查看: 1613|回复: 0
[分享] Customizing the display of standard AutoCAD objects using .NET
已领礼包: 6个
发表于 2013-5-27 01:43:50 | 显示全部楼层 |阅读模式
The code in this post is a direct port of the F# code in this previous post, which was entered by Qun Lu in the recent F# programming contest. Someone – very validly - commented on the fact the post involved both a new language and a new API, which was probably pushing things a little from a learning perspective. :-)
Without repeating my various comments in the previous post, I will reiterate the fact that this API is extremely interesting for developers who wish to customize the appearance and behaviour of standard AutoCAD objects without going through the pain of implementing full custom objects.
Here’s the equivalent C# code that works with AutoCAD 2010:
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.Runtime;
  3. using Autodesk.AutoCAD.DatabaseServices;
  4. using Autodesk.AutoCAD.Geometry;
  5. using Autodesk.AutoCAD.GraphicsInterface;
  6. using Autodesk.AutoCAD.Colors;
  7. namespace DrawOverrule
  8. {
  9.   public class DrawOverrule : DrawableOverrule
  10.   {
  11.     static public DrawOverrule theOverrule =
  12.       new DrawOverrule();
  13.     static private double Radius = 0.5;
  14.     private SweepOptions sweepOpts = new SweepOptions();
  15.     public override bool WorldDraw (Drawable d, WorldDraw wd)
  16.     {
  17.       if (d is Line)
  18.       {
  19.         Line line = (Line)d;
  20.         // Draw the line as is, with overruled attributes
  21.         base.WorldDraw(line, wd);
  22.         if (!line.Id.IsNull && line.Length > 0.0)
  23.         {
  24.           // Draw a pipe around the line
  25.           EntityColor c =
  26.             wd.SubEntityTraits.TrueColor;
  27.           wd.SubEntityTraits.TrueColor =
  28.             new EntityColor(0x00AfAfff);
  29.           wd.SubEntityTraits.LineWeight =
  30.             LineWeight.LineWeight000;
  31.           Circle clr =
  32.             new Circle(
  33.               line.StartPoint,
  34.               line.EndPoint - line.StartPoint,
  35.               DrawOverrule.Radius
  36.             );
  37.           ExtrudedSurface pipe = new ExtrudedSurface();
  38.           try
  39.           {
  40.             pipe.CreateExtrudedSurface(
  41.               clr, line.EndPoint-line.StartPoint, sweepOpts
  42.             );
  43.           }
  44.           catch
  45.           {
  46.             Document doc =
  47.               Application.DocumentManager.MdiActiveDocument;
  48.             doc.Editor.WriteMessage(
  49.               "\nFailed with CreateExtrudedSurface."
  50.             );
  51.           }
  52.           clr.Dispose();
  53.           pipe.WorldDraw(wd);
  54.           pipe.Dispose();
  55.           wd.SubEntityTraits.TrueColor = c;
  56.         }
  57.         return true;
  58.       }
  59.       else if (d is Circle)
  60.       {
  61.         Circle circle = (Circle)d;
  62.         // Draw the circle as is, with overruled attributes
  63.         base.WorldDraw(circle, wd);
  64.         // Needed to avoid ill-formed swept surface
  65.         if (circle.Radius > DrawOverrule.Radius)
  66.         {
  67.           // Draw a pipe around the cirle
  68.           EntityColor c = wd.SubEntityTraits.TrueColor;
  69.           wd.SubEntityTraits.TrueColor =
  70.             new EntityColor(0x3fffe0e0);
  71.           wd.SubEntityTraits.LineWeight =
  72.             LineWeight.LineWeight000;
  73.           Vector3d normal =
  74.             (circle.Center-circle.StartPoint).
  75.               CrossProduct(circle.Normal);
  76.           Circle clr =
  77.             new Circle(
  78.               circle.StartPoint, normal, DrawOverrule.Radius
  79.             );
  80.           SweptSurface pipe = new SweptSurface();
  81.           pipe.CreateSweptSurface(clr, circle, sweepOpts);
  82.           clr.Dispose();
  83.           pipe.WorldDraw(wd);
  84.           pipe.Dispose();
  85.           wd.SubEntityTraits.TrueColor = c;
  86.         }
  87.         return true;
  88.       }
  89.       return base.WorldDraw(d, wd);
  90.     }
  91.     public override int SetAttributes (Drawable d, DrawableTraits t)
  92.     {
  93.       int b = base.SetAttributes(d, t);
  94.       if (d is Line)
  95.       {
  96.         // If d is LINE, set color to index 6
  97.         t.Color = 6;
  98.         // and lineweight to .40 mm
  99.         t.LineWeight = LineWeight.LineWeight040;
  100.       }
  101.       else if (d is Circle)
  102.       {
  103.         // If d is CIRCLE, set color to index 2
  104.         t.Color = 2;
  105.         // and lineweight to .60 mm
  106.         t.LineWeight = LineWeight.LineWeight060;
  107.       }
  108.       return b;
  109.     }
  110.   }
  111.   public class Commands
  112.   {
  113.     public void Overrule(bool enable)
  114.     {
  115.       // Regen to see the effect
  116.       // (turn on/off Overruling and LWDISPLAY)
  117.       DrawableOverrule.Overruling = enable;
  118.       if (enable)
  119.         Application.SetSystemVariable("LWDISPLAY", 1);
  120.       else
  121.         Application.SetSystemVariable("LWDISPLAY", 0);
  122.       Document doc =
  123.         Application.DocumentManager.MdiActiveDocument;
  124.       doc.SendStringToExecute("REGEN3\n", true, false, false);
  125.       doc.Editor.Regen();
  126.     }
  127.     [CommandMethod("OVERRULE1")]
  128.     public void OverruleStart()
  129.     {
  130.       ObjectOverrule.AddOverrule
  131.         (RXClass.GetClass(typeof(Drawable)),
  132.         DrawOverrule.theOverrule, true);
  133.       Overrule(true);
  134.     }
  135.     [CommandMethod("OVERRULE0")]
  136.     public void OverruleEnd()
  137.     {
  138.       Overrule(false);
  139.     }
  140.   }
  141. }
[Repeating the results from the previous post…]
Here’s what happens when we load the application, turn the overrule on using the OVERRULE1 command (OVERRULE0 is the command to turn the overrule off) and draw some lines and circles:
Even in a 3D view – this time with the realistic visual style applied – you get the piping effect when you draw simple geometry:
These are standard AutoCAD lines and circles. When you use the OVERRULE0 command to disable the overrule, they revert to their original form:
GMT+8, 2026-11-3 11:30 , Processed in 0.398672 second(s), 31 queries , Gzip On.
