查看: 2896|回复: 8
[分享] ObjectARX实用函数系列(8)
已领礼包: 13个
发表于 2013-5-18 14:37:25 | 显示全部楼层 |阅读模式
[pcode=cpp,true]
static LPCTSTR                docLockModeToStr(AcAp::DocLockMode activity, CString& str);
static LPCTSTR                dateToStr(const AcDbDate& date, CString& str);
static LPCTSTR                promptStatusToStr(Acad::PromptStatus stat, CString& str);
static LPCTSTR                initFlagsToStr(int initFlags, CString& str);
static LPCTSTR                deepCloneContextToStr(AcDb::DeepCloneType context, CString& str);
static LPCTSTR                filerTypeToStr(AcDb::FilerType type, CString& str);
static LPCTSTR                osnapToStr(int osnapMode, CString& str);
static LPCTSTR                doubleArray3dToStr(double array[], CString& str);
static LPCTSTR                doubleArray2dToStr(double array[], CString& str);
static void                        stuffAcadCmdLine(const CString& str);
static void         clearAcadCmdLine();
static void                        printIdMap(AcDbIdMapping* idMap, LPCTSTR msgStr);
static Acad::ErrorStatus        getPlinePointArrayFromUser(AcGePoint3dArray& vertices);
static void                 grdrawPline(const AcGePoint3dArray& pts, BOOL close, BOOL hilite);
static void                 debugPause(LPCTSTR msg);
static Acad::ErrorStatus    getFileName(bool isForWrite, LPCTSTR prompt,
                                    LPCTSTR def, LPCTSTR ext, CString& fname,
                                    bool defIsDirectory = true,
                                    bool allowArbitraryExt = false);
static Acad::ErrorStatus    getFileNameForRead(LPCTSTR prompt, LPCTSTR def,
static Acad::ErrorStatus    getFileNameForWrite(LPCTSTR prompt, LPCTSTR def,
static ArxDbgUiPrBase::Status    yesNoPrompt(LPCTSTR msg, bool& answer);
static ArxDbgUiPrBase::Status    yesNoPromptDef(LPCTSTR msg, bool& answer, bool def);
static ArxDbgUiPrBase::Status    getNewSymbolName(LPCTSTR msg, AcRxClass* symType, CString& symName);
static ArxDbgUiPrBase::Status    getExistingSymbolName(LPCTSTR msg, AcRxClass* symType,
        CString& symName, bool allowPipes = true);
static bool       getEntityOrObject(AcDbObjectId& objId);
[/pcode]
游客,本帖隐藏的内容需要积分高于 50 才可浏览,您当前积分为 0
评分
参与人数 1D豆 +3 收起 理由
ScmTools + 3 资料分享奖!
查看全部评分
已领礼包: 1632个
财富等级: 堆金积玉
发表于 2013-5-18 17:00:35 | 显示全部楼层
支持!谢谢分享,希望再接再厉!
发表于 2013-8-9 09:19:08 | 显示全部楼层
没分:(:(:(:(:(:(:(:(:(:(
发表于 2013-9-12 22:13:24 | 显示全部楼层
支持 支持
发表于 2013-11-8 15:36:23 | 显示全部楼层
还不够格:(:D:(:(:(
发表于 2014-12-12 15:09:26 | 显示全部楼层
积分不够!!!!
已领礼包: 221个
发表于 2014-12-25 18:15:23 | 显示全部楼层
门槛太高看不了,等。。。。。。。
已领礼包: 112个
发表于 2016-8-11 09:14:42 | 显示全部楼层
支持!谢谢楼主分享
发表于 2017-2-13 13:13:15 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
GMT+8, 2026-11-3 06:11 , Processed in 1.061566 second(s), 47 queries , Gzip On.
