1)
(princ)
[/php]
 楼主| 发表于 2007-12-16 16:01:55 | 显示全部楼层
二楼程序经CAD2004测试可用,zxq0220  长老。
发表于 2007-12-17 17:33:13 | 显示全部楼层
应该不完美,针对dimalign类型的会出错
 楼主| 发表于 2007-12-17 18:08:21 | 显示全部楼层
再测试,cad2004中,有部分尺寸无效,请下载附件测试。
发表于 2007-12-21 19:02:53 | 显示全部楼层
无法下载。
 楼主| 发表于 2007-12-23 09:58:03 | 显示全部楼层
再次上传附件。
不好意思,若还是不能下载,请到如下邮箱下载。
xdcadnet@163.com的密码是abc123
发表于 2007-12-23 11:33:19 | 显示全部楼层
[php]
;将尺寸标注放入相应图层 晓东 zxq0220 2007.12.23
(defun c:tt ()
(if (setq ss (ssget "X" (list (cons 0  "DIMENSION")))) (progn
  (setq i -1 ld (ssadd) vd (ssadd))
  (repeat (sslength ss)
   (setq en (ssname ss (setq i (1+ i)))
           ang (rem (cdr (assoc 50 (entget en)))pi))
;   (princ ang) (princ " ")
   (if (equal ang 0.0 1e-3) (setq ld (ssadd en ld)))
   (if (equal ang (/ pi 2) 1e-3) (setq vd (ssadd en vd)))
  (if (> (sslength ld) 1) (progn
   (command "CHPROP" ld "" "LA" "水平标注" "")
  (if (> (sslength vd) 1) (progn
   (command "CHPROP" vd "" "LA" "垂直标注" "")
(princ)
[/php]
 楼主| 发表于 2007-12-23 13:01:06 | 显示全部楼层
用CAD2004换个dwg文件测试,还是有问题,测试文件放在
xdcadnet@163.com 密码acb123
还请修正,呵呵。
发表于 2007-12-23 20:47:52 | 显示全部楼层
这个程序有什么用啊?不懂,我是初学者
发表于 2007-12-23 23:02:54 | 显示全部楼层
[php]
(defun c:tt ()
         ent (entget en))
   (if (or (= (setq ty (cdr (assoc 70 ent))) 33) (= ty 161))
    (setq ang (angle (cdr (assoc 13 ent)) (cdr (assoc 14 ent))))
        (setq ang (cdr (assoc 50 ent)))
   (setq ang (rem ang pi))
   (if (or (equal ang (/ pi 2) 1e-3) (equal ang (/ pi -2) 1e-3)) (setq vd (ssadd en vd)))
(princ)
[/php]
 楼主| 发表于 2007-12-24 00:56:35 | 显示全部楼层
呵呵,可以了,感谢zxq0220  大侠。
 楼主| 发表于 2007-12-24 01:06:30 | 显示全部楼层
这个程序有什么用呢?将水平标注与垂直标注提取出来,通过修改尺寸的坐标将其标注自动取整,而斜向标注的尺寸,即使 将其坐标取整,标出来的数值还是零丁。
发表于 2008-1-22 10:55:53 | 显示全部楼层
我现在爱心币不够,不能下载.呢给个地址吗?我直接下载.
发表于 2008-1-23 13:36:29 | 显示全部楼层
程序可以直接拷贝到剪切板中,不要币。
GMT+8, 2026-11-22 08:15 , Processed in 0.337957 second(s), 39 queries , Gzip On, File On.
