查看: 1847|回复: 0
[分享] Prevent coping of the entity
已领礼包: 593个
发表于 2013-5-27 00:34:33 | 显示全部楼层 |阅读模式
Prevent coping of the entity                                                        By Virupaksha Aithal
One way to avoid erasing of entity is to use object overrule. With object overrule, you can override the “WblockClone” and "DeepClone" functionality and return NULL from the overridden API. This stops the users from copying the objects.
Below code shows the procedure.
  1. static ObjOverrule objRule = null;
  2. public class ObjOverrule : ObjectOverrule
  3. {
  4.     public override DBObject WblockClone(DBObject dbObject,
  5.             RXObject ownerObject, IdMapping idMap, bool isPrimary)
  6.     {
  7.         return null;
  8.         //return base.WblockClone(dbObject,
  9.                                 //ownerObject, idMap, isPrimary);
  10.     }
  11.     public override DBObject DeepClone(DBObject dbObject,
  12.                 DBObject ownerObject, IdMapping idMap, bool isPrimary)
  13.     {
  14.         return null;
  15.         //return base.DeepClone(dbObject,
  16.                                     //ownerObject, idMap, isPrimary);
  17.     }
  18. }
  19. [CommandMethod("copyOverrule")]
  20. static public void copyOverrule()
  21. {
  22.     if (objRule == null)
  23.     {
  24.         objRule = new ObjOverrule();
  25.         Overrule.AddOverrule(RXObject.GetClass(typeof(Line)),
  26.                                                objRule, true);
  27.         Overrule.Overruling = true;
  28.     }
  29.     else
  30.     {
  31.         Overrule.Overruling = false;
  32.         Overrule.RemoveOverrule(RXObject.GetClass(typeof(Line)),
  33.                                                      objRule);
  34.         objRule.Dispose();
  35.         objRule = null;
  36.     }
  37. }
GMT+8, 2026-11-3 10:47 , Processed in 0.392348 second(s), 28 queries , Gzip On.
