查看: 2328|回复: 3
[求助] [求助]:请问怎样调用ai_molc命令?
发表于 2009-3-4 00:57:30 | 显示全部楼层 |阅读模式
编写一个程序调用_ai_molc
(defun c:dd ()
(command "_ai_molc" "" "")
(princ)
这样不对,好像是参数不对,为什么?
如果在命令栏输入ai_molc 是可以的
发表于 2009-3-4 08:22:57 | 显示全部楼层
---snip-----
;;;=== Make Object's Layer Current =============================
;; Makes the layer of the selected object current.  If there is one
;; object in the pickfirst set, it's layer is made current without
;; prompting for an object.  Else a prompt is issued.
(defun c:ai_molc(/ old_error end_undo old_cmdecho set1 ent undo_control)
  ;; Simple error handling.
---snip-----------------------------
(defun test () (c:ai_molc) )
(test)
发表于 2009-3-4 09:26:10 | 显示全部楼层
在acad.pgp的[AutoCAD Command Aliases]里面加入
    LC,        *AI_MOLC
就可以了,当然LC可以用自己的
发表于 2009-3-4 15:07:08 | 显示全部楼层
不懂
GMT+8, 2026-11-22 08:32 , Processed in 0.371538 second(s), 16 queries , Gzip On, File On.
