查看: 2304|回复: 24
[分享]:BENTLEY.Microstation.Geographics.v8.01.01.06
发表于 2003-6-27 08:27:32 | 显示全部楼层 |阅读模式
有需要的吗?
             MicroStation GeoGraphics is a key engineering product and forms
             the foundation for discipline specific applications. By configuring
             MicroStation V8.1 for a particular use, it significantly increases
             user productivity and offers an easy-to-use environment for geospatial
             users. Independent software developers can take advantage of high-level
             geospatial functionality to increase application performance and
             reduce development time.
             MicroStation GeoGraphics leverages the power of an open Oracle Spatial
             database storage system. By allowing users to post, query and extract
             spatial information into this open storage mechanism, geospatial data
             can be utilized far beyond the users' desktop. Geometry stored in
             Oracle Spatial is Open-GIS compliant and can be shared with other
             Open-GIS compliant applications. Oracle 8i and 9i Spatial are supported
             as well as Oracle 9i Locator. Oracle Locator is a feature of Oracle9i
             Standard and Enterprise Editions that provides spatial object type storage,
             indexing and operations to support a variety of location-based services (LBS)
             and 3rd party GIS solutions. Oracle Spatial is an option for Oracle9i
             Enterprise Edition that provides advanced spatial features to support
             high-end GIS and LBS solutions - further information can be found on:
             http://technet.oracle.com/products/spatial/content.html.
             REQUIREMENTS:
             This release requires MicroStation v8.01.01.09 or higher and Oracle v9i or
             Oracle v8.1.7i properly configured, if you want to play with Spatial data
license:
发表于 2003-6-27 11:36:24 | 显示全部楼层
一大堆的E文,不看了,可是license是要的.
 楼主| 发表于 2003-6-27 11:50:28 | 显示全部楼层
Bentley的产品英文居多,偶有的几个中文产品也是英文帮助,的确要求高了一些!
发表于 2003-7-3 17:08:03 | 显示全部楼层
这个许可是永久的吗?
 楼主| 发表于 2003-7-4 07:11:24 | 显示全部楼层
不知道,但对这个产品是可用的!
发表于 2003-7-4 14:34:35 | 显示全部楼层
有中文的最好了
 楼主| 发表于 2003-7-4 16:02:38 | 显示全部楼层
我没有!有中文的说明!
发表于 2003-7-4 16:40:44 | 显示全部楼层
请问高手"dell"是做什么用的?
 楼主| 发表于 2003-7-4 16:48:49 | 显示全部楼层
Dell不是著名的品牌电脑直销商吗?
发表于 2003-7-4 17:55:16 | 显示全部楼层
就是从你那个压缩文件打开以后有一个dell文件,是做什么用的?
 楼主| 发表于 2003-7-4 19:32:57 | 显示全部楼层
是指上面的压缩文件吗?我打开怎么没有?
庆祝图纸中心重新开张,正在上传到图纸中心,限时下载!因为本地附件只有200多K!!!
发表于 2003-7-5 10:55:48 | 显示全部楼层
 楼主| 发表于 2003-7-5 13:41:38 | 显示全部楼层
最初由 LIFUPING 发布
[B]给一个下栽地址:ftp://ftp2.bentley.com/dist/select/...g08010005en.exe [/B]
这个地址有问题!应该是
ftp://ftp2.bentley.com/dist/sele ... en/gg08010005en.exe
另外,最新的版本下载为:
ftp://ftp2.bentley.com/dist/sele ... en/gg08010106en.exe
发表于 2003-7-13 15:09:03 | 显示全部楼层
垃圾超人:请问你帖的这个license放在哪个目录下使用?
 楼主| 发表于 2003-7-13 16:14:28 | 显示全部楼层
扩展名为LIC的放在LICENSE中,扩展名为DLL的覆盖PROGRAM\GeoGraphics中的同名文件!
GMT+8, 2026-11-3 12:12 , Processed in 0.539481 second(s), 59 queries , Gzip On.
