查看: 3512|回复: 0
【图形图像】Onone Perfect Software Collection Bundle (2013)
发表于 2013-4-6 01:58:23 | 显示全部楼层 |阅读模式
Onone Perfect Software Collection Bundle (2013) | 1GB
The onOne Software team has a passion for two things building simple yet powerful software and taking care of our customers. Our goal is to build tools that save time and money for everyone who loves photography, allowing them to create the images they want and get back to what they really love to do: go shoot!
Perfect Effects includes a complete library of professional photographic effects with a wide range, with universal application - development of Jack Davis and Kevin Kubota. Allows processing in batch mode, regardless of the format and image size, add watermark, apply multiple effects simultaneously, and many others The treatment can be performed in automatic and manual modes can be previewed.
Perfect B & W - offers photographers of all levels, the easiest way to create stunning black and white image.
Its powerful and intuitive tools give instant results as complete creative control over the process and methods of treatment.
Perfect Resize 7 - program is designed to increase the image size up to 1000% or more without visible artifacts observed in the standard scaling method used in Photoshop. It is possible to adjust the smoothing and sharpening, batch processing of images, presented a tool for splitting an image into smaller size for the printer of small size, improved templates for cropping and resizing.
Perfect Mask is the next generation of Mask Pro, the leading software for office and change the background on the images. The designer provides a set of 12 intuitive and convenient tool for masking objects. The technology used allows you to create unique paths (masks), consisting of a large number of control points and at the same time keep colors as accurate and clean the edges of various objects, from large to tiny and subtle details such as hair, smoke and glass.
下载地址:
游客,如果您要查看本帖隐藏内容请回复
GMT+8, 2026-11-22 07:56 , Processed in 0.556193 second(s), 12 queries , Gzip On, File On.
