查看: 1065|回复: 0
[他山之石] 使用Vlisul Lis 插入绑带图块
发表于 2013-5-27 07:52:36 | 显示全部楼层 |阅读模式
Bind-as-Insert, using Visual LISP                                                        By Balaji Ramamoorthy
To perform a bind-as-insert of an Xref, using Visual LISP, here is a sample code.
By setting the BINDTYPE system variable to 1, a bind-as-insert is performed:
(setvar "BINDTYPE" 1)
(command "_-xref" "_bind" "MYBLOCK")
(setvar "BINDTYPE" 0)
Using Visual Lisp, the following code will accomplish the same task.
  1. (defun c:BindInsert ( / appAcad docActive colBlocks objBlk)
  2.    (vl-load-com) ;load ActiveX
  3.    (setq appAcad (vlax-get-acad-object)
  4.          docActive (vla-get-ActiveDocument appAcad)
  5.    ) ;setq
  6.    ;;get the blocks collection
  7.    (setq colBlocks (vla-get-blocks docActive))
  8.    (vlax-for objBlk colBlocks
  9.       ;;Is the block an xref?
  10.       (if (= (vlax-get-property objBlk 'IsXref) :vlax-true)
  11.          ;;if True, then bind it as an insert
  12.          (vlax-invoke-method objBlk "bind" :vlax-true)
  13.       ) ;if
  14.       (vlax-release-object objBlk)
  15.    ) ;vlax-for
  16.    ;;release objects from memory
  17.    (vlax-release-object colBlocks)
  18.    (vlax-release-object docActive)
  19. )
  20. You might also like:
评分
参与人数 1D豆 +4 收起 理由
xshrimp + 4 很给力!经验;技术要点;资料分享奖!
查看全部评分
GMT+8, 2026-11-6 23:37 , Processed in 0.429844 second(s), 30 queries , Gzip On.
