查看: 1496|回复: 0
[分享] Copying (DeepCloning) from one Drawing to another using .NET
已领礼包: 593个
发表于 2013-5-26 18:39:15 | 显示全部楼层 |阅读模式
Here’s how to copy entities from the Model Space of a DWG file hosted inside of AutoCAD to an external DWG file.
  1. // copy Model Space to external DWG
  2. // by Fenton Webb, DevTech 14/9/2012
  3. [CommandMethod("CopySpaceToExtDWG")]
  4. public static void CopySpaceToExtDWG()
  5. {
  6. // get the working database (in AutoCAD)
  7. Database sourceDb = Application.DocumentManager.MdiActiveDocument.Database;
  8. try
  9. {
  10.   // create a new destination database
  11.   using (Database destDb = new Database(true, true))
  12.   {
  13.    // get the model space object ids for both dbs
  14.    ObjectId sourceMsId = SymbolUtilityServices.GetBlockModelSpaceId(sourceDb);
  15.    ObjectId destDbMsId = SymbolUtilityServices.GetBlockModelSpaceId(destDb);
  16.    // now create an array of object ids to hold the source objects to copy
  17.    ObjectIdCollection sourceIds = new ObjectIdCollection();
  18.    // open the sourceDb ModelSpace (current autocad dwg)
  19.    using (BlockTableRecord ms = sourceMsId.Open(OpenMode.ForRead)
  20.         as BlockTableRecord)
  21.     // loop all the entities and record their ids
  22.     foreach (ObjectId id in ms)
  23.      sourceIds.Add(id);
  24.    // next prepare to deepclone the recorded ids to the destdb
  25.    IdMapping mapping = new IdMapping();
  26.    // now clone the objects into the destdb
  27.    sourceDb.WblockCloneObjects(sourceIds, destDbMsId, mapping, DuplicateRecordCloning.Replace, false);
  28.    destDb.SaveAs("c:\\temp\\dwgs\\CopyTest.dwg", DwgVersion.Current);
  29.   }
  30. }
  31. catch (System.Exception eXP)
  32. {
  33.   System.Windows.Forms.MessageBox.Show(eXP.ToString());
  34. }
  35. }
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 很给力!经验;技术要点;资料分享奖!
查看全部评分
GMT+8, 2026-11-3 10:40 , Processed in 0.538027 second(s), 33 queries , Gzip On.
