查看: 1161|回复: 1
test
发表于 2009-1-12 23:51:35 | 显示全部楼层 |阅读模式
局部修改LW线的问题
如果想通过画示意线的方式来局部修改LWPOLYLINE线的话,有什么思路吗?
发表于 2009-1-13 14:38:12 | 显示全部楼层
一个示例,不太完善
  1. (defun c:tt (/ e el obj p pa1 tf code typ)
  2.   (if (and (setq e (entsel "\nPick Pline: "))
  3.            (setq el (entget (car e)))
  4.            (wcmatch (strcase (cdr (assoc 0 el))) "*POLYLINE")
  5.       )
  6.     (progn
  7.       (setq obj        (vlax-ename->vla-object (car e))
  8.             p        (vlax-curve-getclosestpointto obj (cadr e))
  9.             pa1        (fix (vlax-curve-getparamatpoint obj p))
  10.             tf        t
  11.       )
  12.       (while tf
  13.         (setq code (grread t 12 4)
  14.               typ  (car code)
  15.         )
  16.         (redraw)
  17.         (cond
  18.           ((= typ 3)
  19.            (vla-setwidth
  20.              obj
  21.              pa1
  22.              (distance p (cadr code))
  23.              (distance p (cadr code))
  24.            )
  25.            (setq tf nil)
  26.           )
  27.           ((= typ 5)
  28.            (grdraw p (cadr code) 4 1)
  29.            (vla-setwidth
  30.              obj
  31.              pa1
  32.              (distance p (cadr code))
  33.              (distance p (cadr code))
  34.            )
  35.           )
  36.           (t
  37.
  38.            (setq tf nil)
  39.           )
  40.         )
  41.       )
  42.     )
  43.   )
  44.   (princ)
  45. )
GMT+8, 2026-11-22 07:59 , Processed in 0.432479 second(s), 12 queries , Gzip On, File On.
