查看: 1343|回复: 0
[分享] How to pass COM optional parameter in C#
已领礼包: 593个
发表于 2013-5-26 18:20:22 | 显示全部楼层 |阅读模式
How to pass COM optional parameter in C#                                                        By Philippe Leefsma
  Here is a problem you may encounter when invoking the AutoCAD ActiveX API from C#:
  I'm trying to use AcadSelectionSet.SelectOnScreen in C# with similar approaches I've been using in VB. But I can't omit the optional parameters in C# which I can in VB.
I tried to create some empty arrays and pass them to SelectOnScreen but I get invalid argument errors.
Could you offer a solution?
  Solution
  Note: this workaround only applies to .Net 3.5 and prior versions of the framework, as C# 4.0 provides missing parameters functionality.
  In VB, you can ignore the optional parameters when you call AcadSelectionSet.SelectOnScreen but you can't do that in C#. This is because C# doesn't support optional parameters. Also, if you really want to pass NULL values as an indication that you don't want any values in the object array (no variant in C#), you can't create arrays with values, the zeros will be trades as values in the DXF code not 'nothing'. That's where the problem is.
  Fortunately, there is a solution in .NET which is using object reflection to specific a missing value that is NULL.
   object o = System.Reflection.Missing.Value;
  This will be the equivalent of NULL values passed into VB functions call. The following code snippet demonstrates how it works.
  1. //
  2. // error checking code omitted for code brevity
  3. //
  4. private void TestMissing(AcadApplication oAcad)
  5. {
  6.     AcadDocument oDoc = oAcad.ActiveDocument;
  7.     AcadSelectionSet ss = oDoc.SelectionSets.Add("ss01");
  8.     object oMissing01 = System.Reflection.Missing.Value;
  9.     object oMissing02 = System.Reflection.Missing.Value;
  10.     ss.SelectOnScreen(oMissing01, oMissing02);
  11.     System.Windows.Forms.MessageBox.Show(
  12.         "Number of objects in the selection: " + ss.Count + ".");
  13.     ss.Delete();
  14. }
GMT+8, 2026-11-3 10:46 , Processed in 0.426016 second(s), 28 queries , Gzip On.
