查看: 1824|回复: 3
[推荐]:精致古建模型
发表于 2009-1-22 14:31:55 | 显示全部楼层 |阅读模式
送礼自用两相宜---中国古典建筑模型
联系电话  13683520757  吴  请短信联系
中国古典建筑模型覆盖工艺礼品、教学用具、益智玩具、家装及实用陈设领域
DIY - Chinese Classical Architectural Models  They cover a large variety of artistic gifts, teaching tools, learning toys, home renovation and display equipment.
The Hall of Prayer for Good Harvest
天坛祈年殿
零售价格:¥3,850
批发价格:¥2,560
规格:直径83㎝×高52.5cm
包装尺寸:55㎝×36㎝×18㎝
净重/总重: 6.8 / 9.1 Kg
构件数量:2872件
天坛祈年殿的拼装过程图: http://www.wantian.com/bbs/read.php?tid=216
祈年殿是天坛中的主体建筑,是中国古典建筑中的精品,造型洗练,内涵丰富,充满了象征意义。祭坛采用上屋下坛的形式,整座殿宇高大巍峨,造型庄重华美,白色基石,蓝色殿瓦,金色宝顶,在四周古柏的掩映衬托下,显示出至尊至圣的气势。
  This is where the emperor prayed to heaven for abundant harvests. The hall was originally built in 1420A.D. but was destroyed by lightning and rebuilt in 1889.
       The great hall stands at the north of the square inside the Gate of Prayer for Good Harvest. It is circular with a roof of three layers of blue glazed tiles. It sits on a round three-storey platform, six meters high, of white stone.(consist of about 3000 component pieces
登录/注册后可看大图
Corner towers of the Forbidden City
故宫角楼
登录/注册后可看大图
零售价格:¥3,650
批发价格:¥1,880
规格:43㎝×43㎝×38㎝
包装尺寸:56㎝×35㎝×13㎝
净重/总重: 3.6 / 3.2 Kg
构件数量:1370件
明永乐十九年(1421年),明朝正式迁都北京,称为京师,清代继续建都于此。北京城中的故宫是皇帝的宫城,是我国古代建筑史上的杰作,显示出中国古代建筑艺术与工程技术的卓越水平。
       在紫禁城城墙上的四角,各建有一座造型奇特、风姿绰约的角楼。角楼平面呈曲尺形,结构为九梁十八柱,屋顶有七十二条脊,正中安铜鎏金宝顶,形象生动灵秀,巧夺天工。城墙建角楼之举古已有之,主要用于防卫望,但像紫禁城角楼这样的神品,却是绝无仅有之作,它的优美造型为紫禁城平添了无限神韵(整组建筑由约1500件构件拼接搭建而成,并可拆分组装为独立的重檐摩尼殿和三重檐藏经阁)。
       In each of the four corners of the walls of the Imperial City stood a corner tower, shaped like + when viewed from above. The roofs of these tower were double-eaved and hipped and gabled in a complex 72-ridge style. The exterior of the corner tower are not terribly rigid in adhering to the formal restrictions for palace hall. (consist of about 1500 component pieces )
三重檐十字观音阁  ¥960 / ¥880
登录/注册后可看大图
零售价格:¥960
批发价格:¥880
规格:34㎝×34㎝×38㎝
包装尺寸:43.5㎝×33㎝×10㎝
净重/总重: 2.13 / 3.5 Kg
构件数量:664件
观音阁是一座三间两层三重檐的殿阁,坐落于汉白玉须弥座之上,周匝栏杆,屋顶采用十字歇山脊,端庄而华丽。
摩尼殿
登录/注册后可看大图
零售价格:¥650
批发价格:¥398
规格:32.5㎝×22㎝×25.5㎝
包装尺寸:41㎝×30㎝×8㎝
净重/总重: 1.2 / 2.3Kg
构件数量:397件
摩尼殿是中国传统古典建筑的一个袖珍版,它的原型来自颐和园铜亭和武当山铜殿,是中国古代宫殿与殿宇建筑的微缩,精致完美,小巧玲珑.
The Wooden archway(Tree-span)
牌楼(四柱三间七牌楼)
登录/注册后可看大图
零售价格:¥490
批发价格:¥328
规格:38㎝×8㎝×25㎝
包装尺寸:38㎝×30㎝×7.5㎝
净重/总重: 0.574 / 1.72Kg
构件数量:274件
牌楼是中国古典建筑中独具特色的一种类型。在中国古代的寺观、宫苑、坛庙、陵墓、衙署、书院等建筑的前面,大多建有华丽端庄的牌楼,作为建筑群的起点和序幕;在城市街衢的起点与中段、主要街道的交汇处,以及主要桥梁的桥头,也往往布置高大醒目的牌楼,作为街区的标志。
       牌楼的种类很多,按建筑材料划分,可分为本质、石质、琉璃、木石混合、木砖混合等数种;按建筑造形分,则可分为柱不出头和柱出头两大类。其中以木质牌楼最多,在北京有众多古代牌楼的实例,成为城市区域文化的象征。
       In front of the larger temples, gardens, ets, there is often a wooden archway which serves as the entranceway to a complex of building. The wooden archway in front of gate is the primary landmark for the entire palace and garden. (consist of about 300 component pieces )
The Wooden archway(One-span)
小牌楼
登录/注册后可看大图
零售价格:¥185
批发价格:¥128
规格:16㎝×8㎝×23㎝
包装尺寸:23㎝×14㎝×5㎝
净重/总重:    0.212 / 0.52Kg
构件数量:119件
The Hanging Flower Gate:
四合院垂花门
登录/注册后可看大图
零售价格:¥275
批发价格:¥198
规格:21㎝×12㎝×20㎝
包装尺寸:23㎝×15㎝×6㎝
净重/总重:    0.39 / 0.65Kg
构件数量:175件
北京的四合院住宅是中国传统居住形式的典型代表,一般有前、中、后三院,或内、外两院,大门设于外院或前院的东南角,进入大门迎面为影壁,入门西折即为前院。前院与内院隔以中门和院墙,中门常为垂花门,位于中轴线上,将院子分隔为内宅和外宅,在传统住宅建筑中,它是联系分隔内外宅的特殊的建筑物。
        垂花门作为内宅的宅门,有很重要的地位,它是房宅主人社会地位、经济地位的标志,因而有很强的装饰性,有雕刻精美的垂莲柱、花罩,有色彩绚丽的彩绘,显得富贵华丽,有极强的装饰效果。垂花门种类很多,最常见的有独立柱担梁式、一殿—卷式、单卷棚式以及廊罩垂花门数种(整组建筑由170多件构件拼接搭建而成)。
        A Hanging Flower Gate is a type of courtyard gate. It gets its name from the two hanging posts beneath which there are flower carvings. This style of gate is often used in small courtyards in palace hall or gardens, or in the inner courtyards of som more elaborate residences. (consist of 170 component pieces
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
登录/注册后可看大图
发表于 2009-2-4 17:45:09 | 显示全部楼层
哪儿有买啊
发表于 2009-2-27 14:27:26 | 显示全部楼层
这是广告?
发表于 2009-2-27 14:59:15 | 显示全部楼层
GMT+8, 2026-11-22 07:57 , Processed in 0.407495 second(s), 16 queries , Gzip On, File On.
