查看: 2283|回复: 0
[分享] Displaying entities in different colors using DrawableOverrule
发表于 2013-5-27 00:17:22 | 显示全部楼层 |阅读模式
Displaying entities in different colors using DrawableOverrule                                                        By Balaji Ramamoorthy
Recently, a developer wanted to know a method to display the entities in different colors to visually represent the results of a drawing comparison. A way to set the color for entities including those that are nested is explained in Kean's blog post :
Changing the colour of nested AutoCAD entities through .NETAnother way to show the entity in different colors would be to use of DrawableOverrule. But, the WorldDraw of the DrawableOverrule class does not use the color setting from the DrawableTraits for some entities such as MText. To overcome this limitation, the drawable is cloned inside the WorldDraw method before being assigned a new color.
Here is a sample code using this approach. Some of the helper methods to highlight / unhighlight and pick nested entities are from Kean's blog post that I mentioned about previously.
  1. using Autodesk.AutoCAD.GraphicsInterface;
  2. using System.Collections.Generic;
  3. public class MyDrawOverrule : DrawableOverrule
  4. {
  5.     public static List<ObjectId> _redIds = new List<ObjectId>();
  6.     public static List<ObjectId> _yellowIds = new List<ObjectId>();
  7.     public override bool WorldDraw(Drawable drawable, WorldDraw wd)
  8.     {
  9.         Entity mydrawable = drawable.Clone() as Entity;
  10.         short colorIndex = 1;
  11.         if (_yellowIds.Contains(drawable.Id))
  12.             colorIndex = 2;
  13.         wd.SubEntityTraits.Color = colorIndex;
  14.         mydrawable.ColorIndex = colorIndex;
  15.         return base.WorldDraw(mydrawable, wd);
  16.     }
  17.     public override int SetAttributes(Drawable drawable,
  18.                                         DrawableTraits traits)
  19.     {
  20.         return base.SetAttributes(drawable, traits);
  21.     }
  22. }
  23. public class ColorizeClass : IExtensionApplication
  24. {
  25.     static MyDrawOverrule _do = null;
  26.     [CommandMethod("Colorize")]
  27.     public void ColorizeMethod()
  28.     {
  29.         Document doc = Application.DocumentManager.MdiActiveDocument;
  30.         Editor ed = doc.Editor;
  31.         if (_do != null)
  32.         {
  33.             ed.WriteMessage("Overruling is already active");
  34.             return;
  35.         }
  36.         Transaction tr = doc.TransactionManager.StartTransaction();
  37.         using (tr)
  38.         {
  39.             List<FullSubentityPath> paths1;
  40.             SelectNestedEntities(   ed,
  41.                                     out MyDrawOverrule._redIds,
  42.                                     out paths1,
  43.                                     "Red"
  44.                                 );
  45.             List<FullSubentityPath> paths2;
  46.             SelectNestedEntities(  ed,
  47.                                     out MyDrawOverrule._yellowIds,
  48.                                     out paths2,
  49.                                     "Yellow"
  50.                                  );
  51.             _do = new MyDrawOverrule();
  52.             Overrule.AddOverrule(
  53.                 RXObject.GetClass(typeof(Entity)),
  54.                 _do,
  55.                 true);
  56.             List<ObjectId> ids = new List<ObjectId>();
  57.             ids.AddRange(MyDrawOverrule._redIds.ToArray());
  58.             ids.AddRange(MyDrawOverrule._yellowIds.ToArray());
  59.             _do.SetIdFilter(ids.ToArray());
  60.             Overrule.Overruling = true;
  61.             if (MyDrawOverrule._redIds.Count > 0)
  62.                 UnhighlightSubEntities(paths1);
  63.             if (MyDrawOverrule._yellowIds.Count > 0)
  64.                 UnhighlightSubEntities(paths2);
  65.             tr.Commit();
  66.         }
  67.         ed.Regen();
  68.     }
  69.     private static bool SelectNestedEntities
  70.         (
  71.             Editor ed,
  72.             out List<ObjectId> ids,
  73.             out List<FullSubentityPath> paths,
  74.             String colorName
  75.         )
  76.     {
  77.         ids = new List<ObjectId>();
  78.         paths = new List<FullSubentityPath>();
  79.         // Loop until cancelled or completed
  80.         PromptNestedEntityResult rs;
  81.         do
  82.         {
  83.             rs = ed.GetNestedEntity(
  84.                 String.Format("\nSelect entity to color {0}: ",
  85.                 colorName));
  86.             if (rs.Status == PromptStatus.OK)
  87.             {
  88.                 ids.Add(rs.ObjectId);
  89.                 FullSubentityPath path = FullSubentityPath.Null;
  90.                 path = HighlightSubEntity(rs);
  91.                 if (path != FullSubentityPath.Null)
  92.                     paths.Add(path);
  93.             }
  94.         } while (rs.Status == PromptStatus.OK);
  95.         return (rs.Status == PromptStatus.Cancel);
  96.     }
  97.     // Ask the user to select a number of sub-entities.
  98.     // These will have their ObjectIds and their sub-entity
  99.     // paths (returned from the HighlightSubEntity() helper)
  100.     // added to collections that are returned to the caller.
  101.     private static bool SelectNestedEntities
  102.         (
  103.             Editor ed,
  104.             out ObjectIdCollection ids,
  105.             out List<FullSubentityPath> paths
  106.         )
  107.     {
  108.         ids = new ObjectIdCollection();
  109.         paths = new List<FullSubentityPath>();
  110.         // Loop until cancelled or completed
  111.         PromptNestedEntityResult rs;
  112.         do
  113.         {
  114.             rs = ed.GetNestedEntity("\nSelect nested entity: ");
  115.             if (rs.Status == PromptStatus.OK)
  116.             {
  117.                 ids.Add(rs.ObjectId);
  118.                 FullSubentityPath path = FullSubentityPath.Null;
  119.                 path = HighlightSubEntity(rs);
  120.                 if (path != FullSubentityPath.Null)
  121.                     paths.Add(path);
  122.             }
  123.         } while (rs.Status == PromptStatus.OK);
  124.         // Cancel is the status when "enter" is used to
  125.         // terminate the selection, which means we can't
  126.         // use it to distinguish from an actual
  127.         // cancellation.
  128.         return (rs.Status == PromptStatus.Cancel);
  129.     }
  130.     // Unhighlight a set of sub-entities
  131.     private static void UnhighlightSubEntities(
  132.                                 List<FullSubentityPath> paths)
  133.     {
  134.         for (int i = 0; i < paths.Count; i++)
  135.         {
  136.             ObjectId[] ids = paths.GetObjectIds();
  137.             Entity ent
  138.                 = ids[0].GetObject(OpenMode.ForRead) as Entity;
  139.             if (ent != null)
  140.             {
  141.                 ent.Unhighlight(paths, false);
  142.             }
  143.         }
  144.     }
  145.     // Highlight a sub-entity based on its nested
  146.     // selection information.
  147.     // Return the calculated sub-entity path, so
  148.     // the calling application can later unhighlight.
  149.     private static FullSubentityPath HighlightSubEntity(
  150.                                     PromptNestedEntityResult rs)
  151.     {
  152.         // Extract relevant information from the prompt object
  153.         ObjectId selId = rs.ObjectId;
  154.         List<ObjectId> objIds = new List<ObjectId>(rs.GetContainers());
  155.         // Reverse the "containers" list
  156.         objIds.Reverse();
  157.         // Now append the selected entity
  158.         objIds.Add(selId);
  159.         // Retrieve the sub-entity path for this entity
  160.         SubentityId subEnt
  161.             = new SubentityId(SubentityType.Null, System.IntPtr.Zero);
  162.         FullSubentityPath path
  163.             = new FullSubentityPath(objIds.ToArray(), subEnt);
  164.         // Open the outermost container, relying on the open transaction...
  165.         Entity ent = objIds[0].GetObject(OpenMode.ForRead) as Entity;
  166.         // ... and highlight the nested entity
  167.         if (ent == null)
  168.             return FullSubentityPath.Null;
  169.         ent.Highlight(path, false);
  170.         // Return the sub-entity path for later unhighlighting
  171.         return path;
  172.     }
  173.     void IExtensionApplication.Initialize() { }
  174.     void IExtensionApplication.Terminate()
  175.     {
  176.         if (_do != null)
  177.         {
  178.             Overrule.Overruling = false;
  179.             Overrule.RemoveOverrule(
  180.                 RXObject.GetClass(typeof(Entity)),
  181.                 _do);
  182.         }
  183.     }
  184. }
GMT+8, 2026-11-22 07:55 , Processed in 0.345131 second(s), 10 queries , Gzip On, File On.
