查看: 5510|回复: 10
[分享] 初学ARX写的第一个程序,让 LISP也能使用关键字的SSget
发表于 2013-5-12 18:09:14 | 显示全部楼层 |阅读模式
一直以来都是使用LISP编写一些简单的程序自用,但发现LISP的SSGET用得实在太不爽了,不能自定提示和关键字。期间也试过用LISP来模仿但都达不到自己想要的效果,而是学习ARX,但发现C++学起来实在太难了,还好来到这个论坛,找到很多例子,特别是高飞大哥的源码,而是照葫芦画瓢终于写好了,帖出来希望大家能指正下。
[pcode=cpp,true]static int StampingDieSSGet(struct resbuf *rb);
static int StampingDieSSFree(struct resbuf *rb);
resbuf* ssCallback(const TCHAR* kword);
static bool Getlispresbuf(struct resbuf        *lisprb,struct resbuf **rb);
TCHAR *PfunctionName;
const TCHAR *outkword;
        if (lisprb->restype != RTLB)
                return false;
        lisprb = lisprb->rbnext;
        struct resbuf *rb1 =NULL;
        struct resbuf *rb2 = NULL;
        do
                struct resbuf *temrb = acutNewRb(abs(lisprb->restype));
                temrb->restype = lisprb->restype;
                temrb->resval = lisprb->resval;
                if (rb1 == NULL)
                        rb1 = rb2 = temrb;
                else
                        rb2->rbnext = temrb;
                        rb2 = rb2->rbnext;
        } while (lisprb != NULL && lisprb->restype != RTLE);
        *rb = rb1;
        return true;
        resbuf *result = NULL;
        resbuf *rb_in = NULL;
        outkword  = kword;
        if(PfunctionName != NULL)
                rb_in = acutBuildList(RTSTR,PfunctionName,RTSTR,kword,RTNONE);
                int ret = acedInvoke(rb_in,&result);
        else
                throw kword;
        return result;
        resbuf* (*oldFunc)(const ACHAR*);
        acedSSGetKwordCallbackPtr(&oldFunc);
        outkword = NULL;
        PfunctionName = NULL;
        TCHAR *promptStr=NULL;
        ACHAR *kwordStr=NULL;
        struct resbuf *filterrb = NULL;
        //不带参数运行提示字符串
        if(rb == NULL)
                promptStr = _T("选择对象: ");
                goto StartSSget;
        //提示字符串
        if(rb->restype == RTSTR)
                promptStr = rb->resval.rstring;
        else if(rb->restype == RTLB)
                Getlispresbuf(rb,&filterrb);
                goto StartSSget;
        else
                acutPrintf(_T("\n错误: 参数错误"));
                return RTERROR;
        rb = rb->rbnext;
        if(rb == NULL)
                goto StartSSget;
        //关键字
        if (rb->restype == RTSTR)
                kwordStr = rb->resval.rstring;
                rb = rb->rbnext;
                if(rb == NULL)
                        goto StartSSget;
                //回调函数
                        PfunctionName = rb->resval.rstring;
                        rb = rb->rbnext;
                        if(rb == NULL)
                                goto StartSSget;
                        //过虑表
                        else if (rb->restype == RTLB)
                        else
                                acutPrintf(_T("\n错误: 第四个参数过虑表"));
                                return RTERROR;
                //过虑表
                        goto StartSSget;
                else
                        acutPrintf(_T("\n错误: 第三个参数为回调函数字符串或过虑表"));
                        return RTERROR;
        //过虑表
                goto StartSSget;
        else
                acutPrintf(_T("\n错误: 第二参数为关键字或过虑表"));
                return RTERROR;
StartSSget:
        TCHAR *prorptlist[] = {promptStr,_T("删除对象: ")};
        ads_name ss;
        try
                if(kwordStr != NULL)
                        acedSSSetKwordCallbackPtr(ssCallback);
                        if (RTNORM == acedSSGet(_T("_:$:K"),prorptlist,kwordStr,filterrb,ss))
                                acedRetName(ss,RTPICKS);
                                //acedSSFree(ss);
                else
                        if (RTNORM == acedSSGet(_T("_:$"),prorptlist,NULL,filterrb,ss))
                                //acedSSFree(ss);
                acedSSSetKwordCallbackPtr(*oldFunc);
        catch(...)
                if(outkword != NULL)
                        acedRetStr(outkword);
                else
                        acedRetNil();
                acedSSFree(ss);
        return 0;
        if(rb == NULL)
                acutPrintf(_T("\n错误: 参数为空"));
                return RTERROR;
        if(rb->restype != RTPICKS)
                acutPrintf(_T("\n错误: 参数类型错误."));
                return RTERROR;
        ads_name ss ;
        ads_name_set(rb->resval.rlname,ss);
        acedSSFree(ss);
        acedRetT();
        return RTNORM;
};[/pcode]
评分
参与人数 2D豆 +6 收起 理由
ScmTools + 2 技术讨论奖!
XDSoft + 4 出题引导交流奖!
查看全部评分
发表于 2013-5-12 18:23:05 | 显示全部楼层
能编译成个ARX贴论坛吗? 让大家用LISP调用测试测试。
发表于 2013-5-12 18:35:21 | 显示全部楼层
希望LZ增加一个完整的测试例子
 楼主| 发表于 2013-5-12 22:21:24 | 显示全部楼层
ScmTools 发表于 2013-5-12 18:35
希望LZ增加一个完整的测试例子
已帖:http://bbs.xdcad.net/thread-668035-1-1.html
发表于 2013-5-12 23:02:40 | 显示全部楼层
比我当初自己写的第一个ARX程序厉害多了。
 楼主| 发表于 2013-5-12 23:09:38 | 显示全部楼层
我这是照着高飞大哥的例子描出来的,还有你说的释放内存,要怎么释放,指针变量都需要释放吗?能不能给个例子?我写的都没释放的,运行久了会不会有问题?
发表于 2013-5-12 23:32:44 | 显示全部楼层
Gdlprfcu 发表于 2013-5-12 23:09
我这是照着高飞大哥的例子描出来的,还有你说的释放内存,要怎么释放,指针变量都需要释放吗?能不能给个 ...
你这么理解就行了
1、你定义的指针只是指向的一个内存地址
2、这个指针指向的内存在程序中是否被你分配内存了,如果是,那么程序结束的地方要释放它。不释放,内存没了就死呗、内存不足,系统慢呗,不释放你分配的内存,名词叫 “内存泄露”。、
     如果没分配的话,你只是引用,那么就不用释放。
3、ARX中释放的一般是选择集,用malloc分配的字符串内存。。。。
4、你不清楚的,你就程序里面先释放,然后编译运行,如果系统蹦了,你在改回来,不蹦,就是对了。
 楼主| 发表于 2013-5-13 12:11:21 | 显示全部楼层
XDSoft 发表于 2013-5-12 23:32
你这么理解就行了
1、你定义的指针只是指向的一个内存地址
多谢晓东大哥的指教。{:soso_e163:}
发表于 2020-4-1 17:53:33 | 显示全部楼层
编译几个新版吧,2014 2016 2018 2019 2020 2021
发表于 2020-9-25 00:03:16 | 显示全部楼层
thank you sharing
GMT+8, 2026-11-22 08:52 , Processed in 0.239799 second(s), 26 queries , Gzip On, File On.
