查看: 4062|回复: 10
[LISP函数]:另类图元隐藏/显示实体
发表于 2009-4-10 18:16:24 | 显示全部楼层 |阅读模式
通过建立组,隐藏或显示实体。希望对你们有点用处
发表于 2009-4-12 14:19:21 | 显示全部楼层
这个怎么用啊
发表于 2013-7-20 09:23:03 | 显示全部楼层
什么都看不到
发表于 2013-7-21 02:27:47 | 显示全部楼层
看来旧帖子的程序都丢失了。
重贴一下  详情 回复 发表于 2013-7-21 06:39
发表于 2013-7-21 06:39:19 | 显示全部楼层
evayleung 发表于 2013-7-21 02:27
看来旧帖子的程序都丢失了。
重贴一下
  1. ;;另类图元隐藏/显示,通过建立组隐藏实体
  2. ;|
  3. visible
  4. object.Visible
  5. object
  6.       All Drawing objects, Application, AttributeReference, Group, Toolbar
  7.       The object or objects this property applies to.
  8. Boolean; read-write (write-only for the Group object)
  9. TRUE:    The object or application is visible.
  10. FALSE:   The object or application is not visible.
  11. Remarks
  12. If you specify an object to be invisible, it will be invisible regardless of
  13. the application visible setting. Other factors can also cause an object to be
  14. invisible; for example, an objectwill not be displayed if its layer is off or
  15. frozen.
  16. Specifying the application to be invisible allows you to run tasks in the
  17. background without having to see the component.
  18. Specifies the visibility of an object or the application.
  19. All Drawing objects, Application, AttributeReference, Group, Toolbar
  20. |;
  21. (defun ea:SSonoff (tf s mode / groups gl)
  22.   (setvar "cmdecho" 0)
  23.   ;;检测是否有特定组
  24.   (if (vl-catch-all-error-p
  25.     (vl-catch-all-apply
  26.       'vla-item
  27.       (list
  28.         (setq
  29.           groups
  30.            (vla-get-groups
  31.          (vla-get-activedocument (vlax-get-acad-object))
  32.            )
  33.         )
  34.         "ea_hide_object"
  35.       )
  36.     )
  37.       )
  38.     (progn
  39.       (setq gr (vla-add groups "ea_hide_object"));添加组
  40.       (setq gl (entget (vlax-vla-object->ename gr)))
  41.       (entmod (subst '(71 . 0)
  42.              (assoc 71 gl)
  43.              gl
  44.           )
  45.       );不可选择
  46.     );end progn
  47.   );end if
  48.   (if (not tf)
  49.     (progn
  50.       (command ".select" "all" "r" s "")
  51.       (command ".group" "a" "ea_hide_object" "p" "")
  52.     );隔离隐藏用
  53.     (command ".group" "a" "ea_hide_object" s "")
  54.   )
  55.   (vla-put-visible
  56.     (vla-item groups "ea_hide_object")
  57.     mode
  58.   );隐藏组,实体将不拥有 62 组码
  59.   (princ)
  60. )
  61. ;;隐藏选择实体
  62. (defun c:Hideobj (/ ss)
  63.   (if (progn (princ "\n选择要隐藏的实体...")
  64.          (setq ss (ssget))
  65.       )
  66.     (ea:SSonoff t ss :vlax-false)
  67.   )
  68.   (princ)
  69. )
  70. ;;显示全部实体
  71. (defun c:Showall (/ ss)
  72.   (setvar "pickstyle" 0)
  73.   (if (not (vl-catch-all-error-p
  74.          (vl-catch-all-apply
  75.            'vla-item
  76.            (list
  77.          (setq
  78.            groups
  79.             (vla-get-groups
  80.               (vla-get-activedocument (vlax-get-acad-object))
  81.             )
  82.          )
  83.          "ea_hide_object"
  84.            )
  85.          )
  86.        )
  87.       )
  88.     (progn
  89.       (vla-put-visible
  90.     (vla-item groups "ea_hide_object")
  91.     :vlax-true
  92.       )
  93.       (command ".group" "e" "ea_hide_object");清除组
  94.     )
  95.   )
  96.   (princ)
  97. )
  98. ;;隐藏非选择实体
  99. (defun c:ISOobj    (/ ss)
  100.   (if (progn (princ "\n选择隔离实体....")
  101.          (setq ss (ssget))
  102.       )
  103.     (ea:ssonoff nil ss :vlax-false)
  104.   )
  105.   (princ)
  106. )
  107. (princ "\n\t命令: HideObj ShowAll IsoObj.")
谢谢。测试一下使用效果是否方便,这隐藏,显示,平时画图的时候用得最多了。  详情 回复 发表于 2013-7-21 10:22
发表于 2013-7-21 10:22:36 | 显示全部楼层
发表于 2013-10-27 20:53:59 | 显示全部楼层
很简洁很简洁很简洁很简洁很简洁很简洁
发表于 2014-3-23 21:38:33 | 显示全部楼层
谢谢楼主分享
发表于 2014-7-2 13:20:44 | 显示全部楼层
谢谢楼主分享
发表于 2015-2-12 10:12:40 | 显示全部楼层
这个怎么用啊:)
发表于 2019-6-1 20:30:27 | 显示全部楼层
真心好用,感谢感谢!
GMT+8, 2026-11-22 09:18 , Processed in 0.355538 second(s), 30 queries , Gzip On, File On.
