查看: 1245|回复: 0
[日积月累]:autocadmap2008重复线检查源码
发表于 2009-6-19 14:48:57 | 显示全部楼层 |阅读模式
//-------------------------------------重复线检查----------------------------------------------------------
void CleanupDuplicates()
        SetCurLayer(_T("checklayer"),250);
        ade_id cleanupVarId = ADE_NULLID;        // variable ID
        ade_id cleanupModelId = ADE_NULLID;      // clean ID
          ade_id cleanupactionVarId = ADE_NULLID;  //variable ID
        ads_name ss;                             // selection set
        long qty = 0;                            // quantity数量(组类型,子类型)
        long totalqty=0;                         //所有错误的总和
        int type = 0;                            // clean error group type
        int subtype = 0;                         // clean error group subtype
        int done = 0;                            //是否完成清理工作
        int resultCode = 0;
        CString str;
        //给cleanup变量分配内存,变量初始化为它们的缺省值,使用tpm_varalloc.
        cleanupVarId = tpm_varalloc();
    cleanupactionVarId=tpm_varalloc();
        //为cleanup模型分配内存,使用 tpm_cleanalloc.
        cleanupModelId = tpm_cleanalloc();
        if( ! cleanupVarId || ! cleanupModelId ||!cleanupactionVarId)
                acutPrintf(_T("\n内存分配失败."));
                tpm_varfree(cleanupVarId);
                tpm_varfree(cleanupactionVarId);
                tpm_cleanfree(cleanupModelId);
                return;
        tpm_cleanactionlistins(cleanupVarId,1,8,cleanupactionVarId);//必须在tpm_cleaninit前调用
        TCHAR* pszConfigVarName = _T("INCLUDEOBJS_AUTOSELECT");//如何指定要清理的图元,0手动,1全部
        struct resbuf* pIncludeObjsVarValRb = acutBuildList(RTSHORT,1,0);
        resultCode = tpm_varset(
                               cleanupVarId,
                            pszConfigVarName,
                            pIncludeObjsVarValRb);//设置配置变量的值
        acutRelRb(pIncludeObjsVarValRb);
        TCHAR* pLayerName =_T("LINK_LAYER");//已设为1,所以此项失效
        struct resbuf* pLayerRb = acutBuildList(RTSTR,_T(""),0);//""为包含所有图层
                               cleanupVarId,
                            pLayerName,
                            pLayerRb);//设置配置变量的值
        acutRelRb(pLayerRb);
        // 初始化一个目标选择集命名为 ss进行清理工作
        tpm_cleaninit(cleanupModelId, cleanupVarId, ss);//初始化清理模型
        resultCode = tpm_cleanstart(cleanupModelId);//开始清理进程
        if( resultCode != RTNORM )
                acutPrintf(_T("\n清理工作启动失败."));
                return;
        // Count errors by group type and subtype
        while ( ! done)
                resultCode = tpm_cleangroupnext(cleanupModelId);
                if ( resultCode == RTNORM )
                        if (tpm_cleancomplete(cleanupModelId) == TRUE )
                                done = 1;
                        else
                                type = tpm_cleangrouptype(cleanupModelId);
                                subtype = tpm_cleangroupsubtype(cleanupModelId);
                                tpm_cleangroupqty(cleanupModelId, &qty);
                        tpm_cleangroupmark(cleanupModelId);
//                        tpm_cleangroupfix(cleanupModelId);
                                if(qty>0)
                                        totalqty+=qty;
                        } // else
                } // if
                else
                        acedAlert(_T("\n没有要检查的对象"));
        } // while
    resultCode = tpm_cleanend(cleanupModelId);//完成清理进程并更新图形,修复被tpm_cleanerrorfix指定的要修复的错误
    resultCode = acedSSFree(ss);//最后释放选择集
        tpm_cleanfree(cleanupModelId);//释放清理模型
        tpm_varfree(cleanupVarId);//释放配置变量
        if(totalqty==0)
                str.Format(_T("\n恭喜!未找到任何错误。"));
        else
            str.Format(_T("重复线错误%d处"),totalqty);
        acedAlert(str);
GMT+8, 2026-11-3 20:19 , Processed in 0.503870 second(s), 31 queries , Gzip On.
