楼主: cswswq2009
2013-05-15 QQ群:ALISP&VLISP(143438137) 聊天记录:签到
发表于 2013-5-15 09:00:18 | 显示全部楼层
飞龙(877098916)于2013-05-15 09-00-18:
签到
发表于 2013-5-15 09:00:21 | 显示全部楼层
飞龙(877098916)于2013-05-15 09-00-21:
可耻啊
发表于 2013-5-15 09:00:46 | 显示全部楼层
生无可恋(381164857)于2013-05-15 09-00-46:
[face98.gif]
发表于 2013-5-15 09:01:27 | 显示全部楼层
/xu?誩茤鉍鉃?/xu(704138326)于2013-05-15 09-01-27:
签到
发表于 2013-5-15 09:03:58 | 显示全部楼层
流氓兔(871425525)于2013-05-15 09-03-58:
签到
发表于 2013-5-15 09:04:22 | 显示全部楼层
仲文玉(411952877)于2013-05-15 09-04-22:
签到
发表于 2013-5-15 09:08:10 | 显示全部楼层
陈海彬(258498815)于2013-05-15 09-08-10:
签到
发表于 2013-5-15 09:08:37 | 显示全部楼层
飞诗(252545152)于2013-05-15 09-08-37:
[face134.gif]
发表于 2013-5-15 09:22:15 | 显示全部楼层
落墨花-骉!找(226361689)于2013-05-15 09-22-15:
签到
发表于 2013-5-15 09:22:32 | 显示全部楼层
平凡  淡定(120389613)于2013-05-15 09-22-32:
签到
发表于 2013-5-15 09:23:52 | 显示全部楼层
eachy(124471899)于2013-05-15 09-23-52:
签到
发表于 2013-5-15 09:24:31 | 显示全部楼层
简单(252113063)于2013-05-15 09-24-31:
签到
发表于 2013-5-15 09:27:58 | 显示全部楼层
Happy(410786171)于2013-05-15 09-27-58:
签到
发表于 2013-5-15 09:33:45 | 显示全部楼层
周(281369222)于2013-05-15 09-33-45:
签到
发表于 2013-5-15 09:33:58 | 显示全部楼层
Happy(410786171)于2013-05-15 09-33-58:
(defun c:h_hzbbg (  )                       ; 主函数,绘制板标高
  (if (not (tblsearch "layer" "defpoints"))
      (command ".-layer" "M" "defpoints" "C" "g" "defpoints" " ")
  (if (not (tblsearch "layer" "填充-降板"))
      (command ".-layer" "M" "填充-降板" "C" "252" "填充-降板" " ")
  (if (not (tblsearch "layer" "标注-降板"))
      (command ".-layer" "M" "标注-降板" "C" "7" "标注-降板" ""  "")
  (setq
        hjb(getreal  "\n请输入降板标高:")
        p1 (getpoint "\n指定矩形板的一个角点:")
        p3 (getcorner p1 "\n指定矩形板的另一个角点:")
        Ht (if(setq tem (getint "\n请输入字高:"))  tem  500)
  (setvar "clayer" "填充-降板")
  (command "-bhatch" "a" "a"               ; *a[高级]选项,a[关联]
                                            "dr" "h"                       ; *dr[绘图次序],h[边界之后]
                                             "p" ta bl jd                   ; *p[特性]选项,s[实体](也可选u[自定义])
                                            "s" ss                         ; *s[选择对象],ss为程序选定需要填充的对象
  (setvar "clayer" "标注-降板")
  (command "_text" "s" "tssd_rein" "j" "bc" p5 Ht "0" tt )
  (setvar "clayer" lay_c)
(princ "\n运行命令:h_hzbbg" )
(princ))  )
  (setq x1 (car p1)
        y1 (cadr p1)
        x3 (car p3)
        y3 (cadr p3))
  (setq p2 (list x3 y1)
        p4 (list x1 y3)
        p5 (list ((* 0.5(+ x1 x3)) (* 0.5(+ y1 y3)) ) )
        tt (strcat "h-" hjb )
  (setvar "clayer" "defpoints")
  (command "pline" p1 p2 p3 p4 p1 "")
  (setq ss (entlast))  ; 取得图面中,最后一个(最新建立)对象
  (cond
    ((> hjb 0.22)(setq ta  "ar-sand"  bl  5  jd  0))
    ((> hjb 0.17)(setq ta  "brass"  bl  100  jd 30))
    ((> hjb 0.12)(setq ta  "swamp"  bl  10  jd  0))
    ((> hjb 0.07)(setq ta  "angle"  bl  50  jd  45))
    ((< hjb 0.08)(setq ta  "cross"  bl  100  jd  0))
GMT+8, 2026-11-24 11:06 , Processed in 0.373552 second(s), 5 queries , Gzip On, File On.
