查看: 1397|回复: 0
[他山之石] 用LISP删除 LayerFilters (非-ActiveX)
发表于 2013-5-25 03:53:13 | 显示全部楼层 |阅读模式
Delete LayerFilters using LISP (non-ActiveX)                                                        by Fenton Webb
  So maybe you want to write an AutoLISP function (not ActiveX) to delete layerFilters.
  With ActiveX (vla-xxx) functions, you can obtain the ACADLAYERS_DICTIONARY dictionary by calling
  (vla-getextensiondictionary <layerscollection>)
  but how can we access ACAD_LAYERFILTERS and delete the layerfilters, using just plain old AutoLISP?
  Here’s how…
  1. (defun C:DelLyrFlt ( / tbl lyr xlist xrec filt)
  2.    (setq tbl (tblnext "LAYER" T)
  3.             lyr (tblobjname "LAYER" (cdr(assoc 2 tbl)))
  4.    ) ;setq
  5.    ;;Find the"ACAD_LAYERFILTERS" xrecord in the extension dictionary of the layer
  6.    (setq xlist (dictsearch
  7.                      (cdr (assoc 360 (entget (cdr (assoc 330 (entget lyr))))))
  8.                      "ACAD_LAYERFILTERS")
  9.    ) ;setq
  10.    (if xlist
  11.       (progn
  12.          ;;Get the first layer_filter
  13.          (setq xrec (cdr (assoc -1 xlist))
  14.                  filt (dictnext xrec t)
  15.          ) ;setq
  16.          ;;Remove each layer_filter
  17.          (while filt
  18.             (dictremove xrec (cdr (assoc 1 filt)))
  19.             (setq filt (dictnext xrec t))
  20.          ) ;while
  21.          ;;Find the"ACAD_LAYERFILTERS" xrecord
  22.          (dictremove
  23.             (cdr (assoc 360 (entget (cdr (assoc 330 (entget lyr))))))
  24.             "ACAD_LAYERFILTERS"
  25.          )
  26.       ) ;progn
  27.    ) ;if
  28.    (princ)
  29. )
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 很给力!经验;技术要点;资料分享奖!
查看全部评分
GMT+8, 2026-11-6 23:37 , Processed in 0.435444 second(s), 33 queries , Gzip On.
