查看: 2804|回复: 0
[飞鸟集] 一个通用的更改块名的程序!
发表于 2013-5-7 23:29:22 | 显示全部楼层 |阅读模式
一个更改块名的程序.能针对匿名块!
[pcode=lisp,true]
(prompt "在命令行中输入命令: CCC!")
;;;测试程序
(defun C:ccc (/ *APP *DOC EntNam NewNam)
  (vl-load-com)
  (setq *APP (vlax-get-acad-object))
  (setq *DOC (vla-get-activeDocument *APP))
  (if (setq EntNam (car (entsel "\n请选择块: ")))
    (if (setq NewNam (getstring "\n请输入新块名<字符规范,不要重名>: "))
      (change-block-name EntNam NewNam)
      (princ "\n你没有输入新块名!")
    (princ "\n你没有选择物体!")
  (princ)
;;;改块名程序
(defun change-block-name (EntNam NewNam / obj blocks BlkNam block)
  (setq obj (vlax-ename->vla-object EntNam))
  (setq blocks (vla-get-blocks *DOC))
  (if (=(vla-get-objectname obj) "AcDbBlockReference")
    (if (tblsearch "block" NewNam)
      (princ "\n和已有块名重复!")
      (progn
        (setq BlkNam (vla-get-name obj))
        (setq block  (vla-item blocks BlkNam))
        (vla-put-name block NewNam)
        (if (= (substr BlkNam 1 2) "*U")
          (progn
            (princ "\n这是一个匿名块.")
            (vla-auditinfo *Doc :vlax-true)
        (princ "\n块名已经更改成\"")
        (princ NewNam)
        (princ "\"")
    (princ "\n所选物体不是块!")
[/pcode]
评分
参与人数 1D豆 +1 收起 理由
炫翔 + 1 很给力!经验;技术要点;资料分享奖!
查看全部评分
GMT+8, 2026-11-22 08:00 , Processed in 0.156674 second(s), 11 queries , Gzip On, File On.
