查看: 3027|回复: 5
[求助] 从点表画多边形
发表于 2009-4-24 19:10:36 | 显示全部楼层 |阅读模式
[pcode=lisp,true](defun draw_r(#l /)
(setq n 0
      p1 (nth n #l)
(while (< n (length #l ))
(setq p2 (nth n #l))
(vl-cmdf "pline" P1 P2)
(setq p1 p2)
(setq n (1+ n))
(command "c" )
(princ)
[/pcode]
试验
#l
((11662.9 2181.44 0.0) (11662.9 2598.96 0.0) (12215.8 2598.96 0.0) (12215.8
2181.44 0.0))
===> 能画出闭合多边形,多出如下提示
需要二维角点或选项关键字。
需要二维角点或选项关键字。
需要二维角点或选项关键字。
发表于 2009-4-24 22:22:53 | 显示全部楼层
  1. (defun draw_r (#l /)
  2.    (vl-cmdf "pline")
  3.      (foreach pt #L
  4.        (vl-cmdf pt)
  5.      )
  6.    (vl-cmdf "c" )
  7.    (princ)
  8. )
发表于 2009-4-24 23:35:40 | 显示全部楼层
  1. (apply 'command (append '("_Pline") (append #1 '("c"))))
复制代码
发表于 2009-4-25 00:43:23 | 显示全部楼层
看不懂这一段代码
 楼主| 发表于 2009-4-25 12:15:49 | 显示全部楼层
懂2楼没懂3楼,和4楼一样;都谢谢。
发表于 2009-4-25 23:02:28 | 显示全部楼层
也可以这样写
(apply 'vl-cmdf (cons "_Pline" (reverse (cons "c"  #L))))
GMT+8, 2026-11-22 08:09 , Processed in 0.182894 second(s), 20 queries , Gzip On, File On.
