查看: 2687|回复: 0
[图形图像] Adobe After Effects CS6 11.0.0.378 with Crack+Update 11.0.2.12 | 1.1GB
发表于 2013-4-11 22:59:12 | 显示全部楼层 |阅读模式
Adobe After Effects - Software company Adobe Systems for video editing and dynamic images, the development of tracks (compositing), animation, and create different effects. Widely used in the treatment of the footage (color correction, post-production), the creation of commercials, music videos, in the production of animation (for TV and web), titles for feature and television films, as well as a number of other tasks that require the use of digital visual effects.
name comes from the effect known as "the resistance (inertia) of the visual sensation," this mechanism uses the sensory memory of the retina, which can store visual information in a short period of time. Due to the extensive library of plug-ins developed by third parties, AfterEffects is also used in printing and graphic design, editing of static graphic images (photos, images, computer-generated, etc.)
MD5:
* ad08aea10ff796bed615dc912aeb8fa7 AfterEffects_11_LS7.7z
d0d3e9d493ef06b20281c2273b5c4d8d * AfterEffects_11_LS7.exe
Adding support for GPU:
Go to "% ProgramW6432% \ Adobe \ Adobe After Effects CS6 \ Support Files . "
We are looking for a file raytracer_supported_cards.txt .
tracker, finishes its modelku and save the file.
Run AE (fifth screen).
The procedure for treatment (one choice)
dll:
Set trial'nuyu version.
Run AE. Press the "Start Trial". Close AE.
Copy the replacement "amtlib.dll" from the folder "Crack \ Dll" to the folder "% ProgramW6432% \ Adobe \ Adobe After Effects CS6 \ Support Files"
Pre recommended to backup the original "amtlib.dll"
Keygen:
Turning off the Internet.
Start the installation, choose "Install".
Run keygen.exe ("Crack \ Keygen \ Keygen-CORE") and generate a serial number for AE CS5.5. Copy it in the Setup window (do not close keygen!).
He climbs a connection error - click "connect later."
After installation run the AE.
confirm that we have a problem with the internet - click "Having trouble connecting to the internet"
Click "Offline Activation" => "Generate Request Code".
Start the XF-mccs6.exe ("Crack \ Keygen \ Keygen-X-FORCE").
previously generated serial fills in "Serial".
In the "Request" insert "Request Code" from the window "Offline Activation".
Click "Generate ".
The resulting activation code (field "Activation") copy and paste in the "Response Code" in the "Offline Activation" and click "Activate".
Now put this in the hosts ("% windir% \ System32 \ drivers \ etc"):
"Lmlicenses.wip4.adobe.com 127.0.0.1
127.0.0.1 lm.licenses.adobe.com"
Either run disable_activation.cmd ("Crack \ Keygen \ Keygen-X-FORCE").
Include the Internet and fully use AE.
System Requirements:
Intel ® Core ™ 2 Duo or AMD Phenom ® II processor; 64-bit support required
Microsoft ® Windows ® 7 with Service Pack 1 (64 bit)
4GB of RAM (8GB recommended)
3GB of available hard-disk space; additional free space required during installation (cannot install on removable flash storage devices)
Additional disk space for disk cache (10GB recommended)
1280x900 display
OpenGL 2.0-capable system
DVD-ROM drive for installation from DVD media
QuickTime 7.6.6 software required for QuickTime features
Optional: Adobe-certified GPU card for GPU-accelerated ray-traced 3D renderer *
This software will not operate without activation. Broadband Internet connection and registration are required for software activation, validation of subscriptions, and access to online services. † Phone activation is not available.
登录/注册后可看大图
Download:
http://rapidgator.net/file/7df6bf818dffdc85a21c099029cca696/A.DO_After_Effects_CS6_new.update.rar.html
Mirror 1:
http://extabit.com/file/278uh1x4ddten/A.DO_After_Effects_CS6_new.update.rar
GMT+8, 2026-11-24 23:24 , Processed in 0.359947 second(s), 8 queries , Gzip On, File On.
