查看: 939|回复: 2
[编程申请]:如何只开选择层
发表于 2008-1-23 10:39:09 | 显示全部楼层 |阅读模式
如题,如何只开选择层,谢谢
发表于 2008-1-24 12:51:32 | 显示全部楼层
;;; 显示指定图层;;;
(defun c:test(/ ss n i key)
  (setvar "cmdecho" 0)
  (setq ss (ssget))
  (setq n (sslength ss))
  (setq i 0)
  (command "layer" "off" "*" "y" "")
  (repeat n
    (setq key (cdr (assoc 8 (entget (ssname ss i)))))
    (command "layer" "on" key "")
    (setq i (+ 1 i))
  (princ)
发表于 2008-1-30 21:00:55 | 显示全部楼层
;;;[仅显示选层]
(defun c:G (/ ES EN EL A)
(princ "请选择对象,未被选中的对象所在层将被关闭")
(setq ES (ssget) A 0 EN ""EL nil FL nil)
(while (/= EN nil)
(setq EN (ssname ES A) EL (cons EN EL) A (1+ A)))
(setq EL (cdr EL) FL (cdr (assoc ' 8 (entget (car EL)))) EL (cdr EL))
(repeat (- A 2)
(setq EN (cdr (assoc ' 8 (entget (car EL))))
FL (strcat EN "," FL) EL (cdr EL)) )
(command "layer" "off" "*" "y" "on" (eval FL) "")
(princ)
GMT+8, 2026-11-7 09:55 , Processed in 0.394850 second(s), 35 queries , Gzip On.
