查看: 2901|回复: 2
[分享] Using ActiveX API GetBoundingBox in .NET
已领礼包: 593个
发表于 2013-5-25 03:13:49 | 显示全部楼层 |阅读模式
Using ActiveX API GetBoundingBox in .NET                                                        By Virupaksha Aithal
Below code shows the procedure to use activeX API GetBoundingBox in AutoCAD.NET. As GetBoundingBox returns the points, we need to "InvokeMember" member with "ParameterModifier" parameters.
  1. [CommandMethod("GetBoundingBox")]
  2. static public void GetBoundingBox()
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Database db = doc.Database;
  6.     Editor ed = doc.Editor;
  7.     PromptEntityOptions options =
  8.           new PromptEntityOptions("\nSelect an entity");
  9.     PromptEntityResult acSSPrompt = ed.GetEntity(options);
  10.     if (acSSPrompt.Status != PromptStatus.OK)
  11.     return;
  12.     // obtain transaction manager
  13.     using (Transaction Tx = db.TransactionManager.StartTransaction())
  14.     {
  15.         Entity text = Tx.GetObject(acSSPrompt.ObjectId,
  16.                                          OpenMode.ForRead) as Entity;
  17.         object oAcadObjpl1 = text.AcadObject;
  18.         object[] argspl1 = new object[2];
  19.         argspl1[0] = new VariantWrapper(0);
  20.         argspl1[1] = new VariantWrapper(0);
  21.         ParameterModifier pmpl1 = new ParameterModifier(2);
  22.         pmpl1[0] = true;
  23.         pmpl1[1] = true;
  24.         ParameterModifier[] modifierspl1 =
  25.             new ParameterModifier[] { pmpl1 };
  26.         oAcadObjpl1.GetType().InvokeMember("GetBoundingBox",
  27.                BindingFlags.InvokeMethod, null, oAcadObjpl1, argspl1,
  28.                modifierspl1, null, null);
  29.         Point3d pt1 =
  30.             new Point3d((double[])argspl1[0]);
  31.         Point3d pt2 =
  32.             new Point3d((double[])argspl1[1]);
  33.         ed.WriteMessage("\n");
  34.         ed.WriteMessage(pt1.X + "," + pt1.Y + "," + pt1.Z + "\n");
  35.         ed.WriteMessage(pt2.X + "," + pt2.Y + "," + pt2.Z + "\n");
  36.         Tx.Commit();
  37.     }
  38. }
发表于 2015-3-7 10:32:26 | 显示全部楼层
有人能帮解释下oAcadObjpl1.GetType().InvokeMember("GetBoundingBox",
               modifierspl1, null, null);参数的含义吗
发表于 2020-5-28 15:34:36 | 显示全部楼层
学习了!谢谢!!!
GMT+8, 2026-11-3 01:33 , Processed in 0.461934 second(s), 32 queries , Gzip On.
