查看: 2501|回复: 0
[分享] Changing draworder of entities
已领礼包: 593个
发表于 2013-5-26 23:38:32 | 显示全部楼层 |阅读模式
Changing draworder of entities                                                        By Balaji Ramamoorthy
An MText with background mask set can hide entities that are behind it. To send the MText to the back and make the entity behind it to be visible, we can set the DrawOrder in AutoCAD using the context menu option. This can also be achieved programmatically for an entity.
Here is a sample code to send a selected entity behind. i.e., change the draworder of the selected entity to bottom.
Using ObjectARX :
  1. static void ADSProjectSendToBottom(void)
  2. {
  3.     ads_name ent;
  4.     ads_point pt;
  5.     Acad::ErrorStatus es;
  6.     int ret = RTNORM;
  7.     ret = acedEntSel(    _T("\nSelect Entity: "),
  8.                 ent,
  9.                 pt
  10.               );
  11.     if (RTNORM != ret)
  12.         return;
  13.     AcDbObjectId ent_id;
  14.     if (Acad::eOk != acdbGetObjectId( ent_id, ent ))
  15.         return;
  16.     configureSortents();
  17.     AcDbEntity *pEnt;
  18.     es = acdbOpenObject( pEnt, ent_id, AcDb::kForRead );
  19.     if (Acad::eOk != es)
  20.         return;
  21.     AcDbSortentsTable *pSt = GetSortentsTableOf( pEnt );
  22.     pEnt->close();
  23.     if (NULL == pSt)
  24.         return;
  25.     AcDbObjectIdArray entity_array;
  26.     entity_array.append( ent_id );
  27.     pSt->moveToBottom( entity_array );
  28.     pSt->close();
  29.     // Send regen command or use the
  30.     // undocumented ads_regen method.
  31.     acDocManager->sendStringToExecute
  32.                             (
  33.                                 acDocManager->curDocument(),
  34.                                 L"_regen\n",
  35.                                 false,
  36.                                 true
  37.                             );
  38. }
Using AutoCAD .Net API :
  1. [CommandMethod("SendToBottom")]
  2. public void commandDrawOrderChange()
  3. {
  4.     Document activeDoc
  5.                 = Application.DocumentManager.MdiActiveDocument;
  6.     Database db = activeDoc.Database;
  7.     Editor ed = activeDoc.Editor;
  8.     PromptEntityOptions peo
  9.                 = new PromptEntityOptions("Select an entity : ");
  10.     PromptEntityResult per = ed.GetEntity(peo);
  11.     if (per.Status != PromptStatus.OK)
  12.     {
  13.         return;
  14.     }
  15.     ObjectId oid = per.ObjectId;
  16.     SortedList<long, ObjectId> drawOrder
  17.                             = new SortedList<long, ObjectId>();
  18.     using (Transaction tr = db.TransactionManager.StartTransaction())
  19.     {
  20.         BlockTable bt = tr.GetObject(
  21.                                         db.BlockTableId,
  22.                                         OpenMode.ForRead
  23.                                     ) as BlockTable;
  24.         BlockTableRecord btrModelSpace =
  25.                 tr.GetObject(
  26.                                 bt[BlockTableRecord.ModelSpace],
  27.                                 OpenMode.ForRead
  28.                             ) as BlockTableRecord;
  29.         DrawOrderTable dot =
  30.                 tr.GetObject(
  31.                                 btrModelSpace.DrawOrderTableId,
  32.                                 OpenMode.ForWrite
  33.                             ) as DrawOrderTable;
  34.         ObjectIdCollection objToMove = new ObjectIdCollection();
  35.         objToMove.Add(oid);
  36.         dot.MoveToBottom(objToMove);
  37.         tr.Commit();
  38.     }
  39.     ed.WriteMessage("Done");
  40. }
GMT+8, 2026-11-3 10:48 , Processed in 0.476857 second(s), 28 queries , Gzip On.
