查看: 1471|回复: 2
[ARX程序]:求一个点
发表于 2002-5-28 04:04:55 | 显示全部楼层 |阅读模式
AcGeVector3d v,vzix;
AcGeVector3d v1(pt1-pt2);
AcGeVector3d v2(pt3-pt2);
v1.normalize();
v2.normalize();
v=v1+v2;//角平分线;
vzix.set(0,0,1);
double anglea,angleb,anglec;
anglea=v2.angleTo(v1,vzix);
AcGeLine3d vLine(pt2,v);
现在想求沿v方向、距pt2为len的点以及v与X轴的夹角,该怎么办呢?
谢谢!
已领礼包: 145个
发表于 2002-5-28 04:22:13 | 显示全部楼层
很多时候,不用向量,使用ARX全局函数,更方便
你试试:
void
acutPolar(
    const ads_point pt,
    ads_real angle,
    ads_real dist,
    ads_point result)
Include File
acutads.h
Finds a point by means of polar coordinates.
Sets result to the point that is at angle and dist from the initial point pt. The pt and result arguments are three-dimensional points. The angle is expressed in radians, measured from the X axis with the value increasing in the counterclockwise direction.
The acutPolar() function does not return a value.
发表于 2002-5-28 06:22:31 | 显示全部楼层
pt=pt2+v*len
GMT+8, 2026-11-2 21:40 , Processed in 0.407610 second(s), 36 queries , Gzip On.
