查看: 2313|回复: 4
[编程申请]:自编的改层LISP
发表于 2009-10-18 10:48:55 | 显示全部楼层 |阅读模式
诸位大侠,自己编了一个改图层的lisp,目的是可以通过命令来修改物体的图层名,由于探索者的图层较长,也可以自动判断并进行修改,例如探索者的柱标注为COLU_DIM,则输入程序设定的默认CD即可自动将物体所在层改到了COLU_DIM,如果图层不存在,则新建图层。现在的问题是,程序不太稳定,有时候突然就不能用了,请诸位高手多多指教。
;CHANGE OBJIECT TO A LAYER
(defun c:gc (/ Layer_name Object_name Current_layer_name Temp_layer_name layer_color)
  (setvar "cmdecho" 0)
  (setq Layer_name (getstring "\nInput object layer[柱标注(CD)\\柱填充(CH)\\柱编号(CB)\\墙标注(WD)\\墙填充(WH)\\墙详图(WX)\\墙详图钢筋(WG)\\钢筋(G)\\表格文字(TT)]:"))
  (setq Object_name (ssget))
  (setq Current_layer_name (getvar "CLAYER"))
  ;The following is a description of the layer setup
  (setq Layer_name (cond ((= Layer_name "CD") "COLU_DIM")
                   ((= Layer_name "CH") "COLU_HATCH")
                   ((= Layer_name "CB") "COLU_NUM")
                   ((= Layer_name "WD") "WALL_DIM")
                   ((= Layer_name "WH") "WALL_HATCH")
                   ((= Layer_name "WX") "WALL_DE")
                   ((= Layer_name "WG") "WALL_DE_REIN")
                   ((= Layer_name "G") "REIN")
                   ((= Layer_name "TT") "TAB_TEXT")
;;;                   (t Layer_name)
  (setq Temp_layer_name (tblsearch "layer" Layer_name))
  (if (= Temp_layer_name nil)
    (progn
      (princ "\nhaven't this layer:")
      (setq layer_color (getint "\n Input the layer's layer_color:"))
      (COMMAND "-LAYER" "n" Layer_name "c" layer_color Layer_name "")
      (command "change" Object_name "" "p" "la" Layer_name "")
  (command "CLAYER" Current_layer_name)
  (prin1)
发表于 2009-10-18 15:21:55 | 显示全部楼层
顶
发表于 2009-10-18 19:54:37 | 显示全部楼层
将
改为
(setq Layer_name (strcase (getstring "\nInput object layer[柱标注(CD)\\柱填充(CH)\\柱编号(CB)\\墙标注(WD)\\墙填充(WH)\\墙详图(WX)\\墙详图钢筋(WG)\\钢筋(G)\\表格文字(TT)/<柱标注>]:")))
将
;;; (t Layer_name)
改为
(t "COLU_DIM")
 楼主| 发表于 2009-10-18 21:23:42 | 显示全部楼层
感谢gysjy
下午翻了一下午的书,已经有办法解决了,方法就同3楼的说法一样,不过我的程序稍微处理的麻烦一点,以下为修改好的源程序,再次感谢gysjy。
  (setq Layer_name (strcase Layer_name));将图层名称转换为大写字母
                         (T Layer_name)
    (progn
  (prin1)
发表于 2009-11-2 17:09:16 | 显示全部楼层
谢谢啊,我还不会编程啊
GMT+8, 2026-11-22 08:24 , Processed in 0.298078 second(s), 16 queries , Gzip On, File On.
