查看: 1269|回复: 1
[原创]:手动输入标高的值
发表于 2008-12-10 11:03:28 | 显示全部楼层 |阅读模式
(defun C:BZ ()                                ;手动输入标高的值
    (setq OSN (getvar "osmode"))
                                        ;(setvar"osmode" 32)
    (while (setq PT1 (getpoint "\n 给出标高标注位置点"))
        (setq ZL (getstring "\n 给出标高值(向左以/开头 向右以*开头)")
              TZ (substr ZL 1 1)
              CD (- (strlen ZL) 1)
              ZL (substr ZL 2 (1- (strlen ZL)))
              BL (/ (* (getvar "dimtxt") (getvar "dimscale")) 0.25)
        (if (and (/= TZ "*") (/= TZ "/"))
            (princ "标注内容有误")
            (progn
                (if (= TZ "*")
                    (setq FH 1)
                    (setq FH -1)
                (setq PT0 (polar PT1 0 (* BL FH 0.05))
                      PT1 (polar PT1 0 (* BL FH 0.18))
                      PT2 (polar PT1 0 (* BL FH 0.25))
                      PT3 (polar PT2 0 (* BL FH CD 0.075))
                      PT6 (polar PT2 0 (* BL FH CD 0.15))
                      PT4 (polar PT1 (/ pi 3) (* BL 0.2))
                      PT5 (polar PT1 (/ pi 1.5) (* BL 0.2))
                (setvar "osmode" 0)
                (command "pline"
                         PT1
                         "w"
                         "0"
                         "0"
                         PT4
                         PT5
                         "c"
                         "line"
                         PT0
                         PT6
                         "text"
                         "j"
                         "c"
                         (polar PT3 (/ pi 2) (* BL 0.05))
                         (* BL 0.3)
                         "0"
                         ZL
                (setvar "osmode" OSN)
    (command "redraw")
    (princ)
发表于 2008-12-15 12:33:39 | 显示全部楼层
以前用过!~~
GMT+8, 2026-11-22 11:40 , Processed in 0.534794 second(s), 12 queries , Gzip On, File On.
