查看: 1535|回复: 4
[求助] [求助]:如何设置正交F8
发表于 2008-5-23 13:21:36 | 显示全部楼层 |阅读模式
在LISP程序中,如何设置正交
发表于 2008-5-23 14:03:38 | 显示全部楼层
(setVar "OrthoMode" 1)
 楼主| 发表于 2008-5-23 14:34:56 | 显示全部楼层
谢谢
发表于 2008-5-23 18:33:20 | 显示全部楼层
好象不同吧,F8是正交切换,不仅仅是正交啊,要怎么切换呢?
发表于 2008-5-23 21:03:27 | 显示全部楼层
ORTHOMODE System Variable
Type: Integer
Saved in: Drawing
Initial value: 0
Constrains cursor movement to the perpendicular.
When ORTHOMODE is turned on, the cursor can move only horizontally
or vertically relative to the UCS and the current grid rotation angle.
0 Turns off Ortho mode
1 Turns on Ortho mode
GMT+8, 2026-11-22 09:18 , Processed in 0.405882 second(s), 18 queries , Gzip On, File On.
