楼主: Free-Lancer
[他山之石] 一些随手写的小工具(慢慢更新)
 火   [复制链接]
 楼主| 发表于 2013-5-2 09:22:29 | 显示全部楼层
8 标注删除
[pcode=lisp,true](defun c:DimErase ()
  (prompt "\n请选取要删除的尺寸标注<退出>:")
  (vl-catch-all-apply
    (function (lambda (/ ss)
                (if (setq ss (ssget '((0 . "DIMENSION"))))
                  (command "._erase" ss "")
  (princ)
)[/pcode]
评分
参与人数 1D豆 +10 贡献 +1 收起 理由
XDSoft + 10 + 1 资料分享奖!
查看全部评分
 楼主| 发表于 2013-5-2 09:24:12 | 显示全部楼层
9 标注文字翻转
[pcode=lisp,true](defun c:DIMTxtRev ()
  (command ".undo" "g")
  (vl-catch-all-apply
    (function
      (lambda (/ ss ang ssl e lst)
        (while (progn
                 (prompt "\n请选取要翻转文字方向的尺寸标注 <退出>: ")
          (setq ssl (sslength ss))
          (while (> ssl 0)
            (setq e   (ssname ss (setq ssl (1- ssl)))
                  lst (entget e)
                  ang (cdr (assoc 51 lst))
            (entmod (subst (cons 51
                                 (if (and
                                       (>= pi ang)
                                       (> ang 0)
                                   0
                                   pi
                           (assoc 51 lst)
                           lst
  (command "undo" "end")
  (princ)
)[/pcode]
 楼主| 发表于 2013-5-2 09:29:54 | 显示全部楼层
10 修改填充角度[pcode=lisp,true];;修改Hatch的角度
(defun c:ModHang (/  e el an)
  (if (setq an (getangle "\n指定角度: "))
    (progn
      (setq el (entget e))
      (entdel e)
      (entmake (subst (cons 52 an)
                      (assoc 52 el)
                      el
  (princ)
)[/pcode]
已领礼包: 86个
发表于 2013-5-2 15:49:18 | 显示全部楼层
感谢楼主分享
 楼主| 发表于 2013-5-2 16:58:32 | 显示全部楼层
11 局部重生成
[pcode=lisp,true](defun c:RegenObj (/ thisdrawing)
  (setq thisdrawing (vla-get-activedocument (vlax-get-acad-object)))
   (vl-catch-all-apply
    (function
      (lambda (/ ss)
        (if (setq ss (ssget))
          (progn
            (vlax-for obj (vla-get-activeselectionset thisdrawing)
              (vla-update obj)
  (princ)
)[/pcode]
 楼主| 发表于 2013-5-2 17:00:09 | 显示全部楼层
12 临时隐藏[pcode=lisp,true](defun c:TmpHide ()
  (vl-catch-all-apply
    (function
      (lambda (/ ss sl n)
          (progn
            (setq sl (sslength ss)
                  n  -1
            (while (< n (1- sl))
              (redraw (ssname ss (setq n (1+ n))) 2)
  (princ)
)[/pcode]
 楼主| 发表于 2013-5-2 17:02:41 | 显示全部楼层
13 循环修改文字示例,可以是块中的文字、属性、多行文字[pcode=lisp,true] ;|
(defun c:ChgTxt ()
  (vl-catch-all-apply
    (function
      (lambda (/ e vla-object)
        (while (and (setq e (nentsel "\n选择文字<退出>: "))
                    (setq vla-object
                           (vlax-ename->vla-object (car e))
                    (member (vla-get-objectname vla-object)
                            '("AcDbText" "AcDbAttribute" "AcDbMtext")
          (princ (strcat "\n原文字: "
                         (vla-get-textstring vla-object)
          (vla-put-textstring
            vla-object
            (getstring "\n新文字: ")
          (if (> (length e) 2)
            (vla-update
              (vlax-ename->vla-object (last (last e)))
  (princ)
)[/pcode]
回复 支持 0 反对 1
 楼主| 发表于 2013-5-2 17:05:16 | 显示全部楼层
14 修改点选段多义线宽度[pcode=lisp,true](defun c:Plw (/ ss e e0 p w pam p1 p2)
  (while (and (setq e (entsel "\n选择多线: "))
              (setq e0 (car e)
                    p  (cadr e)
              (progn
                (setq ss (ssadd))
                (ssadd e0 ss)
                (sssetfirst ss ss)
                T
              (if
                (setq
                  w (getreal
                      (strcat "\n输入宽度:<"
                              (vl-princ-to-string (getvar "plinewid"))
                 (setvar "plinewid" w)
                 (setq w (getvar "plinewid"))
    (setq ss (ssadd))
    (ssadd e0 ss)
    (sssetfirst ss ss)
    (setq pam (vlax-curve-getparamatpoint
                e0
                (vlax-curve-getclosestpointto e0 p)
          p1  (fix pam)
          p2  (1+ pam)
    (vla-setwidth (vlax-ename->vla-object e0) p1 w w)
  (sssetfirst ss nil)
  (princ)
)[/pcode]
 楼主| 发表于 2013-5-2 17:13:54 | 显示全部楼层
15 对齐标注转转角标注[sell=5][pcode=lisp,true](defun c:datol (/ ms doc)
  (setq        doc (vla-get-activedocument (vlax-get-acad-object))
        ms  (vla-get-modelspace doc)
  (vla-startundomark doc)
  (vl-catch-all-apply
    '(lambda (/ ss p1 p2 an dl)
       (if (setq ss (ssget "x" '((0 . "dimension"))))
         (progn
           (vlax-for obj (vla-get-activeselectionset doc)
             (if (= (vla-get-objectname obj) "AcDbAlignedDimension")
               (progn
                 (setq p1 (vla-get-ExtLine1Point obj)
                       p2 (vla-get-extline2point obj)
                       an (angle (safearray-value (variant-value p1))
                                 (safearray-value (variant-value p2))
                 (setq dl
                        (vla-adddimrotated
                          ms
                          p1
                          p2
                          (vlax-3d-point
                            (cdr
                              (assoc 10 (entget (vlax-vla-object->ename obj)))
                          an
                 (vla-put-textoverride dl (vla-get-textoverride obj))
                 (vla-put-textrotation dl (vla-get-textrotation obj))
                 (vla-put-textprefix dl (vla-get-textprefix obj))
                 (vla-put-textsuffix dl (vla-get-textsuffix obj))
                 (vla-put-textposition dl (vla-get-textposition obj))
                 (vla-delete obj)
  (vla-endundomark doc)
  (princ)
)[/pcode][/sell]
尺寸原的特性都变了,如图层,颜色。最好是用户选择哪些尺寸要转化,而不是全部  发表于 2013-6-14 19:33
 楼主| 发表于 2013-5-2 17:32:30 | 显示全部楼层
16 简单的双向Offset
[pcode=lisp,true](defun c:Rd ()
   (vl-catch-all-apply
    (function
      (lambda (/ d)
        (setq d (getdist "\nInput Road Width = "))
        (while  (ssget)
          (vlax-for obj        (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object)))
            (vla-offset obj d)
            (vla-offset obj (- d))
  (princ)
)[/pcode]
这个不是双向offset  发表于 2013-7-4 23:21
 楼主| 发表于 2013-5-2 17:44:45 | 显示全部楼层
18 用引线和字段标准Pline面积及周长[sell=5][pcode=lisp,true](defun C:FA (/ acsp adoc cpt elist en ent fld lead_obj lpt mtx oid osm)
  (vl-load-com)
  (or adoc
      (setq adoc
  (if (and
        (= (getvar "tilemode") 0)
        (= (getvar "cvport") 1)
    (setq acsp (vla-get-paperspace adoc))
    (setq acsp (vla-get-modelspace adoc))
  (setq osm (getvar "osmode"))
  (setvar "osmode" 0)
  (while
    (setq ent (entsel "\nSelect pline or hit Enter to exit: "))
     (setq en (car ent))
     (if (wcmatch (cdr (assoc 0 (setq elist (entget en))))
                  "*POLYLINE"
       (progn
         (setq cpt (trans (vlax-curve-getclosestpointto en (cadr ent)) 1 0)
               lpt (trans (getpoint cpt "\nPick the ending point of leader: ")
                          1
                          0
         (setq oID (vla-get-objectid (vlax-ename->vla-object en)))
         (setq fld
                (strcat
                  (strcat "Area = "
                          "%<\\AcObjProp Object(%<\\_ObjId "
                          (itoa oID)
                          ">%).Area \\f \"%lu2%pr2\">%"
                          "\\P"
                  (strcat "Perimeter = "
                          (itoa oID)
                          ">%).Length \\f \"%lu2%pr2\">%"
         (setq mtx (vlax-invoke
                     acsp 'AddMText lpt        0.0 fld)
         (vlax-put mtx
                   'AttachmentPoint
                   (cond ((> (car cpt) (car lpt))
                          6
                         ((< (car cpt) (car lpt))
                          4
                         (T 4)
         (vlax-put mtx 'Height (getvar "textsize"))
         (setq lead_obj        (vlax-invoke
                          acsp
                          'Addleader
                          (apply 'append (list cpt lpt))
                          mtx
                          acLineWithArrow
         (vlax-put lead_obj 'VerticalTextPosition 0) ;1
  (setvar "osmode" osm)
  (princ)
(princ "\n Start command with FA ...")
(princ)[/pcode][/sell]
 楼主| 发表于 2013-5-2 17:48:34 | 显示全部楼层
18 统一改字体[pcode=lisp,true](defun c:stgb (/ table)
  (defun table (s / d r)
    (while (setq d (tblnext s (null d)))
      (setq r (cons (cdr (assoc 2 d)) r))
    (reverse r)
  (setvar "cmdecho" 0)
  (foreach x (table "style")
    (vl-cmdf ".style" x        "gbenor,gbcbig"        "0.00" "1.0" "0.0" "n" "n")
  (princ)
)[/pcode]
Free-Lancer :“18 统一改字体”的程序好像是双向偏移吧,并非是改字体!  发表于 2013-7-4 23:13
 楼主| 发表于 2013-5-2 17:54:02 | 显示全部楼层
19 简单的文字排版[pcode=lisp,true](defun c:tt (/ ss ssl i e el ll d hi p vh vx vy str)
  (if (setq ss (ssget '((0 . "text"))))
    (progn
            i        -1
      (repeat ssl
        (setq e         (ssname ss (setq i (1+ i)))
              el (entget e)
        (if ll
          (setq ll (cons el ll))
          (setq ll (list el))
      (setq
        ll (vl-sort ll
                    '(lambda (e1 e2)
                       (> (caddr (assoc 10 e1)) (caddr (assoc 10 e2)))
      (setq p  (cdr (assoc 10 (car ll)))
            vx (car p)
            vy (cadr p)
            i  1
      (setq d (getdist p "\n行距: "))
      (setq hi (getdist        p
                        (strcat        "\n字高<"
                                (rtos (cdr (assoc 40 (car ll)))
                                      2
                                      2
      (if hi
        (setq vh (cons 40 hi))
      (foreach x ll
        (if vh
          (entmod (subst vh (assoc 40 x) x))
        (setq str (vl-string-left-trim " " (cdr (assoc 1 x))))
        (if (wcmatch str "[0-9]*")
          (setq        str (vl-string-left-trim "1234567890" str)
                el  (subst (cons 1 (strcat (itoa i) str)) (assoc 1 x) x)
                i (1+ i)
          (setq el x)
        (setq el (subst (list 10 vx vy 0.) (assoc 10 x) el))
        (entmod el)
        (if d
          (setq vy (- vy d))
  (princ)
)[/pcode]
已领礼包: 6468个
发表于 2013-5-3 01:58:02 | 显示全部楼层
谢谢楼主放出这么多好程式。
已领礼包: 5800个
发表于 2013-5-3 08:51:40 | 显示全部楼层
楼主辛苦!谢谢楼主的好程序!
GMT+8, 2026-11-6 16:45 , Processed in 0.489421 second(s), 56 queries , Gzip On.
