查看: 1263|回复: 2
[他山之石] 如何用LISP加载 .MLN 文件
发表于 2013-5-25 09:12:03 | 显示全部楼层 |阅读模式
How to load a .MLN file using LISPBy Augusto Goncalves
There isn't a ready-to-use API function that loads a .MLN file in Lisp, VBA and ARX. Normally you can do this only by using the MLSTYLE dialog.
Of course, it's possible to create the dictionary entry of a multiline style definition programmatically with either API. The following code shows how to read the .MLN file in Lisp and how to create the MLINESTYLE objects defined in it.
  1. (defun c:LoadMlStyles (/ mlFileName)
  2.    (setq mlFileName (getstring "\nEnter MLN file name: "))
  3.    (if (/= nil mlFileName)
  4.       (LoadMln mlFileName)
  5.    )
  6.    (princ)
  7. )
  8. (defun LoadMln (mlnFile / f mlineDict same newStyle xName)
  9.    (setq mlnFile (findfile mlnFile))
  10.    (setq f (open mlnFile "r"))
  11.    ;;(setq f (open mlnFile "r"))
  12.    (if (= NIL f)
  13.       (princ "\nInvalid MLN file.\n")
  14.       (progn
  15.          ;; Get the MLINESTLYE dictionary.
  16.          (setq mlineDict (dictsearch
  17.                (namedobjdict) "ACAD_MLINESTYLE"))
  18.          ;; Create the beginning of an MLINESTYLE object.
  19.          (setq same (list (cons 0 "MLINESTYLE")
  20.                              ;;(cons 102 "{ACAD_REACTORS")
  21.                              ;;(cons 330 (cdr (assoc -1 mlineDict)))
  22.                              ;;(cons 102 "}")
  23.                              ;;(cons 330 (cdr (assoc -1 mlineDict)))
  24.                                  (cons 100 "AcDbMlineStyle")
  25.                           )
  26.          )
  27.          ;;
  28.          ;; Read the data of the MLINESTYLE
  29.          ;;
  30.          (while (/= nil (setq mlStyle (ReadObject f)))
  31.             ;; Create the complete MLINESTYLE object.
  32.             (setq newStyle (append same mlStyle)
  33.                      xName    (entmakex newStyle)
  34.             )
  35.             ;; Append it to the MLINESTYLE dictionary.
  36.             (dictadd (cdr (assoc -1 mlineDict))
  37.                (cdr (assoc 2 newStyle))
  38.                xName
  39.             )
  40.          )
  41.       )
  42.    )
  43.    (close f)
  44.    (princ)
  45. )
  46. (defun ReadObject (f / ObjectList firstLine code value)
  47.   (setq ObjectList nil)
  48.   ;; Skip the 'MLSTYLE'.
  49.   (setq firstLine (read-line f))
  50.   (if (/= nil firstLine)
  51.    (progn
  52.      (while (/= 0 (setq code (atoi (read-line f))))
  53.         (setq value (vl-string-trim " " (read-line f)))
  54.         (if (or (= code 2)
  55.                   (= code 3)
  56.                   (= code 6)
  57.             )
  58.            (setq ObjectList (append ObjectList
  59.            (list (cons code value))))
  60.         )
  61.         (if (or (= code 70)
  62.                   (= code 62)
  63.                   (= code 71)
  64.              )
  65.            (setq ObjectList (append ObjectList
  66.            (list (cons code (atoi value)))))
  67.         )
  68.         (if (or (= code 51)
  69.                 (= code 52)
  70.           )
  71.           ;; Code 51 and 52 must be converted into degrees.
  72.           (setq ObjectList
  73.             (append ObjectList
  74.             (list (cons code
  75.             (angtof value 0)))))
  76.           )
  77.           (if (= code 49)
  78.            (setq ObjectList
  79.            (append ObjectList
  80.            (list (cons code (atof value)))))
  81.           )
  82.        )
  83.    )
  84.   )
  85.   ObjectList
  86. )
You can load a .MLN file from the AutoCAD command line by using the LOADMLSTYLES command. This command asks for the MLN file name. If you want to call this function from Lisp, you can use the (LOADMLN) function. There you can specify the MLN file name.
Once you've loaded a .MLN file, you can set the AutoCAD variable CMLSTYLE to one of the loaded styles, so the next created MLINE will use the style.
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 很给力!经验;技术要点;资料分享奖!
查看全部评分
发表于 2013-7-16 21:45:23 | 显示全部楼层
使用(vl-load-com)函数将(defun LoadMln ---和(defun ReadObject---置前
已领礼包: 6468个
发表于 2013-7-17 00:10:00 | 显示全部楼层
*.MLN是什么文件?
GMT+8, 2026-11-7 20:52 , Processed in 0.446069 second(s), 33 queries , Gzip On.
