查看: 5331|回复: 10
[每日一码] 模型布局文本窗口颜色修改 V1.1
发表于 2013-5-11 23:02:38 | 显示全部楼层 |阅读模式
更改
模型窗口背景颜色
模型十字光标颜色
命令行背景颜色
命令行文字颜色
布局窗口背景颜色
布局十字光标颜色
DisplayColorProperties.LSP By xshrimp
文件名称:displaycolorpropertiesv1.1.lsp
下载次数:153  文件大小:5.63 KB
[pcode=lisp,true];|
更改
模型窗口背景颜色
模型十字光标颜色
命令行背景颜色
命令行文字颜色
布局窗口背景颜色
布局十字光标颜色
By xshrimp
网络U盘: shlisp.ys168.cm
E-mail:  xshrimp@163.com
v1.0 初步完成全部功能.
v1.1 增加全部默认按钮.常用的黑白按钮.
(defun c:DCP( / aci col dclid dclname dclstr dd display filen i tempname vvla)
(defun gps->aci2ole (aci / col)
  (setq col (vla-get-truecolor (vla-get-ActiveLayer(vla-get-ActiveDocument(vlax-get-acad-object)))))
  (vla-put-ColorIndex col aci)
  (vlax-variant-value (vlax-make-variant (+ (* (vla-get-blue  col) 65536)
                                            (* (vla-get-green col) 256)
                                               (vla-get-red   col)
                                          ) vlax-vblong
(defun actdefaultbutton()
  (setq varBlack (vlax-Make-Variant 0                 vlax-vbLong))
  (setq varWhite (vlax-Make-Variant 16777215         vlax-vbLong))
  (vla-put-graphicswinmodelbackgrndcolor DISPLAY varBlack)
  (vla-Put-ModelCrosshairColor DISPLAY varWhite)
  (vla-put-graphicswinlayoutbackgrndcolor DISPLAY varWhite)
  (vla-Put-LayoutCrosshairColor DISPLAY varBlack)
  (vla-put-TextWinBackgrndColor DISPLAY varWhite)
  (vla-put-TextWinTextColor DISPLAY varBlack)
(defun actradiobutton($value)
  (setq #changebackradio# $value)
  (cond
     ((= $value "a")(setvar "TILEMODE" 1)(setq vvla 'vla-put-graphicswinmodelbackgrndcolor) )
     ((= $value "b")(setvar "TILEMODE" 1)(setq vvla 'vla-Put-ModelCrosshairColor) )
     ((= $value "c")(setvar "TILEMODE" 0)(setq vvla 'vla-put-graphicswinlayoutbackgrndcolor) )
     ((= $value "d")(setvar "TILEMODE" 0)(setq vvla 'vla-Put-LayoutCrosshairColor) )
     ((= $value "e")(setvar "TILEMODE" 1)(setq vvla 'vla-put-TextWinBackgrndColor))
     ((= $value "f")(setvar "TILEMODE" 1)(setq vvla 'vla-put-TextWinTextColor))
(setq DISPLAY (vla-get-display(vla-get-preferences(vlax-get-acad-object))))
(setq dclstr
"mimg:image_button {aspect_ratio = 0.9 ;fixed_height = true ;
    fixed_width = true ; width = 2.8 ;horizontal_margin = none ;
    vertical_margin = none ;
mmimg:image {
    aspect_ratio = 0.9 ;    color = -15 ;
    fixed_height = true ;    fixed_width = true ;
    width = 2.8 ;    horizontal_margin = none ;
rbt:radio_button{horizontal_margin=none;vertical_margin=none;fixed_width = true ; width = 36;}\n
sss:dialog {label = \"颜色选项修改 V1.0\" ;
    :text {
        label = \"AutoCAD 颜色索引 (ACI):\" ;
    :column {
        :column {
(setq i 18)
(repeat 5
    (setq j i)
    (setq dclstr (strcat dclstr ":row{\n"))
    (repeat 24
      (setq dclstr (strcat dclstr ":mimg{color=" (itoa j) ";key=\""(itoa j)"\";}\n" ))
      (setq j (+ 10 j))
    (setq i (- i 2))
    (setq dclstr (strcat dclstr  "}\n"))
(setq dclstr (strcat dclstr  "}}:spacer { } :spacer {} :column {\n"))
(setq i 11)
(repeat 5
    (setq j i)
    (repeat 24
      (setq j (+ 10 j))
    (setq i (+ i 2))
(setq dclstr (strcat dclstr  "}:spacer { } :row { :column {\n:row {\n"))
(setq j 1)
(repeat 9
      (setq dclstr (strcat dclstr ":mimg{color=" (itoa j) ";width = 3;key=\""(itoa j)"\";}\n" ))
      (setq j (1+ j))
(setq dclstr (strcat dclstr  "}:row {\n"))
(setq j 250)
(repeat 6
    (setq j (1+ j))
(setq dclstr (strcat dclstr " :mmimg {width = 3;}\n" ))
(setq dclstr (strcat dclstr ":mimg{color=7;width = 3;key=\"7a\";}\n" ))
(setq dclstr (strcat dclstr ":mimg{color=0;width = 3;key=\"0\";}\n" ))
    "}:edit_box {key=\"box\";edit_width = 15 ;fixed_width = true ;label = \"颜色\" ;}} \n"
     ":boxed_radio_column{key=\"radio\";\n"
           " :rbt {key=\"a\";  label = \"模型窗口背景颜色\" ;}\n"
           " :rbt {key=\"b\";label = \"模型十字光标颜色\" ;  }\n"
           " :rbt {key=\"e\";label = \"命令行背景颜色\" ;  }\n"
           " :rbt {key=\"f\";label = \"命令行文字颜色\" ;}\n"
           " :rbt {key=\"c\";label = \"布局窗口背景颜色\" ;    }\n"
           " :rbt {key=\"d\";label = \"布局十字光标颜色\" ;   }   \n"
           ":column {
    : row {
        fixed_width = true;
        alignment = centered;
        :button {key=\"default\";label=\"全部默认\";}
        :spacer {width = 2; }
        :button {label=\"    取消    \";is_cancel=true;}
(setq dclname
(cond
((setq tempname (vl-filename-mktemp "gps-dcl-tmp.dcl") filen (open tempname "w"))
(princ dclstr filen)
(close filen)
tempname
(setq dclid (load_dialog dclname))
(if (not (new_dialog "sss" dclid)) (progn (alert "dcl对话框加载失败.")(exit)))
(setq i 0)
(repeat 256
(action_tile (itoa i)  "(set_tile \"box\" $key)((eval vvla) DISPLAY (gps->aci2ole (atoi $key)))")
(setq i (1+ i))
(if (null #changebackradio#)(setq #changebackradio# "a"))
(actradiobutton #changebackradio#)
(set_tile #changebackradio# "1")
(action_tile "7a"  "(set_tile \"box\" \"7\")((eval vvla) DISPLAY (gps->aci2ole 7))")
(action_tile "radio" "(actradiobutton $value)")
(action_tile "default" "(actdefaultbutton)")
(action_tile "cancel" "(done_dialog 0)")
(action_tile "help" "(alert \"模型,布局及命令行背景光标颜色修改!\n xshrimp 写于 2010.10\")")
(setq dd (start_dialog))
(unload_dialog dclid)
(vl-file-delete dclname)
(princ "启动命令: DCP\n")
(princ)[/pcode]
评分
参与人数 3D豆 +20 贡献 +1 收起 理由
/db_自贡黄明儒_ + 5 很给力!经验;技术要点;资料分享奖!
ScmTools + 5 好主题奖!
XDSoft + 10 + 1 很给力!经验;技术要点;资料分享奖!
查看全部评分
本帖被以下淘专辑推荐:
发表于 2013-5-13 09:22:29 | 显示全部楼层
LISP能做成这种效果真的不错!
发表于 2013-5-30 13:55:08 | 显示全部楼层
谢谢楼主的分享!收藏备用。
发表于 2013-5-31 18:56:47 | 显示全部楼层
好源码!好源码!好源码呀
发表于 2013-7-31 21:30:34 | 显示全部楼层
功能强大!!{:soso_e179:}
发表于 2014-3-19 17:15:04 | 显示全部楼层
太厉害了   {:soso_e179:}
发表于 2015-2-15 09:54:28 | 显示全部楼层
LISP能做成这种效果真的不错;P
发表于 2016-1-22 02:48:23 | 显示全部楼层
界面看着真舒服
发表于 2016-1-25 09:11:12 | 显示全部楼层
非常简便实用的程序,新颖直观。
既然是V1.1版,那么代码中的“颜色选项修改 V1.0“就改成“颜色选项修改 V1.1“吧。
发表于 2016-10-2 16:16:53 | 显示全部楼层
非常好程序!!!
发表于 2021-10-15 05:47:56 | 显示全部楼层
感谢分享模型布局文本窗口颜色修改 V1.1
GMT+8, 2026-11-22 07:55 , Processed in 0.416986 second(s), 32 queries , Gzip On, File On.
