查看: 4926|回复: 31
[下载]:比z0好用的Z轴归0工具
发表于 2008-12-17 10:49:48 | 显示全部楼层 |阅读模式
比z0好用的Z轴归0工具
发表于 2008-12-22 12:49:14 | 显示全部楼层
补充下:是邱枫汉化并修正的lsp
发表于 2008-12-22 22:20:38 | 显示全部楼层
好在哪里?请说明
发表于 2008-12-23 00:24:38 | 显示全部楼层
下载不了!!
已领礼包: 464个
发表于 2009-4-30 20:03:45 | 显示全部楼层
我很想下载,可惜下不了.
发表于 2009-4-30 20:15:41 | 显示全部楼层
好象是两个人在操作,
[B]但为什么不能下载呢?[/B] [/COLOR]
发表于 2009-4-30 22:02:27 | 显示全部楼层
不能下载!可否直接贴出来?
发表于 2009-5-4 09:57:32 | 显示全部楼层
我帮楼主贴出来
;;; FLATTEN.LSP version 2k.0, 25-May-1999
;;; 邱枫汉化并修正
;;; 2005年9月5日
;;; FLATTEN sets the Z-coordinates of these types of objects to 0
;;; in the World Coordinate System:
;;;  "3DFACE" "ARC" "ATTDEF" "CIRCLE" "DIMENSION"
;;;  "ELLIPSE" "HATCH" "INSERT" "LINE" "LWPOLYLINE"
;;;  "MTEXT" "POINT" "POLYLINE" "SOLID" "TEXT"
;;; copyright 1990-1999 by Mark Middlebrook
;;;   Daedalus Consulting
;;;   e-mail: markmiddlebrook@compuserve.com
;;; Thanks to Vladimir Livshiz for improvements in polyline handling
;;; and the addition of several other object types.
;;; You are free to distribute FLATTEN.LSP to others so long as you do not
;;; charge for it.
;;;*Why Use FLATTEN?
;;; FLATTENing is useful in at least two situations:
;;;  1) You receive a DXF file created by another CAD program and discover
;;;     that all the Z coordinates contain small round-off errors. These
;;;     round-off errors can prevent you from object snapping to
;;;     intersections and make your life difficult in other ways as well.
;;;  2) In a supposedly 2D drawing, you accidentally create one object with
;;;     a Z elevation and end up with a drawing containing objects partly
;;;     in and partly outside the Z=0 X-Y plane. As with the round-off
;;;     problem, this situation can make object snaps and other procedures
;;;     difficult.
;;; Warning: FLATTEN is not for flattening the custom objects created by
;;; applications such as Autodesk's Architectural Desktop. ADT and similar
;;; programs create "application-defined objects" that only the
;;; application really knows what to do with. FLATTEN has no idea how
;;; to handle application-defined objects, so it leaves them alone.
;;;*How to Use FLATTEN
;;; This version of FLATTEN works with AutoCAD R12 through 2000.
;;; To run FLATTEN, load it using AutoCAD's APPLOAD command, or type:
;;;   (load "FLATTEN")
;;; at the AutoCAD command prompt. Once you've loaded FLATTEN.LSP, type:
;;;   FLATTEN
;;; to run it. FLATTEN will tell you what it's about to do and ask you
;;; to confirm that you really want to flatten objects in the current
;;; drawing. If you choose to proceed, FLATTEN prompts you to select objects
;;; to be flattened (press ENTER to flatten all objects in the drawing).
;;; After you've selected objects and pressed ENTER, FLATTEN goes to work.
;;; It reports the number of objects it flattens and the number left
;;; unflattenened (because they were objects not recognized by FLATTEN; see
;;; the list of supported objects above).
;;; If you don't like the results, just type U to undo FLATTEN's work.
;;;*Known limitations
;;;  1) FLATTEN doesn't support all of AutoCAD's object types. See above
;;;     for a list of the object types that it does work on.
;;;  2) FLATTEN doesn't flatten objects nested inside of blocks.
;;;     (You can explode blocks before flattening. Alternatively, you can
;;;     WBLOCK block definitions to separate DWG files, run FLATTEN in
;;;     each of them, and then use INSERT in the parent drawing to update
;;;     the block definitions. Neither of these methods will flatten
;;;     existing attributes, though.
;;;  3) FLATTEN flattens objects onto the Z=0 X-Y plane in AutoCAD's
;;;     World Coordinate System (WCS). It doesn't currently support
;;;     flattening onto other UCS planes.
(defun C:FLT (/              olderr  oldcmd  zeroz   ss1     ss1len  i
              numchg  numnot  numno0  ssno0   ename   elist   etype
              yorn    vrt     crz
  ;;Error handler
  (setq olderr *error*)
  (defun *error* (msg)
    (if        (= msg "quit / exit abort")
      (princ)
      (princ (strcat "error: " msg))
    (setq *error* olderr)
    (command "._UCS"               "_Restore"         "$FLATTEN-TEMP$"
             "._UCS"               "_Delete"         "$FLATTEN-TEMP$"
    (command "._UNDO" "_End")
    (setvar "CMDECHO" oldcmd)
    (princ)
  ;;Function to change Z coordinate to 0
  (defun zeroz (key zelist / oplist nplist)
    (setq oplist (assoc key zelist)
          nplist (reverse (append '(0.0) (cdr (reverse oplist))))
          zelist (subst nplist oplist zelist)
    (entmod zelist)
  ;;Setup
  (setq oldcmd (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (command "._UNDO" "_Group")
  (command "._UCS"           "_Delete"           "$FLATTEN-TEMP$"
           "._UCS"           "_Save"           "$FLATTEN-TEMP$"
           "._UCS"           "World"
          )                                ;set World UCS
  ;;Get input
  (prompt
    (strcat
      "\n此程序校正二维图形的Z坐标不为0的情况."
  (initget "Yes No")
  (setq yorn (getkword "\n是否继续<Y>: "))
  (cond
    ((/= yorn "No")
     (graphscr)
     (prompt "\n选择要拍平的物体: ")
     (prompt
       "<直接回车将会自动选择所有物体>"
     (setq ss1 (ssget))
     (if (null ss1)                        ;if enter...
       (setq ss1 (ssget "X"))                ;select all entities in database
     ;;*initialize variables
     (setq ss1len (sslength ss1)        ;length of selection set
           i          0                        ;loop counter
           numchg 0                        ;number changed counter
           numnot 0                        ;number not changed counter
           numno0 0                        ;number not changed and Z /= 0 counter
           ssno0  (ssadd)                ;selection set of unchanged entities
     )                                        ;setq
     ;; 首先设置所有Thickness为0; By邱枫
     (princ "\n设置Thickness为0...")
     (command "_.chprop" ss1 "" "_Thickness" 0 "")
     ;;*do the work
     (prompt "\n处理Z轴坐标中...")
     (while (< i ss1len)                ;while more members in the SS
       (if (= 0 (rem i 10))
         (princ (strcat "\r处理Z轴坐标中..." (itoa i)))
       (setq ename (ssname ss1 i)        ;entity name
             elist (entget ename)        ;entity data list
             etype (cdr (assoc 0 elist)) ;entity type
       ;;*Keep track of entities not flattened
       (if (not        (member        etype
                        '("3DFACE"     "ARC"            "ATTDEF"
                          "CIRCLE"     "DIMENSION"  "ELLIPSE"
                          "LWPOLYLINE" "MTEXT"            "POINT"
         (progn                                ;leave others alone
           (setq numnot (1+ numnot))
           (if (/= 0.0 (car (reverse (assoc 10 elist))))
             (progn                        ;add it to special list if Z /= 0
               (setq numno0 (1+ numno0))
               (ssadd ename ssno0)
       ;;Change group 10 Z coordinate to 0 for listed entity types.
       (if (member etype
                   '("3DFACE"         "ARC"             "ATTDEF"         "CIRCLE"
                     "DIMENSION" "ELLIPSE"   "HATCH"         "INSERT"
                     "LINE"         "MTEXT"     "POINT"         "POLYLINE"
                     "SOLID"         "TEXT"
         (setq elist  (zeroz 10 elist)        ;change entities in list above
               numchg (1+ numchg)
       ;;Change group 11 Z coordinate to 0 for listed entity types.
       (if
         (member etype
                 '("3DFACE" "ATTDEF" "DIMENSION" "LINE" "TEXT" "SOLID")
          (setq elist (zeroz 11 elist))
       ;;Change groups 12 and 13 Z coordinate to 0 for SOLIDs and 3DFACEs.
       (if (member etype '("3DFACE" "SOLID"))
         (progn
           (setq elist (zeroz 12 elist))
           (setq elist (zeroz 13 elist))
       ;;Change groups 13, 14, 15, and 16
       ;;Z coordinate to 0 for DIMENSIONs.
       (if (member etype '("DIMENSION"))
         (progn
           (setq elist (zeroz 14 elist))
           (setq elist (zeroz 15 elist))
           (setq elist (zeroz 16 elist))
       ;;Change each polyline vertex Z coordinate to 0.
       ;;Code provided by Vladimir Livshiz, 09-Oct-1998
       (if (= etype "POLYLINE")
         (progn
           (setq vrt ename)
           (while (not (equal (cdr (assoc 0 (entget vrt))) "SEQEND"))
             (setq elist (entget (entnext vrt)))
             (setq crz (cadddr (assoc 10 elist)))
             (if (/= crz 0)
               (progn
                 (zeroz 10 elist)
                 (entupd ename)
             (setq vrt (cdr (assoc -1 elist)))
       ;;Special handling for LWPOLYLINEs
       (if (member etype '("LWPOLYLINE"))
         (progn
           (setq elist        (subst (cons 38 0.0) (assoc 38 elist) elist)
                 numchg        (1+ numchg)
           (entmod elist)
       (setq i (1+ i))                        ;next entity
     (prompt " 完成.")
     ;;Print results
     (prompt (strcat "\n" (itoa numchg) " 个物体已拍平."))
     (prompt
       (strcat "\n" (itoa numnot) " 个物体没有拍平.")
     ;;If there any entities in ssno0, show them
     (if (/= 0 numno0)
       (progn
         (prompt (strcat "  ["
                         (itoa numno0)
                         " 个物体具有非0基点无法处理]"
         (getstring
           "\n回车可以亮显这些物体... "
         (command "._SELECT" ssno0)
         (getstring "\n请按回车取消亮显... ")
         (command "")
  (princ)
(prompt
  "\n二维图形校正程序已加载."
(princ)
;;;eof
已领礼包: 35个
发表于 2009-5-31 18:10:32 | 显示全部楼层
好玩
发表于 2009-6-4 10:51:21 | 显示全部楼层
谢谢!
发表于 2009-6-17 23:53:51 | 显示全部楼层
原来z0确实有很多情况是不能起作用的,感谢楼主。
发表于 2009-6-18 10:55:59 | 显示全部楼层
不错急需
发表于 2009-6-18 11:53:44 | 显示全部楼层
不错,好用
发表于 2009-6-19 09:06:05 | 显示全部楼层
到底怎么个好法,下载试用了再说:)谢了
发表于 2009-6-19 16:32:55 | 显示全部楼层
我下载了,经过修改,移植到我自己的程序库中了,非常感谢
GMT+8, 2026-11-5 08:00 , Processed in 0.524518 second(s), 61 queries , Gzip On.
