查看: 1518|回复: 1
[求助] 请高飞鸟帮忙看看,下面这个VBS代码转成Lisp为何不成功?
发表于 2013-5-17 12:25:40 | 显示全部楼层 |阅读模式
在网上搜了一段Base64编码解码的VBS代码,VBS能正确运行,于是想把它移植到Lisp中来,移到Lisp中却不成功,请高飞鸟版主给看看,是什么原因?谢谢!下面是网上搜来的VBS代码
  1. '/*=========================================================================
  2. ' * Intro       Base64编码解码函数,Base64加密解密函数
  3. ' * FileName    Base64Test.vbs
  4. ' * Author      yongfa365
  5. ' * Version     v1.0
  6. ' * WEB         http://www.yongfa365.com
  7. ' * Email       yongfa365[at]qq.com
  8. ' * FirstWrite  http://www.yongfa365.com/Item/Base64Test.vbs.html
  9. ' * MadeTime    2007-12-31 23:44:36
  10. ' * LastModify  2007-12-31 23:44:36
  11. ' *==========================================================================*/
  12.
  13.
  14. sBASE_64_CHARACTERS = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/"
  15. sBASE_64_CHARACTERS = strUnicode2Ansi(sBASE_64_CHARACTERS)
  16.
  17.
  18. Function strUnicode2Ansi(asContents)
  19.     '将Unicode编码的字符串,转换成Ansi编码的字符串
  20.     strUnicode2Ansi = ""
  21.     len1 = Len(asContents)
  22.     For i = 1 To len1
  23.         varchar = Mid(asContents, i, 1)
  24.         varasc = Asc(varchar)
  25.         If varasc<0 Then varasc = varasc + 65536
  26.         If varasc>255 Then
  27.             varHex = Hex(varasc)
  28.             varlow = Left(varHex, 2)
  29.             varhigh = Right(varHex, 2)
  30.             strUnicode2Ansi = strUnicode2Ansi & chrb("&H" & varlow ) & chrb("&H" & varhigh )
  31.         Else
  32.             strUnicode2Ansi = strUnicode2Ansi & chrb(varasc)
  33.         End If
  34.     Next
  35. End Function
  36.
  37. Function strAnsi2Unicode(asContents)
  38.     '将Ansi编码的字符串,转换成Unicode编码的字符串
  39.     strAnsi2Unicode = ""
  40.     len1 = lenb(asContents)
  41.     If len1 = 0 Then Exit Function
  42.     For i = 1 To len1
  43.         varchar = midb(asContents, i, 1)
  44.         varasc = ascb(varchar)
  45.         If varasc > 127 Then
  46.             strAnsi2Unicode = strAnsi2Unicode & Chr(ascw(midb(asContents, i + 1, 1) & varchar))
  47.             i = i + 1
  48.         Else
  49.             strAnsi2Unicode = strAnsi2Unicode & Chr(varasc)
  50.         End If
  51.     Next
  52. End Function
  53.
  54. Function Base64encode(asContents)
  55.     '将Ansi编码的字符串进行Base64编码
  56.     'asContents应当是ANSI编码的字符串(二进制的字符串也可以)
  57.     Dim lnPosition
  58.     Dim lsResult
  59.     Dim Char1
  60.     Dim Char2
  61.     Dim Char3
  62.     Dim Char4
  63.     Dim Byte1
  64.     Dim Byte2
  65.     Dim Byte3
  66.     Dim SaveBits1
  67.     Dim SaveBits2
  68.     Dim lsGroupBinary
  69.     Dim lsGroup64
  70.     Dim m4, len1, len2
  71.
  72.     len1 = Lenb(asContents)
  73.     If len1<1 Then
  74.         Base64encode = ""
  75.         Exit Function
  76.     End If
  77.
  78.     m3 = Len1 Mod 3
  79.     If M3 > 0 Then asContents = asContents & String(3 - M3, chrb(0))
  80.     '补足位数是为了便于计算
  81.
  82.     If m3 > 0 Then
  83.         len1 = len1 + (3 - m3)
  84.         len2 = len1 -3
  85.     Else
  86.         len2 = len1
  87.     End If
  88.
  89.     lsResult = ""
  90.
  91.     For lnPosition = 1 To len2 Step 3
  92.         lsGroup64 = ""
  93.         lsGroupBinary = Midb(asContents, lnPosition, 3)
  94.
  95.         Byte1 = Ascb(Midb(lsGroupBinary, 1, 1))
  96.         SaveBits1 = Byte1 And 3
  97.         Byte2 = Ascb(Midb(lsGroupBinary, 2, 1))
  98.         SaveBits2 = Byte2 And 15
  99.         Byte3 = Ascb(Midb(lsGroupBinary, 3, 1))
  100.
  101.         Char1 = Midb(sBASE_64_CHARACTERS, ((Byte1 And 252) / 4) + 1, 1)
  102.         Char2 = Midb(sBASE_64_CHARACTERS, (((Byte2 And 240) / 16) Or (SaveBits1 * 16) And &HFF) + 1, 1)
  103.         Char3 = Midb(sBASE_64_CHARACTERS, (((Byte3 And 192) / 64) Or (SaveBits2 * 4) And &HFF) + 1, 1)
  104.         Char4 = Midb(sBASE_64_CHARACTERS, (Byte3 And 63) + 1, 1)
  105.         lsGroup64 = Char1 & Char2 & Char3 & Char4
  106.
  107.         lsResult = lsResult & lsGroup64
  108.     Next
  109.
  110.     '处理最后剩余的几个字符
  111.     If M3 > 0 Then
  112.         lsGroup64 = ""
  113.         lsGroupBinary = Midb(asContents, len2 + 1, 3)
  114.
  115.         Byte1 = Ascb(Midb(lsGroupBinary, 1, 1))
  116.         SaveBits1 = Byte1 And 3
  117.         Byte2 = Ascb(Midb(lsGroupBinary, 2, 1))
  118.         SaveBits2 = Byte2 And 15
  119.         Byte3 = Ascb(Midb(lsGroupBinary, 3, 1))
  120.
  121.         Char1 = Midb(sBASE_64_CHARACTERS, ((Byte1 And 252) / 4) + 1, 1)
  122.         Char2 = Midb(sBASE_64_CHARACTERS, (((Byte2 And 240) / 16) Or (SaveBits1 * 16) And &HFF) + 1, 1)
  123.         Char3 = Midb(sBASE_64_CHARACTERS, (((Byte3 And 192) / 64) Or (SaveBits2 * 4) And &HFF) + 1, 1)
  124.
  125.         If M3 = 1 Then
  126.             lsGroup64 = Char1 & Char2 & ChrB(61) & ChrB(61) '用=号补足位数
  127.         Else
  128.             lsGroup64 = Char1 & Char2 & Char3 & ChrB(61) '用=号补足位数
  129.         End If
  130.
  131.         lsResult = lsResult & lsGroup64
  132.     End If
  133.
  134.     Base64encode = lsResult
  135.
  136. End Function
  137.
  138.
  139. Function Base64decode(asContents)
  140.     '将Base64编码字符串转换成Ansi编码的字符串
  141.     'asContents应当也是ANSI编码的字符串(二进制的字符串也可以)
  142.     Dim lsResult
  143.     Dim lnPosition
  144.     Dim lsGroup64, lsGroupBinary
  145.     Dim Char1, Char2, Char3, Char4
  146.     Dim Byte1, Byte2, Byte3
  147.     Dim M4, len1, len2
  148.
  149.     len1 = Lenb(asContents)
  150.     M4 = len1 Mod 4
  151.
  152.     If len1 < 1 Or M4 > 0 Then
  153.         '字符串长度应当是4的倍数
  154.         Base64decode = ""
  155.         Exit Function
  156.     End If
  157.
  158.     '判断最后一位是不是 = 号
  159.     '判断倒数第二位是不是 = 号
  160.     '这里m4表示最后剩余的需要单独处理的字符个数
  161.     If midb(asContents, len1, 1) = chrb(61) Then m4 = 3
  162.     If midb(asContents, len1 -1, 1) = chrb(61) Then m4 = 2
  163.
  164.     If m4 = 0 Then
  165.         len2 = len1
  166.     Else
  167.         len2 = len1 -4
  168.     End If
  169.
  170.     For lnPosition = 1 To Len2 Step 4
  171.         lsGroupBinary = ""
  172.         lsGroup64 = Midb(asContents, lnPosition, 4)
  173.         Char1 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 1, 1)) - 1
  174.         Char2 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 2, 1)) - 1
  175.         Char3 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 3, 1)) - 1
  176.         Char4 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 4, 1)) - 1
  177.         Byte1 = Chrb(((Char2 And 48) / 16) Or (Char1 * 4) And &HFF)
  178.         Byte2 = lsGroupBinary & Chrb(((Char3 And 60) / 4) Or (Char2 * 16) And &HFF)
  179.         Byte3 = Chrb((((Char3 And 3) * 64) And &HFF) Or (Char4 And 63))
  180.         lsGroupBinary = Byte1 & Byte2 & Byte3
  181.
  182.         lsResult = lsResult & lsGroupBinary
  183.     Next
  184.
  185.     '处理最后剩余的几个字符
  186.     If M4 > 0 Then
  187.         lsGroupBinary = ""
  188.         lsGroup64 = Midb(asContents, len2 + 1, m4) & chrB(65) 'chr(65)=A,转换成值为0
  189.         If M4 = 2 Then '补足4位,是为了便于计算
  190.             lsGroup64 = lsGroup64 & chrB(65)
  191.         End If
  192.         Char1 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 1, 1)) - 1
  193.         Char2 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 2, 1)) - 1
  194.         Char3 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 3, 1)) - 1
  195.         Char4 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 4, 1)) - 1
  196.         Byte1 = Chrb(((Char2 And 48) / 16) Or (Char1 * 4) And &HFF)
  197.         Byte2 = lsGroupBinary & Chrb(((Char3 And 60) / 4) Or (Char2 * 16) And &HFF)
  198.         Byte3 = Chrb((((Char3 And 3) * 64) And &HFF) Or (Char4 And 63))
  199.
  200.         If M4 = 2 Then
  201.             lsGroupBinary = Byte1
  202.         ElseIf M4 = 3 Then
  203.             lsGroupBinary = Byte1 & Byte2
  204.         End If
  205.
  206.         lsResult = lsResult & lsGroupBinary
  207.     End If
  208.
  209.     Base64decode = lsResult
  210.
  211. End Function
  212.
  213.
  214.
  215. '因为Base64的编码与解码过程都是对Ansi编码进行操作的,所以在编码或解码前得先把我们平时看到的Unicode编码转换为Ansi编码
  216. 'Base64编码过程:Unicode-->Ansi-->Base64编码-->Unicode
  217. MsgBox strUnicode2Ansi("精彩blog http://www.yongfa365.com/"), , "Unicode转成Ansi,显示乱码为正常"
  218. MsgBox Base64encode(strUnicode2Ansi("精彩blog http://www.yongfa365.com/")), , "对Ansi进行Base64编码,显示乱码为正常"
  219. MsgBox strAnsi2Unicode(Base64encode(strUnicode2Ansi("精彩blog http://www.yongfa365.com/"))), , "编码后再由Ansi转为Unicode,显示正常"
  220.
  221. 'Base64解码过程:Unicode-->Ansi-->Base64解码-->Unicode
  222. MsgBox strAnsi2Unicode(Base64decode(strUnicode2Ansi("vquyymJsb2cgaHR0cDovL3d3dy55b25nZmEzNjUuY29tLw=="))), , "Base64解码过程"
  223.
  224. 'Base64编码解码过程:Unicode-->Ansi-->Base64编码-->Base64解码-->Unicode
  225. MsgBox strAnsi2Unicode(Base64decode(Base64encode(strUnicode2Ansi("精彩blog http://www.yongfa365.com/")))), , "Base64编码解码过程"
文件名称:Base64.zip
下载次数:4  文件大小:2.05 KB
  1. ;;参数 buffer = 字串
  2. ;;     encode = t 编码 = nil 解码
  3. (defun Base64code (buffer encode / wsObj FuncStr)
  4.   (if (setq wsObj (vlax-create-object "ScriptControl"))
  5.     (progn
  6.       (vlax-put wsObj "language" "VBS")
  7. (setq Funcstr
  8.        (list
  9.          "'/*=========================================================================  "
  10.          "' * Intro       Base64编码解码函数,Base64加密解密函数  "
  11.          "' * FileName    Base64Test.vbs  "
  12.          "' * Author      yongfa365  "
  13.          "' * Version     v1.0  "
  14.          "' * WEB         http://www.yongfa365.com  "
  15.          "' * Email       yongfa365[at]qq.com  "
  16.          "' * FirstWrite  http://www.yongfa365.com/Item/Base64Test.vbs.html  "
  17.          "' * MadeTime    2007-12-31 23:44:36  "
  18.          "' * LastModify  2007-12-31 23:44:36  "
  19.          "' *==========================================================================*/  "
  20.          ""
  21.          "sBASE_64_CHARACTERS = \"ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/\""
  22.          "sBASE_64_CHARACTERS = strUnicode2Ansi(sBASE_64_CHARACTERS)  "
  23.          ""
  24.          "Function strUnicode2Ansi(asContents)  "
  25.          "    '将Unicode编码的字符串,转换成Ansi编码的字符串  "
  26.          "    strUnicode2Ansi = \"\""
  27.          "    len1 = Len(asContents)  "
  28.          "    For i = 1 To len1  "
  29.          "        varchar = Mid(asContents, i, 1)  "
  30.          "        varasc = Asc(varchar)  "
  31.          "        If varasc<0 Then varasc = varasc + 65536  "
  32.          "        If varasc>255 Then  "
  33.          "            varHex = Hex(varasc)  "
  34.          "            varlow = Left(varHex, 2)  "
  35.          "            varhigh = Right(varHex, 2)  "
  36.          "            strUnicode2Ansi = strUnicode2Ansi & chrb(\"&H\" & varlow ) & chrb(\"&H\" & varhigh )  "
  37.          "        Else  "
  38.          "            strUnicode2Ansi = strUnicode2Ansi & chrb(varasc)  "
  39.          "        End If  "
  40.          "    Next  "
  41.          "End Function  "
  42.          ""
  43.          "Function strAnsi2Unicode(asContents)  "
  44.          "    '将Ansi编码的字符串,转换成Unicode编码的字符串  "
  45.          "    strAnsi2Unicode = \"\""
  46.          "    len1 = lenb(asContents)  "
  47.          "    If len1 = 0 Then Exit Function  "
  48.          "    For i = 1 To len1  "
  49.          "        varchar = midb(asContents, i, 1)  "
  50.          "        varasc = ascb(varchar)  "
  51.          "        If varasc > 127 Then  "
  52.          "            strAnsi2Unicode = strAnsi2Unicode & Chr(ascw(midb(asContents, i + 1, 1) & varchar))  "
  53.          "            i = i + 1  "
  54.          "        Else  "
  55.          "            strAnsi2Unicode = strAnsi2Unicode & Chr(varasc)  "
  56.          "        End If  "
  57.          "    Next  "
  58.          "End Function  "
  59.          ""
  60.          "Function Base64encode(asContents)  "
  61.          "    '将Ansi编码的字符串进行Base64编码  "
  62.          "    'asContents应当是ANSI编码的字符串(二进制的字符串也可以)  "
  63.          "    Dim lnPosition  "
  64.          "    Dim lsResult  "
  65.          "    Dim Char1  "
  66.          "    Dim Char2  "
  67.          "    Dim Char3  "
  68.          "    Dim Char4  "
  69.          "    Dim Byte1  "
  70.          "    Dim Byte2  "
  71.          "    Dim Byte3  "
  72.          "    Dim SaveBits1  "
  73.          "    Dim SaveBits2  "
  74.          "    Dim lsGroupBinary  "
  75.          "    Dim lsGroup64  "
  76.          "    Dim m4, len1, len2  "
  77.          "      "
  78.          "    len1 = Lenb(asContents)  "
  79.          "    If len1<1 Then  "
  80.          "        Base64encode = \"\""
  81.          "        Exit Function  "
  82.          "    End If  "
  83.          "      "
  84.          "    m3 = Len1 Mod 3  "
  85.          "    If M3 > 0 Then asContents = asContents & String(3 - M3, chrb(0))  "
  86.          "    '补足位数是为了便于计算  "
  87.          "      "
  88.          "    If m3 > 0 Then  "
  89.          "        len1 = len1 + (3 - m3)  "
  90.          "        len2 = len1 -3  "
  91.          "    Else  "
  92.          "        len2 = len1  "
  93.          "    End If  "
  94.          "      "
  95.          "    lsResult = \"\""
  96.          "      "
  97.          "    For lnPosition = 1 To len2 Step 3  "
  98.          "        lsGroup64 = \"\""
  99.          "        lsGroupBinary = Midb(asContents, lnPosition, 3)  "
  100.          "          "
  101.          "        Byte1 = Ascb(Midb(lsGroupBinary, 1, 1))  "
  102.          "        SaveBits1 = Byte1 And 3  "
  103.          "        Byte2 = Ascb(Midb(lsGroupBinary, 2, 1))  "
  104.          "        SaveBits2 = Byte2 And 15  "
  105.          "        Byte3 = Ascb(Midb(lsGroupBinary, 3, 1))  "
  106.          "          "
  107.          "        Char1 = Midb(sBASE_64_CHARACTERS, ((Byte1 And 252) / 4) + 1, 1)  "
  108.          "        Char2 = Midb(sBASE_64_CHARACTERS, (((Byte2 And 240) / 16) Or (SaveBits1 * 16) And &HFF) + 1, 1)  "
  109.          "        Char3 = Midb(sBASE_64_CHARACTERS, (((Byte3 And 192) / 64) Or (SaveBits2 * 4) And &HFF) + 1, 1)  "
  110.          "        Char4 = Midb(sBASE_64_CHARACTERS, (Byte3 And 63) + 1, 1)  "
  111.          "        lsGroup64 = Char1 & Char2 & Char3 & Char4  "
  112.          "          "
  113.          "        lsResult = lsResult & lsGroup64  "
  114.          "    Next  "
  115.          "      "
  116.          "    '处理最后剩余的几个字符  "
  117.          "    If M3 > 0 Then  "
  118.          "        lsGroup64 = \"\""
  119.          "        lsGroupBinary = Midb(asContents, len2 + 1, 3)  "
  120.          "          "
  121.          "        Byte1 = Ascb(Midb(lsGroupBinary, 1, 1))  "
  122.          "        SaveBits1 = Byte1 And 3  "
  123.          "        Byte2 = Ascb(Midb(lsGroupBinary, 2, 1))  "
  124.          "        SaveBits2 = Byte2 And 15  "
  125.          "        Byte3 = Ascb(Midb(lsGroupBinary, 3, 1))  "
  126.          "          "
  127.          "        Char1 = Midb(sBASE_64_CHARACTERS, ((Byte1 And 252) / 4) + 1, 1)  "
  128.          "        Char2 = Midb(sBASE_64_CHARACTERS, (((Byte2 And 240) / 16) Or (SaveBits1 * 16) And &HFF) + 1, 1)  "
  129.          "        Char3 = Midb(sBASE_64_CHARACTERS, (((Byte3 And 192) / 64) Or (SaveBits2 * 4) And &HFF) + 1, 1)  "
  130.          "          "
  131.          "        If M3 = 1 Then  "
  132.          "            lsGroup64 = Char1 & Char2 & ChrB(61) & ChrB(61) '用=号补足位数  "
  133.          "        Else  "
  134.          "            lsGroup64 = Char1 & Char2 & Char3 & ChrB(61) '用=号补足位数  "
  135.          "        End If  "
  136.          "          "
  137.          "        lsResult = lsResult & lsGroup64  "
  138.          "    End If  "
  139.          "      "
  140.          "    Base64encode = lsResult  "
  141.          "      "
  142.          "End Function  "
  143.          ""
  144.          ""
  145.          "Function Base64decode(asContents)  "
  146.          "    '将Base64编码字符串转换成Ansi编码的字符串  "
  147.          "    'asContents应当也是ANSI编码的字符串(二进制的字符串也可以)  "
  148.          "    Dim lsResult  "
  149.          "    Dim lnPosition  "
  150.          "    Dim lsGroup64, lsGroupBinary  "
  151.          "    Dim Char1, Char2, Char3, Char4  "
  152.          "    Dim Byte1, Byte2, Byte3  "
  153.          "    Dim M4, len1, len2  "
  154.          "      "
  155.          "    len1 = Lenb(asContents)  "
  156.          "    M4 = len1 Mod 4  "
  157.          "      "
  158.          "    If len1 < 1 Or M4 > 0 Then  "
  159.          "        '字符串长度应当是4的倍数  "
  160.          "        Base64decode = \"\""
  161.          "        Exit Function  "
  162.          "    End If  "
  163.          "      "
  164.          "    '判断最后一位是不是 = 号  "
  165.          "    '判断倒数第二位是不是 = 号  "
  166.          "    '这里m4表示最后剩余的需要单独处理的字符个数  "
  167.          "    If midb(asContents, len1, 1) = chrb(61) Then m4 = 3  "
  168.          "    If midb(asContents, len1 -1, 1) = chrb(61) Then m4 = 2  "
  169.          "      "
  170.          "    If m4 = 0 Then  "
  171.          "        len2 = len1  "
  172.          "    Else  "
  173.          "        len2 = len1 -4  "
  174.          "    End If  "
  175.          "      "
  176.          "    For lnPosition = 1 To Len2 Step 4  "
  177.          "        lsGroupBinary = \"\""
  178.          "        lsGroup64 = Midb(asContents, lnPosition, 4)  "
  179.          "        Char1 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 1, 1)) - 1  "
  180.          "        Char2 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 2, 1)) - 1  "
  181.          "        Char3 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 3, 1)) - 1  "
  182.          "        Char4 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 4, 1)) - 1  "
  183.          "        Byte1 = Chrb(((Char2 And 48) / 16) Or (Char1 * 4) And &HFF)  "
  184.          "        Byte2 = lsGroupBinary & Chrb(((Char3 And 60) / 4) Or (Char2 * 16) And &HFF)  "
  185.          "        Byte3 = Chrb((((Char3 And 3) * 64) And &HFF) Or (Char4 And 63))  "
  186.          "        lsGroupBinary = Byte1 & Byte2 & Byte3  "
  187.          "          "
  188.          "        lsResult = lsResult & lsGroupBinary  "
  189.          "    Next  "
  190.          "      "
  191.          "    '处理最后剩余的几个字符  "
  192.          "    If M4 > 0 Then  "
  193.          "        lsGroupBinary = \"\""
  194.          "        lsGroup64 = Midb(asContents, len2 + 1, m4) & chrB(65) 'chr(65)=A,转换成值为0  "
  195.          "        If M4 = 2 Then '补足4位,是为了便于计算  "
  196.          "            lsGroup64 = lsGroup64 & chrB(65)  "
  197.          "        End If  "
  198.          "        Char1 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 1, 1)) - 1  "
  199.          "        Char2 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 2, 1)) - 1  "
  200.          "        Char3 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 3, 1)) - 1  "
  201.          "        Char4 = InStrb(sBASE_64_CHARACTERS, Midb(lsGroup64, 4, 1)) - 1  "
  202.          "        Byte1 = Chrb(((Char2 And 48) / 16) Or (Char1 * 4) And &HFF)  "
  203.          "        Byte2 = lsGroupBinary & Chrb(((Char3 And 60) / 4) Or (Char2 * 16) And &HFF)  "
  204.          "        Byte3 = Chrb((((Char3 And 3) * 64) And &HFF) Or (Char4 And 63))  "
  205.          "          "
  206.          "        If M4 = 2 Then  "
  207.          "            lsGroupBinary = Byte1  "
  208.          "        ElseIf M4 = 3 Then  "
  209.          "            lsGroupBinary = Byte1 & Byte2  "
  210.          "        End If  "
  211.          "          "
  212.          "        lsResult = lsResult & lsGroupBinary  "
  213.          "    End If  "
  214.          "      "
  215.          "    Base64decode = lsResult  "
  216.          "      "
  217.          "End Function  "
  218.          )
  219.       )
  220.       (vlax-invoke wsObj 'ExecuteStatement (apply 'strcat (mapcar '(lambda (x) (strcat x "\n")) FuncStr)))
  221.       (if encode
  222.       (setq buffer
  223.              (vlax-invoke wsObj 'run "strAnsi2Unicode"
  224.                (vlax-invoke wsObj 'run "Base64encode"
  225.                  (vlax-invoke wsObj 'run "strUnicode2Ansi" buffer)
  226.                  )
  227.                )
  228.             ) ;_ 编码
  229.         (setq buffer
  230.              (vlax-invoke wsObj 'run "strAnsi2Unicode"
  231.                (vlax-invoke wsObj 'run "Base64decode"
  232.                  (vlax-invoke wsObj 'run "strUnicode2Ansi" buffer)
  233.                  )
  234.                )
  235.             ) ;_ 解码
  236.         )
  237.
  238.       (vlax-release-object wsObj)
  239.       buffer
  240.     )
  241.   )
  242. )
  243. ;; 编码测试 ,结果不正确
  244. (Base64code "精彩blog http://www.yongfa365.com/" t)
  245. ;;解码测试,提示 错误: Microsoft VBScript 运行时错误: 无效的过程调用或参数: 'ascw'
  246. (Base64code "vquyymJsb2cgaHR0cDovL3d3dy55b25nZmEzNjUuY29tLw==" nil)
文件名称:Base64.zip
下载次数:7  文件大小:2.56 KB
已领礼包: 51个
发表于 2013-5-17 12:47:51 | 显示全部楼层
早上刚看一个朋友解码成了,看看这个帖子对你有帮助没
http://bbs.xdcad.net/thread-668134-1-1.html
GMT+8, 2026-11-6 23:39 , Processed in 0.509380 second(s), 35 queries , Gzip On.
