查看: 2506|回复: 6
[分享] 模型空间到图纸空间的转换矩阵函数
发表于 2013-5-5 01:17:16 | 显示全部楼层 |阅读模式
[sell=5]
[pcode=cpp,true]//////////////////////////////////////////////////////////////////////////
void ms2ps( AcDbViewport*pVp, AcGeMatrix3d &resultMat)
        // first get all the data
        AcGeVector3d viewDirection = pVp->viewDirection();
        AcGePoint2d centre2d = pVp->viewCenter();
        AcGePoint3d viewCenter = AcGePoint3d( centre2d.x, centre2d.y, 0);
        AcGePoint3d viewTarget = pVp->viewTarget ();
        double twistAngle = -pVp->twistAngle();
        AcGePoint3d centerPoint = pVp->centerPoint();
        double viewHeight = pVp->viewHeight();
        double height = pVp->height();
        double width = pVp->width();
        double scaling = viewHeight / height;
        double lensLength = pVp->lensLength();
        // prepare the transformation
        AcGeVector3d xAxis, yAxis, zAxis;
        zAxis = viewDirection.normal();
        xAxis = AcGeVector3d::kZAxis.crossProduct( viewDirection );
        if( !xAxis.isZeroLength() ) {
                xAxis.normalize();
                yAxis = zAxis.crossProduct( xAxis );
        } else if( zAxis.z < 0 ) {
                xAxis = -AcGeVector3d::kXAxis;
                yAxis = AcGeVector3d::kYAxis;
                zAxis = -AcGeVector3d::kZAxis;
        } else {
                xAxis = AcGeVector3d::kXAxis;
                zAxis = AcGeVector3d::kZAxis;
        AcGeMatrix3d dcs2wcs; // display coordinate system (DCS) to world coordinate system (WCS)
        AcGeMatrix3d ps2Dcs; // paperspace to DCS
        // First initialise with a transformation to centerPoint
        ps2Dcs = AcGeMatrix3d::translation( AcGePoint3d::kOrigin - centerPoint);
        // then scale for the view
        ps2Dcs = ps2Dcs * AcGeMatrix3d::scaling( scaling, centerPoint);
        // then adjust to the viewCenter
        dcs2wcs = AcGeMatrix3d::translation( viewCenter - AcGePoint3d::kOrigin);
        // Then transform for the view direction
        AcGeMatrix3d matCoords;
        matCoords.setCoordSystem( AcGePoint3d::kOrigin, xAxis, yAxis, zAxis);
        dcs2wcs = matCoords * dcs2wcs;
        // Then adjust for the viewTarget
        dcs2wcs = AcGeMatrix3d::translation( viewTarget - AcGePoint3d::kOrigin) * dcs2wcs;
        // Then the twist angle
        dcs2wcs = AcGeMatrix3d::rotation(twistAngle, zAxis, viewTarget ) *dcs2wcs;
        AcGeMatrix3d perspMat;
        if( pVp->isPerspectiveOn())
                // we do special perspective handling
                double viewSize = viewHeight;
                double aspectRatio = width / height;
                double adjustFactor = 1.0 / 42.0;
                double adjustedLensLength = viewSize * lensLength * sqrt ( 1.0 +
                        aspectRatio * aspectRatio ) * adjustFactor;
                double eyeDistance = viewDirection.length();
                double lensDistance = eyeDistance - adjustedLensLength;
                double ed = eyeDistance;
                double ll = adjustedLensLength;
                double l = lensDistance;
                perspMat.entry[2][2] = (ll - l ) / ll;
                perspMat.entry[2][3] = l * ( ed - ll ) / ll;
                perspMat.entry[3][2] = -1.0 / ll;
                perspMat.entry[3][3] = ed / ll;
        resultMat = ps2Dcs.inverse() * perspMat * dcs2wcs.inverse();
void ps2ms ( AcDbViewport*pVp, AcGeMatrix3d &resultMat )
        // Keep life simple, just invert the other way
        AcGeMatrix3d mat;
        ms2ps( pVp, mat );
        resultMat = mat.inverse();
        return;
[/pcode]
[/sell]
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 技术引导讨论和指点奖!
查看全部评分
发表于 2013-5-5 09:13:16 | 显示全部楼层
支持!希望后续能够看到LZ更精彩的贴!
发表于 2014-1-3 05:32:37 | 显示全部楼层
看不懂的代码
发表于 2014-1-3 05:34:30 | 显示全部楼层
这个在lisp中可以引用吗?怎么用呢?
发表于 2014-1-3 18:06:40 来自手机 | 显示全部楼层
学习学习!
发表于 2017-10-31 19:09:44 来自手机 | 显示全部楼层
这个在lisp中可以引用
发表于 2018-11-16 08:55:13 | 显示全部楼层
上当,不是lisp的,看不懂。
GMT+8, 2026-11-22 11:02 , Processed in 0.346684 second(s), 20 queries , Gzip On, File On.
