查看: 1941|回复: 4
[求助] [求助]:用了一个lisp后出现的问题
发表于 2007-12-31 01:36:45 | 显示全部楼层 |阅读模式
用了一个lisp执行运行命令后,又用了Ctrl+Z,可能是撤销次数不够,CAD出现了不能先选择实体后执行命令了,输入PICKFIRST,输入1回车。先选择实体,可以后用键盘执行命令了,但不能后执行图标命令,并且执行刚才那个lisp时,提示:错误: no function definition: VLAX-ENAME->VLA-OBJECT
请大侠出手相助,谢谢!
发表于 2007-12-31 22:30:32 | 显示全部楼层
假如可以,最好发代码上来看看。
发表于 2007-12-31 23:31:48 | 显示全部楼层
先选择实体后执行
在选项里自己设
发表于 2008-1-1 00:15:54 | 显示全部楼层
关闭CAD后重打开再试试看。
 楼主| 发表于 2008-1-1 01:54:32 | 显示全部楼层
谢楼上的几位朋友,
选项里设置是正确的
重新启动后,还是不行。
现在是运行这个lisp后,提示“函数错误”图层颜色变成黑色188了,生成的边界轮廓线不连贯,样条曲线也没有变成多段线。(以前把原点移动了,好像也有这种现象)
这是代码,是论坛上的,生成边界轮廓很不错。
;;边界轮廓线
(vl-load-com)
(defun c:j(/ viewpt maxmin spl2arc ss_add os cor qa ss n pt1 pt2 l_pt dis ent m)
  (defun viewpt(/ a b c d x)
    (setq b (getvar "viewsize") c (car (getvar "screensize")) d (cadr (getvar "screensize"))
          a (* b (/ c d)) x (setq x (getvar "viewctr")) x (trans x 1 2) c (list (- (car x)  (/ a 2.0)) (- (cadr x) (/ b 2.0)) 0.0)
          d (list (+ (car x) (/ a 2.0)) (+ (cadr x) (/ b 2.0)) 0.0) c (trans c 2 1) d (trans d 2 1)
    (list c d)
  (defun maxmin(lst / x n a b c d)
    (setq x (car lst) a (car x) b (cadr x) c (car x) d (cadr x) n 1)
    (repeat (max (- (length lst) 1) 0)
      (setq x (nth n lst) a (min a (car x)) b (min b (cadr x)) c (max c (car x)) d (max d (cadr x)))
      (setq n (1+ n))
    (list (list a b) (list c d))
  (defun spl2arc(ent / obj len num spt ept ss i pt1 pt2 pt3 s)
    (setq obj (vlax-ename->vla-object ent)
          len (vlax-curve-getDistAtParam obj (vlax-curve-getEndParam obj))
          num (1+ (fix (/ len dis)))
          num (if (= num 1) 2 num)
          spt (vlax-curve-getStartPoint obj)
          ept (vlax-curve-getEndPoint obj)
    (command "_.divide" ent (* 2 num))
    (setvar "cecolor" "1")
    (setq ss (ssget "_p"))
    (if (equal spt ept)
      (setq i 1)
      (setq i 0)
    (setq pt3 spt)
    (setq s (ssadd))
    (repeat num
      (setq pt2 (cdr (assoc 10 (entget (ssname ss i)))))
      (if (/= num (/ (+ i 2) 2))
        (setq pt1 (cdr (assoc 10 (entget (ssname ss (1+ i))))))
        (setq pt1 ept)
      (command "_.arc" pt3 pt2 pt1)
      (ssadd (entlast) s)
      (setq pt3 pt1)
      (setq i (+ 2 i))
    (command "_.erase" ss ent "")
    (setvar "cecolor" "188")
    s
  (defun ss_add(s1 s2 / n)
    (setq n -1)
    (repeat (sslength s1)
      (ssadd (ssname s1 (setq n (1+ n))) s2)
    s2
  (prompt "\n请选择要生成边界轮廓线的所有对象(图块轮廓要闭合):")
  (if (setq ss (ssget '((0 . "line,arc,circle,*polyline,spline,ellipse,insert"))))
    (progn
      (command "_.undo" "_be")
      (setq os (getvar "osmode")
            cor (getvar "cecolor")
            qa (getvar "qaflags")
      (setvar "osmode" 0)
      (setvar "cmdecho" 0)
      (setq n -1)
      (repeat (sslength ss)
        (vla-getboundingbox (vlax-ename->vla-object (ssname ss (setq n (1+ n)))) 'pt1 'pt2)
        (setq l_pt (append l_pt (list (vlax-safearray->list pt1) (vlax-safearray->list pt2))))
      (setq l_pt (maxmin l_pt)
            pt1 (car l_pt)
            pt2 (cadr l_pt)
            dis (/ (distance pt1 pt2) 20)
            pt1 (polar pt1 (angle pt2 pt1) dis)
            pt2 (polar pt2 (angle pt1 pt2) dis)
      (setq l_pt (maxmin (append (viewpt) (list pt1 pt2))))
      (command "_.zoom" "_w" (car l_pt) (cadr l_pt))
      (command "_.rectang" pt1 pt2)
      (setq ent (entlast))
      (command "_.boundary" "_a" "_o" "_r" "_i" "_y" "_b" "_n" ent ss "" "" (polar pt1 (angle pt1 pt2) (/ dis 2)) "")
      (if (equal (entlast) ent)
        (progn
          (entdel ent)
          (prompt "\n没有边界轮廓线!")
        (progn
          (entdel ent)
          (command "_.erase" (ssget "c" pt1 pt1 '((0 . "region") (62 . 188))) "")
          (setq m 0)
          (if (setq ss (ssget "x" '((0 . "region") (62 . 188))))
            (progn
              (command "_.union" ss "")
              (entmod (subst (cons 62 1) (cons 62 188) (entget (setq ent (entlast)))))
              (command "_.explode" ent)
              (if (= (cdr (assoc 0 (entget (ssname ss 0)))) "REGION")
                (progn
                  (setvar "qaflags" 1)
                  (command "_.explode" ss "")
              (if (ssget "p" '((0 . "spline,ellipse")))
                (progn
                  (setq dis (abs (if (setq dis (getreal "\n请输入样条曲线或椭圆的取样距离:<3>")) dis 3.0)))
                  (if (= dis 0.0) (setq dis 600.0))
              (setq n -1)
                (setq ent (ssname ss (setq n (1+ n)))
                      name (cdr (assoc 0 (entget ent)))
                (if (or (= name "SPLINE") (= name "ELLIPSE"))
                  (progn
                    (ssdel ent ss)
                    (setq ss (ss_add (spl2arc ent) ss))
                    (setq n (1- n))
              (setq n -1)
              (while (setq ent (ssname ss (setq n (1+ n))))
                (if (entget ent)
                  (progn
                    (command "_.pedit" ent "_y" "_j" ss "" "")
                    (setq m (1+ m))
          (if (setq ss (ssget "x" '((0 . "*polyline") (62 . 188))))
            (progn
              (setq n -1)
                (entmod (subst (cons 62 1) (cons 62 188) (entget (ssname ss (setq n (1+ n))))))
              (setq m (+ m (sslength ss)))
          (if (= m 0)
            (prompt (strcat "\n生成" (itoa m) "条边界轮廓线!"))
      (setvar "osmode" os)
      (setvar "cecolor" cor)
      (setvar "qaflags" qa)
      (command "_.undo" "_e")
  (princ)
(prompt "\n***边界轮廓线yad_outline***  YAD建筑")
(princ)
GMT+8, 2026-11-7 10:47 , Processed in 0.482345 second(s), 39 queries , Gzip On.
