查看: 1381|回复: 2
[求助] [求助]:各位老大麻烦帮我看看我以前下的xdcad的实体对齐源码要用什么命令启动另外要
发表于 2009-1-1 10:07:45 | 显示全部楼层 |阅读模式
各位老大麻烦帮我看看我以前下的xdcad的实体对齐源码要用什么命令启动另外要把它转成什么格式是lsp‘vlx,还是vba的
我在1例题的基础上修改的,绝对好用
Sub AlignEnt()
Dim ss As AcadSelectionSet
'创建选择集
Set ss = CreateSelectionSet
ss.SelectOnScreen
Dim ent As AcadEntity
Dim MinPoint As Variant
Dim MaxPoint As Variant
If ss.Count > 0 Then
Dim AlignMode As String
On Error Resume Next
ThisDrawing.Utility.InitializeUserInput 0, "Left Middle Right Up Down"
AlignMode = ThisDrawing.Utility.GetKeyword("选择对齐方式[左对齐(L)/对中(M)/右对齐(R)/上对齐(U)/下对齐(D)]/<左对齐>:")
'如果用户直接按下Enter键
If Err Then AlignMode = "Left"
If AlignMode = "" Then AlignMode = "Left"
Dim AlignPoint As Variant
Dim MovePoint(2) As Double
AlignPoint = ThisDrawing.Utility.GetPoint(, "请选择对齐点:")
For Each ent In ss
ent.GetBoundingBox MinPoint, MaxPoint
Select Case AlignMode
'获得对象移动的基点
Case "Left"
MovePoint(0) = MinPoint(0)
MovePoint(1) = AlignPoint(1)
MovePoint(2) = MinPoint(2)
Case "Middle"
MovePoint(0) = (MinPoint(0) + MaxPoint(0)) / 2
Case "Right"
MovePoint(0) = MaxPoint(0)
MovePoint(2) = MaxPoint(2)
Case "Up"
MovePoint(0) = AlignPoint(0)
MovePoint(1) = MaxPoint(1)
Case "Down"
MovePoint(1) = MinPoint(1)
End Select
ent.Move MovePoint, AlignPoint
'更新图形
Update
Next
Else
ThisDrawing.Utility.Prompt vbCr & "未选定对象,自动退出..."
End If
End Sub
Public Function CreateSelectionSet(Optional ssName As String = "ss") As AcadSelectionSet
'错误处理
Set ss = ThisDrawing.SelectionSets(ssName)
If Err Then Set ss = ThisDrawing.SelectionSets.Add(ssName)
'初始状态下清空选择集
ss.Clear
Set CreateSelectionSet = ss
End Function
发表于 2009-1-1 13:02:56 | 显示全部楼层
vb的,程序不全。
 楼主| 发表于 2009-1-1 21:14:29 | 显示全部楼层
哦!怪不得我用什么格式加载都没用也不知启动命令是什么看来没戏了
GMT+8, 2026-11-7 06:04 , Processed in 0.451014 second(s), 36 queries , Gzip On.
