查看: 1344|回复: 7
[编程申请]:如何只开选择层
发表于 2008-1-23 10:52:55 | 显示全部楼层 |阅读模式
如题,如何只开选择层,谢谢
已领礼包: 12496个
发表于 2008-1-23 14:07:51 | 显示全部楼层
只保留显示当前层:
(command "-layer" "lock" "*" "")
发表于 2008-1-24 08:21:10 | 显示全部楼层
(command "layiso")
发表于 2008-1-24 08:53:46 | 显示全部楼层
安装ET(Express Tool)工具
另外一般的商业软件中
也都有此类功能
发表于 2008-1-30 21:07:17 | 显示全部楼层
;;;[仅显示选层]
(defun c:G (/ ES EN EL A)
(princ "请选择对象,未被选中的对象所在层将被关闭")
(setq ES (ssget) A 0 EN ""EL nil FL nil)
(while (/= EN nil)
(setq EN (ssname ES A) EL (cons EN EL) A (1+ A)))
(setq EL (cdr EL) FL (cdr (assoc ' 8 (entget (car EL)))) EL (cdr EL))
(repeat (- A 2)
(setq EN (cdr (assoc ' 8 (entget (car EL))))
FL (strcat EN "," FL) EL (cdr EL)) )
(command "layer" "off" "*" "y" "on" (eval FL) "")
(princ)
已领礼包: 2个
发表于 2008-1-31 16:34:17 | 显示全部楼层
楼上代码,修改后:
  1. (defun C:G (/ SS I LAYER)
  2.     (princ "\n请注意:未被选中的对象所在层将被关闭")
  3.     (if (setq SS (ssget))
  4.         (progn
  5.             (command "_.layer" "off" "*" "y" "")
  6.             (setq I 0)
  7.             (repeat (sslength SS)
  8.                 (setq LAYER (cdr (assoc 8 (entget (ssname SS I)))))
  9.                 (command "_.layer" "on" LAYER "")
  10.                 (setq I (1+ I))
  11.             )
  12.         )
  13.     )
  14.     (princ)
  15. )
发表于 2008-1-31 18:18:45 | 显示全部楼层
还是版主强!清爽了许多!
发表于 2008-2-2 10:46:18 | 显示全部楼层
看看那
GMT+8, 2026-11-7 09:55 , Processed in 0.517631 second(s), 46 queries , Gzip On.
