查看: 2925|回复: 5
[分享] OjbectARX实用函数代码系列(6)
已领礼包: 13个
发表于 2013-5-18 14:01:23 | 显示全部楼层 |阅读模式
[pcode=cpp,true]
static LPCTSTR      ptToStr(const AcGePoint3d& pt, CString& str, int unit = -1, int prec = -1);
static LPCTSTR      ptToStr(const AcGePoint2d& pt, CString& str, int unit = -1, int prec = -1);
static LPCTSTR      vectorToStr(const AcGeVector3d& vec, CString& str, int unit = -1, int prec = -1);
static LPCTSTR      vectorToStr(const AcGeVector2d& vec, CString& str, int unit = -1, int prec = -1);
static LPCTSTR      angleToStr(const double angle, CString& str, int unit = -1, int prec = -1);
static LPCTSTR      doubleToStr(const double realVal, CString& str, int unit = -1, int prec = -1);
static LPCTSTR      intToStr(const int intVal, CString& str);
static LPCTSTR      ptrToStr(void* ptr, CString& str);
static LPCTSTR                dbToStr(AcDbDatabase* db, CString& str);
static LPCTSTR      booleanToStr(bool b, CString& str);
static LPCTSTR      booleanToStr(Adesk::Boolean b, CString& str);
static LPCTSTR      colorToStr(int color, CString& str, bool convertStandard = true);
static LPCTSTR      objToHandleStr(const AcDbObject* obj, CString& str);
static LPCTSTR      objToEnameStr(const AcDbObject* obj, CString& str);
static LPCTSTR      objToClassStr(const AcRxObject* obj);
static LPCTSTR                objToClassAndHandleStr(const AcDbObjectId& objId, CString& str);
static LPCTSTR                objToClassAndHandleStr(const AcDbObject* obj, CString& str);
static LPCTSTR                textModeToStr(AcDb::TextHorzMode horizMode, CString& str);
static LPCTSTR                textModeToStr(AcDb::TextVertMode vertMode, CString& str);
static LPCTSTR                vertexTypeToStr(AcDb::Vertex3dType vertexType, CString& str);
static LPCTSTR                hatchTypeToStr(AcDbHatch::HatchPatternType hatchType, CString& str);
static LPCTSTR                hatchStyleToStr(AcDbHatch::HatchStyle style, CString& str);
static LPCTSTR                hatchLoopTypeToStr(Adesk::Int32 loopType, CString& str);
[/pcode]
游客,本帖隐藏的内容需要积分高于 50 才可浏览,您当前积分为 0
评分
参与人数 1D豆 +3 收起 理由
ScmTools + 3 资料分享奖!
查看全部评分
已领礼包: 1632个
财富等级: 堆金积玉
发表于 2013-5-18 16:55:09 | 显示全部楼层
支持!类型转换很常用
发表于 2014-1-27 17:28:41 | 显示全部楼层
学习一下,谢谢:)
已领礼包: 81个
发表于 2014-4-20 20:02:21 | 显示全部楼层
虽然看不懂,但是还是要顶的!!
发表于 2014-4-22 21:44:24 | 显示全部楼层
谢谢楼主分享
发表于 2014-9-13 17:02:58 | 显示全部楼层
{:soso_e102:}{:soso_e103:}{:soso_e117:}
GMT+8, 2026-11-3 19:15 , Processed in 0.569608 second(s), 39 queries , Gzip On.
