查看: 2034|回复: 7
[原创] CAD视口投影
发表于 2013-6-1 00:02:26 | 显示全部楼层 |阅读模式
  1. (defun c:vty ()
  2.   (setq clay (getvar "clayer"))                ;取当前图层
  3.   (if (= nil (tblsearch "layer" "VPORTS"))
  4.                                         ;看下有没有vpoint 图层没有就新建
  5.     (command "-layer" "n" "VPORTS" "")
  6.   )
  7.   (command "-layer" "p" "no" "VPORTS" "")
  8.   (setvar "clayer" "VPORTS")                ;新建图层让他不打印
  9.   (setvar "CMDECHO" 0)                        ;参数回显
  10.   (setq osmode(getvar "OSMODE"))
  11.   (setvar "OSMODE" 0)
  12.   (setvar "ORTHOMODE" 1)
  13.   (while (= nil (setq ent (entsel "\n选中你要的参考视口
  14.   \n如果你现在还没有视口,
  15.   您可以退出现在命令,
  16.   再用fv来建你的前视口\n"))))
  17.   (setq vppoint (cdr (assoc 10 (entget (car ent)))))
  18.                                         ;取出你选中的视口的中心点
  19.   (setq pot1 (getpoint vppoint "点中下个视图的中点"))
  20.   (if (= (car vppoint) (car pot1))        ;判断下你的下个视口的中心位置是什么视图顶视左视正视左视右视
  21.     (setq ay "x")
  22.   )
  23.   (if (= (cadr vppoint) (cadr pot1))
  24.     (setq ay "y")
  25.   )
  26.   ;                                        ;确定要按哪个坐标来转动
  27.   (if (< (cadr vppoint) (cadr pot1))        ;确宝角度大小方向
  28.     (setq ang -90)
  29.   )
  30.   (if (> (cadr vppoint) (cadr pot1))
  31.     (setq ang 90)
  32.   )
  33.   (if (< (car vppoint) (car pot1))
  34.     (setq ang -90)
  35.   )
  36.   (if (> (car vppoint) (car pot1))
  37.     (setq ang 90)
  38.   )
  39.   (command "vpmax" ent)                        ;进入选中的视图
  40.   (command "ucs" "v")
  41.   (command "ucs" ay ang)
  42.   (command "plan" "")
  43.   (command "ucs" "na" "s" "newucs" "y")        ;新建个坐标
  44.                                         ;(command "ucs" "0,0,0" "1,0,0" "0,1,0" "")
  45.   (setq xf (GETVAR "UCSXDIR"))                ;取出x方向
  46.   (setq yf (GETVAR "UCSyDIR"))                ;取出y方向
  47.   (minmix)                                ;取出视图中所有图的最大值
  48.   (command "PSPACE")
  49.   (makvp)                                ;建视口
  50. )
  51. (defun minmix ()                        ;取最大值分程
  52.   (setq rxy (getvar "extmax"))
  53.   (setq lxy (getvar "extmin"))
  54.   (setq minx (- (car rxy) (car lxy)))
  55.   (setq miny (- (cadr rxy) (cadr lxy)))
  56.   (setq minz (- (caddr rxy) (caddr lxy)))
  57. )
  58. (defun makvp ()                                ;要pot1和运行一次minmix
  59.   (setq pot1x (car pot1))
  60.   (setq pot1y (cadr pot1))
  61.                                         ;判断下面的视口外框大小
  62.   (cond        ((= (abs (car xf)) 1.0) (setq minxx minx))
  63.         ((= (abs (cadr xf)) 1.0) (setq minxx miny))
  64.         ((= (abs (caddr xf)) 1.0) (setq minxx minz))
  65.   )
  66.   (cond        ((= (abs (car yf)) 1.0) (setq minyy minx))
  67.         ((= (abs (cadr yf)) 1.0) (setq minyy miny))
  68.         ((= (abs (caddr yf)) 1.0) (setq minyy minz))
  69.   )
  70.                                         ;下面是将视口大小改成最大值的1.2倍
  71.   (setq vp1 (list (- pot1x (/ minxx 1.8)) (+ pot1y (/ minyy 1.8))))
  72.   (setq vp2 (list (+ pot1x (/ minxx 1.8)) (- pot1y (/ minyy 1.8))))
  73.   (command "mview" vp1 vp2)                ;建视口
  74.   (setq sv (entlast))
  75.   (command "mspace")
  76.   (command "move" "all" "" "0,0,0" "0,0,0")
  77.   (command "zoom" "ex")
  78.   (command "ucs" "na" "r" "newucs")
  79.   (command "plan" "")
  80.   (command "zoom" "s" "1xp")
  81.   (command "pspace")
  82.   (command "MVIEW" "h" "on" "all" "")
  83.   (setvar "CMDECHO" 1)
  84.   (setvar "clayer" clay)
  85.   (setvar "OSMODE" OSMODE)
  86.   (princ
  87.     "
  88. \n++++++++++  特声名此程序由:           +++++++
  89. \n++++++++++    胡嘉浚编写               +++++++
  90. \n++++++++++  最终解说权终归胡嘉浚所有   +++++++
  91. \n++++++++++  谢您对我工作的支持         ++++++"
  92.   )
  93.   (princ
  94.   )
  95. )
  96. (defun c:fv ()
  97.     (setq clay (getvar "clayer"))                ;取当前图层
  98.   (setq ctab(getvar "ctab"))
  99.   (if (= nil (tblsearch "layer" "VPORTS"))
  100.                                         ;看下有没有vpoint 图层没有就新建
  101.     (command "-layer" "n" "VPORTS" "")
  102.   )
  103.   (command "-layer" "p" "no" "VPORTS" "")
  104.   (setvar "clayer" "VPORTS")                ;新建图层让他不打印
  105.   (setvar "CMDECHO" 0)
  106.
  107.   (command "model")
  108.   (command "ucs" "top")
  109.   (minmix)
  110.   (setvar "ctab" ctab)
  111.   (setq cep (getpoint "请输入你的视图中心点"))
  112.   (setq cepx (car cep))
  113.   (setq cepy (cadr cep))
  114.   (setq vp1 (list (- cepx (/ minx 1.8)) (+ cepy (/ minz 1.8))))
  115.   (setq vp2 (list (+ cepx (/ minx 1.8)) (- cepy (/ minz 1.8))))
  116.   (command "mview" vp1 vp2)
  117.     (setq sv (entlast))
  118.   (command "mspace")
  119.   (command "move" "all" "" "0,0,0" "0,0,0")
  120.   (command "zoom" "ex")
  121.   (command "ucs" "fr")
  122.   (command "plan" "")
  123.   (command "zoom" "s" "1xp")
  124.   (command "pspace")
  125.   (command "MVIEW" "h" "on" "all" "")
  126.   (setvar "CMDECHO" 1)
  127.   (setvar "clayer" clay)
  128.   (command "ucs" "v")
  129.   (princ
  130.     "
  131. \n++++++++++  特声名此程序由:           +++++++
  132. \n++++++++++    胡嘉浚编写               +++++++
  133. \n++++++++++  最终解说权终归胡嘉浚所有   +++++++
  134. \n++++++++++  谢您对我工作的支持         ++++++"
  135.   )
  136.   (princ
  137.   )
  138. )
评分
参与人数 1D豆 +6 收起 理由
XDSoft + 6 很给力!经验;技术要点;资料分享奖!
查看全部评分
 楼主| 发表于 2013-6-1 00:04:10 | 显示全部楼层
有时候会出点小毛病, 希望大家给点改良建议
说说你这个程序是做啥的,最好你做个演示动画贴论坛来。 另外,你说的小毛病,你自己发现的是什么?  详情 回复 发表于 2013-6-1 00:07
已领礼包: 145个
发表于 2013-6-1 00:07:17 | 显示全部楼层
发表于 2013-6-1 00:15:08 | 显示全部楼层
咋一个局部变量都没有啊,还有这么多的command、if{:soso_e103:}
所以说, 希望大家来点改量的呀, 要是有可用的系统变理, 我也不会那么累了  详情 回复 发表于 2013-6-1 00:47
 楼主| 发表于 2013-6-1 00:41:48 | 显示全部楼层
下面就是视频了,主要用在于布局里面用视口出图的用户。
 楼主| 发表于 2013-6-1 00:47:21 | 显示全部楼层
qiaochen朋友说你的程序没有定义局部变量,不是说的系统变量。是在DEFUN后面的。这个是程序的设计习惯。不要你的变量影响到外面的了,变量只在你的程序运行过程中存在。  详情 回复 发表于 2013-6-1 01:05
已领礼包: 20个
发表于 2013-6-1 01:05:30 | 显示全部楼层
 楼主| 发表于 2013-6-1 10:12:24 | 显示全部楼层
谢谢!我是个初级的学者, 可能我以前做的都 没有把变量放到()里面去
GMT+8, 2026-11-6 21:49 , Processed in 0.482696 second(s), 46 queries , Gzip On.
